Question about generator.
12-22-2012, 08:34
I had a leak at the fuel block on the
Kohler. I pulled it out to repair and found that the fuel connection block
had cracked. Curious if anyone has an old 12.5kw generator that is being
parted out that I might purchase the fuel block from. This is the block
that the supply and return hoses from the chassis connect to on the generator
by the fuel filter.
Second question:
I removed the generator without marking
the hose connections. Anyone know which chassis connection is the supply
and which is the return or a way to figure it out?
1982 FC31SB
Fort Worth, TX
- Chuck
Wheeler -
12-22-2012, 08:52
You can try Power Field Service in Houston for the block.
281-337-7683 They are pretty good.
2: turn on the Coach key switch, or have some one do it, to activate the
electric fuel pump and that should put fuel out the out put hose from the tank.
At 02:34 PM 12/22/2012 -0600, you wrote:
>I had a leak at the fuel block on the Kohler. I pulled it out to repair
>and found that the fuel connection block had cracked. Curious if anyone
>has an old 12.5kw generator that is being parted out that I might purchase
>the fuel block from. This is the block that the supply and return hoses
>from the chassis connect to on the generator by the fuel filter.
>Second question:
>I removed the generator without marking the hose connections. Anyone know
>which chassis connection is the supply and which is the return or a way to
>figure it out?
>1982 FC31SB
>Fort Worth, TX
>- Chuck Wheeler -
Safe travels,
Ralph & Charolette Fullenwider
'84 FC35 "Ruff Diamond"
Duncan, Oklahoma
2005 Jeep Wrangler X
_______
/l ,[____],
l---L -OlllllllO-
()_) ()_)--o-)_)
