Shurflow 2088 pump head replacements
04-30-2013, 13:11 (This post was last modified: 04-30-2013 13:12 by pgchin.)
FWIW, Shurflow 2088-554-144 fresh water pump head replacements:
http://www.amazon.com/SHURflo-94-236-08-...p_t_1_VX4A
Part number 94-236-08 is a good number confirmed by Shurflow tech support. 800-942-1153, option #2.
Pete and Donna Chin
95 42' WLWB
On The Road Always! :-)
-Toby Keith & Willie Nelson
[+] 1 user Likes pgchin's post
04-30-2013, 20:00
RE: Shurflow 2088 pump head replacements
Pete:
Does that pump head come with the wobble plate attached so all you have to do is slip it onto the motor shaft?
2003 LXI dbl. slide
George & Norma Fox
Mexico in Winter
Alaska in Summer
http://www.doszorros.com
05-01-2013, 10:31
(04-30-2013 20:00)DOSZORROS Wrote:  Pete:
George,
Yes a completely sealed unit. All you do is attach the motor to the new pump with 3 screws. In that link, at the bottom, you can buy the wobbler plate for about 15 dollars but that upper housing also has a rubber seal that usually leaks as well when these things start to go, many comments about that on the wobbler plate in Amazon and I also had the same experience which is why I now just buy a new pump.
Pete and Donna Chin
95 42' WLWB
