12 volt fluorescent ballast supplier
01-28-2013, 12:22
Am in need of a replacement for a Triad-litrad Model #PS-15 Fluorescent lamp dc ballast. Does anyone know a source?
The T8 lamp has 58 watts printed on it. That seems a bit high for the 12 volt system. Old ballast has line current 2.0A or 2.75A and input voltage 13.2 VDC printed on it. Shouldn't the lamp be about 35 watts?
Jean Eichenlaub
'87 35' FC
San Diego, CA
01-28-2013, 12:36
T8 tells us the diameter (1-inch), but for ordinary bulbs the wattage is related
to length. For example, 12-inch are typically 8 watt, 15-inch are 14 watt,
18-inch are 15 watt, 24-inch are 20 watt, 36-inch are 30 watt, and 48-inch are
40 watt.
There are high output (HO) and very high output (VHO) bulbs, but they have
different end pins and are very unlikely in a Bird.
I would try Dupree Products for the ballast/inverter; I don't think they are
listed on the dupreeproducts.com website, but he probably has them.
>Jean Eichenlaub
>'87 35' FC
>San Diego, CA
01-29-2013, 07:01
Thank you. At 48" must be a 40 watt. Am thinking the best thing to do is
change out the fixture.
Jean
Sent from my iPad
01-29-2013, 07:35
Jean,
If Stephen Birtles at Dupree Products doesn't have that ballast you need, it might be worth a call to John Drake at http://www.solarseller.com/ to check with him. Good guy on DC electrical stuff and good prices.
1991 WB40 "Texas Minivan"
--- On Tue, 1/29/13, Jean Eichenlaub wrote:
Subject: [WanderlodgeForum] Re: 12 volt fluorescent ballast supplier
Date: Tuesday, January 29, 2013, 1:01 PM
Thank you. At 48" must be a 40 watt. Am thinking the best thing to do is change out the fixture.
Jean
Sent from my iPad
01-29-2013, 17:29
Jean:
Why don't you look at installing LED bulbs instead of the old flourescent. Might cost you the same to do the entire coach vs purchasing the one ballast.
On my 88, it cost under $200 to change my flourescent to LED's.
Bill
1988 40WB XXV "Anniversary Special Edition"
Kitimat, B.C. Canada eh
01-29-2013, 18:01
Can't argue with that. I made a video last year when I was doing mine - this
shows replacing 2 18-inch bulbs with about $8 worth of LED strip:
https://www.youtube.com/watch?v=WQw2LiYFn14
On 1/29/2013 at 9:29 PM Wilhelmus Schreurs wrote:
>Jean:
>the one ballast.
>Bill
