A DC Power Conundrum
07-02-2005, 08:41
My Dometic refrigerator on our 78FC 31 is currently getting its DC power from
the genset battery. I am not really sure why, but I am trying to shift it to drawing on the house banks instead. There is a solenoid on the inside right of the genset tray. I found a hot lead on the solenoid post, but when I hook up the terminal that was on the genset battery post to the solenoid post the fridge won't turn on. Is there a difference in the power supply that I don't know about (and I'll admit, I don't know much!). Is there a better way to access the DC on the house banks? Thanks for any help. John Fitz 78 FC31 Maynard MA |
07-02-2005, 09:55
If you don't receive a better answer, try "trouble
shooting" the DC circuit with a good digital voltmeter. As you know, the circuit will require both a good positive and a good negative from the same DC source; and a break in either will prevent the circuit from properly operating. I'd be especially suspicious of the ground/negative side. Additionally, if either the positive or negative leads/wires possesses an unusual resistance, a drop in the voltage may occur under load - which can occur with corroded connections and/or too small gauge of wire and too high current/amperage required by the appliance - therefore, if you can't measure the voltage under load and without load at the refrig itself, measure the voltage at the hot lead of the solenoid post at the same time as the refrig is presumably operating, to determine if the voltage is dropping under load. Voltage drop problems take a bit of time to isolate and correct. John Suter --- bluebirdfitz > My Dometic refrigerator on our 78FC 31 is currently > getting its DC power from the genset > battery. I am not really sure why, but I am trying > to shift it to drawing on the house banks > instead. There is a solenoid on the inside right of > the genset tray. I found a hot lead on > the solenoid post, but when I hook up the terminal > that was on the genset battery post to > the solenoid post the fridge won't turn on. Is > there a difference in the power supply that I > don't know about (and I'll admit, I don't know > much!). Is there a better way to access the > DC on the house banks? > > Thanks for any help. > > John Fitz > 78 FC31 > Maynard MA > > > > ____________________________________________________ Yahoo! Sports Rekindle the Rivalries. Sign up for Fantasy Football http://football.fantasysports.yahoo.com |
07-02-2005, 14:28
Thanks John,
"As you know, the circuit will require both a good > positive and a good negative from the same DC source; > and a break in either will prevent the circuit from > properly operating"--John I think you are right. An old neighbor of mine thought it had to be the ground of the fridge being on a different ground. I will check that tomorrow. Thanks for your help. --- In WanderlodgeForum@yahoogroups.com, John Suter > If you don't receive a better answer, try "trouble > shooting" the DC circuit with a good digital > voltmeter. > > As you know, the circuit will require both a good > positive and a good negative from the same DC source; > and a break in either will prevent the circuit from > properly operating. I'd be especially suspicious of > the ground/negative side. > > Additionally, if either the positive or negative > leads/wires possesses an unusual resistance, a drop in > the voltage may occur under load - which can occur > with corroded connections and/or too small gauge of > wire and too high current/amperage required by the > appliance - therefore, if you can't measure the > voltage under load and without load at the refrig > itself, measure the voltage at the hot lead of the > solenoid post at the same time as the refrig is > presumably operating, to determine if the voltage is > dropping under load. Voltage drop problems take a bit > of time to isolate and correct. > > John Suter > > > > > --- bluebirdfitz > > > My Dometic refrigerator on our 78FC 31 is currently > > getting its DC power from the genset > > battery. I am not really sure why, but I am trying > > to shift it to drawing on the house banks > > instead. There is a solenoid on the inside right of > > the genset tray. I found a hot lead on > > the solenoid post, but when I hook up the terminal > > that was on the genset battery post to > > the solenoid post the fridge won't turn on. Is > > there a difference in the power supply that I > > don't know about (and I'll admit, I don't know > > much!). Is there a better way to access the > > DC on the house banks? > > > > Thanks for any help. > > > > John Fitz > > 78 FC31 > > Maynard MA > > > > > > > > > > > > ____________________________________________________ > Yahoo! Sports > Rekindle the Rivalries. Sign up for Fantasy Football > http://football.fantasysports.yahoo.com |
07-03-2005, 01:17
John,
As original the 78 Dometic refer did not require 12 v DC. Changing modes from gas to 110 v required the operator to operate the switchover manually. Any 12V DC to your present refer was added by whoever changed out the original refrigerator. My recomendation would be to change the wiring from the generator battery to a fused supply from the house batteries. even though the current draw for the refer is probably small,I would not want the generator battery to be run down by the refer. I like the generator to always be available for charging the house batteries if needed. Steve Anderson 79 FC 35 Poulsbo,Wa. --- In WanderlodgeForum@yahoogroups.com, "bluebirdfitz" > My Dometic refrigerator on our 78FC 31 is currently getting its DC power from the genset > battery. I am not really sure why, but I am trying to shift it to drawing on the house banks > instead. There is a solenoid on the inside right of the genset tray. I found a hot lead on > the solenoid post, but when I hook up the terminal that was on the genset battery post to > the solenoid post the fridge won't turn on. Is there a difference in the power supply that I > don't know about (and I'll admit, I don't know much!). Is there a better way to access the > DC on the house banks? > > Thanks for any help. > > John Fitz > 78 FC31 > Maynard MA |
07-03-2005, 02:13
Thanks Steve,
That is what I am going to try and do (after our trip through NH)!. I also don't like to be without a generator battery. I have a trickle charger on the genset that runs whenever the ac power is being used. John fitz --- In WanderlodgeForum@yahoogroups.com, "Steve Anderson" wrote: > John, > As original the 78 Dometic refer did not require 12 v DC. Changing > modes from gas to 110 v required the operator to operate the > switchover manually. Any 12V DC to your present refer was added by > whoever changed out the original refrigerator. My recomendation would > be to change the wiring from the generator battery to a fused supply > from the house batteries. even though the current draw for the refer > is probably small,I would not want the generator battery to be run > down by the refer. I like the generator to always be available for > charging the house batteries if needed. > > Steve Anderson > 79 FC 35 > Poulsbo,Wa. > > > > > --- In WanderlodgeForum@yahoogroups.com, "bluebirdfitz" > > > My Dometic refrigerator on our 78FC 31 is currently getting its DC > power from the genset > > battery. I am not really sure why, but I am trying to shift it to > drawing on the house banks > > instead. There is a solenoid on the inside right of the genset > tray. I found a hot lead on > > the solenoid post, but when I hook up the terminal that was on the > genset battery post to > > the solenoid post the fridge won't turn on. Is there a difference > in the power supply that I > > don't know about (and I'll admit, I don't know much!). Is there a > better way to access the > > DC on the house banks? > > > > Thanks for any help. > > > > John Fitz > > 78 FC31 > > Maynard MA |
