FC quit running
07-04-2005, 07:27
FC quit running
Hey any of you FC owners, brother Dan is traveling in his 86FC and the
engine began loosing power. he stopped and changed the Racor filter. Started and ran the same, no boost, no smoke, no power. It has now stopped. All suggestions appreciated! Thanks Jay Darst |
07-04-2005, 08:14
FC quit running
Jay,
Check the rear electric fuel pump, You should hear it clicking or a rattle at the rear, front high on the fuel tank. There is a switch that you can jumper at the oil pressure switch near the oil filters. Change the front Cat fuel filter, crack an injector or two, let out the air with the Facet electric fuel pump running. This is how it works on our 88 FC. We have no hand priming pump. Not sure if the 86 is the same. Is the Racor vacuum gage in the red??? Hope it is a fuel issue. Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" wrote: > Hey any of you FC owners, brother Dan is traveling in his 86FC and the > engine began loosing power. he stopped and changed the Racor filter. > Started and ran the same, no boost, no smoke, no power. > > It has now stopped. > > All suggestions appreciated! > > Thanks > Jay Darst |
07-04-2005, 08:43
FC quit running
I am sure you know to turn the ignition on the check the electric
fuel pump. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" wrote: > Hey any of you FC owners, brother Dan is traveling in his 86FC and the > engine began loosing power. he stopped and changed the Racor filter. > Started and ran the same, no boost, no smoke, no power. > > It has now stopped. > > All suggestions appreciated! > > Thanks > Jay Darst |
07-04-2005, 09:43
FC quit running
-Could be air in the fuel. If it will run at all, watch water
separator for air bubbles. If there, may be defective water separator. I had that situation and replacing H2O separator solved the problem. Bill 82FC33 -- In WanderlodgeForum@yahoogroups.com, "Jay Darst" wrote: > Hey any of you FC owners, brother Dan is traveling in his 86FC and the > engine began loosing power. he stopped and changed the Racor filter. > Started and ran the same, no boost, no smoke, no power. > > It has now stopped. > > All suggestions appreciated! > > Thanks > Jay Darst |
07-04-2005, 09:55
FC quit running
also,on my sister in laws coach the wire going to the fuel sol.on the pump broke
off,she put a new end on the wire and that fixed it. Randy ----- Original Message ----- From: samax8 To: WanderlodgeForum@yahoogroups.com Sent: Monday, July 04, 2005 5:43 PM Subject: [WanderlodgeForum] Re: FC quit running -Could be air in the fuel. If it will run at all, watch water separator for air bubbles. If there, may be defective water separator. I had that situation and replacing H2O separator solved the problem. Bill 82FC33 -- In WanderlodgeForum@yahoogroups.com, "Jay Darst" wrote: > Hey any of you FC owners, brother Dan is traveling in his 86FC and the > engine began loosing power. he stopped and changed the Racor filter. > Started and ran the same, no boost, no smoke, no power. > > It has now stopped. > > All suggestions appreciated! > > Thanks > Jay Darst ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
07-04-2005, 11:33
FC quit running
Appreciate the suggestions on the Facet pump...
Dan was able to get started again...though can only run in high gear at 50mph. When a hill climb is required, he must not push the throttle too hard as he will have symptoms of low fuel delivery(such as very little or no boost). When the speed reduces to a point where 3rd gear(of 4 gears)is being used, the fuel and boost return to normal full power. However, as soon as 4th gear is engaged, almost immediately, boost level reduces to 1-2psi and thus away goes the horse power. as we slow down and then back to 3rd gear, an immediate 10pounds of boost and all the horses are back. Going down a hill with throttle wide open, reached about 63mph with 10pounds of boost, then, while continuing the downhill run, the boost reduced to 1-2pounds and the Bird slowed to 50mph. Where it will run all day, with 1-3 pounds of boost. After changing the Racor, it ran bad, as before the change. So he stopped and changed the secondary fuel filter, reffered to as the "CAT" filter, I suppose to differentiate from the Racor filter. Noticed that the fuel level in the Cat filter was down maybe 2 inches in the filter. Dan replaced the Cat filter with new, primed with the Facet pump and the little hand primer pump, and the bird started and ran, BUT, NO CHANGE. Still not making power as it should. Generator has been running the whole time, no stumbles, no problems. The Racor gage is at 1 or 2 inches of vacuum, so normal. The filters are fresh. The fuel is fresh The wire to the "Fuel Shut Off Solenoid" is good. By the way, that wire, if broken, causes the Cat to NOT run at all. Been there done that. A fuel delivery issue for sure. Plans are to remove the bottom bowl from the Racor and clean the swirl tube and check ball. What else? Thanks for all your help! Jay Darst working toward a fix for 1986 FC 35 RB and an owner of the far superior and slightly better(on some days) 85PT40 ;~) --- In WanderlodgeForum@yahoogroups.com, randydupree wrote: > also,on my sister in laws coach the wire going to the fuel sol.on the pump broke off,she put a new end on the wire and that fixed it. Randy > ----- Original Message ----- > From: samax8 > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, July 04, 2005 5:43 PM > Subject: [WanderlodgeForum] Re: FC quit running > > > -Could be air in the fuel. If it will run at all, watch water > separator for air bubbles. If there, may be defective water separator. > I had that situation and replacing H2O separator solved the problem. > Bill > 82FC33 > > > -- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > wrote: > > Hey any of you FC owners, brother Dan is traveling in his 86FC and > the > > engine began loosing power. he stopped and changed the Racor filter. > > Started and ran the same, no boost, no smoke, no power. > > > > It has now stopped. > > > > All suggestions appreciated! > > > > Thanks > > Jay Darst > > > > > ------------------------------------------------------------------- ----------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------- ----------- > > > > [Non-text portions of this message have been removed] |
07-04-2005, 14:06
FC quit running
Jay.
I think you are now beyond my knowledge, maybe the experts will check in after their 4th July party. The low fuel in the primary filter should be a clue. Great idea to clean out the Racor. About a week or two ago there was a thread on blowing out the fuel lines toward the tank and then forward to the primary filter with air forced into the racor fuel lines when disconnected. Then, I guess it is onto the injectors, Bleed those injectors, until the fuel runs clear. I can easily reach five of them, and the Cat always starts. Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > Appreciate the suggestions on the Facet pump... > > Dan was able to get started again...though can only run in high gear > at 50mph. When a hill climb is required, he must not push the > throttle too hard as he will have symptoms of low fuel delivery (such > as very little or no boost). > > When the speed reduces to a point where 3rd gear(of 4 gears)is being > used, the fuel and boost return to normal full power. However, as > soon as 4th gear is engaged, almost immediately, boost level reduces > to 1-2psi and thus away goes the horse power. as we slow down and > then back to 3rd gear, an immediate 10pounds of boost and all the > horses are back. > > Going down a hill with throttle wide open, reached about 63mph with > 10pounds of boost, then, while continuing the downhill run, the > boost reduced to 1-2pounds and the Bird slowed to 50mph. Where it > will run all day, with 1-3 pounds of boost. > > After changing the Racor, it ran bad, as before the change. So he > stopped and changed the secondary fuel filter, reffered to as > the "CAT" filter, I suppose to differentiate from the Racor filter. > Noticed that the fuel level in the Cat filter was down maybe 2 > inches in the filter. > > Dan replaced the Cat filter with new, primed with the Facet pump and > the little hand primer pump, and the bird started and ran, BUT, NO > CHANGE. Still not making power as it should. > > Generator has been running the whole time, no stumbles, no problems. > > The Racor gage is at 1 or 2 inches of vacuum, so normal. > The filters are fresh. > The fuel is fresh > The wire to the "Fuel Shut Off Solenoid" is good. By the way, that > wire, if broken, causes the Cat to NOT run at all. Been there done > that. > > A fuel delivery issue for sure. > > Plans are to remove the bottom bowl from the Racor and clean the > swirl tube and check ball. > > What else? > > Thanks for all your help! > > Jay Darst > working toward a fix for 1986 FC 35 RB > and an owner of the far superior and slightly better(on some days) > 85PT40 ;~) > > > > > > --- In WanderlodgeForum@yahoogroups.com, randydupree > wrote: > > also,on my sister in laws coach the wire going to the fuel sol.on > the pump broke off,she put a new end on the wire and that fixed it. > Randy > > ----- Original Message ----- > > From: samax8 > > To: WanderlodgeForum@yahoogroups.com > > Sent: Monday, July 04, 2005 5:43 PM > > Subject: [WanderlodgeForum] Re: FC quit running > > > > > > -Could be air in the fuel. If it will run at all, watch water > > separator for air bubbles. If there, may be defective water > separator. > > I had that situation and replacing H2O separator solved the > problem. > > Bill > > 82FC33 > > > > > > -- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > > > wrote: > > > Hey any of you FC owners, brother Dan is traveling in his 86FC > and > > the > > > engine began loosing power. he stopped and changed the Racor > filter. > > > Started and ran the same, no boost, no smoke, no power. > > > > > > It has now stopped. > > > > > > All suggestions appreciated! > > > > > > Thanks > > > Jay Darst > > > > > > > > > > ----------------------------------------------------------------- -- > ----------- > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > of Service. > > > > > > ----------------------------------------------------------------- -- > ----------- > > > > > > > > [Non-text portions of this message have been removed] |
07-04-2005, 14:45
FC quit running
Thanks everyone for the quick feedback. Made it home at 8pm central time.
Took 8 hours to do a five hour trip. Cat died three times, lack of fuel flow at high demand. Changed the filters, priming both with the facet pusher pump on a dash switch we put in. So pump works. Next step is to take racor apart to try and find something causing flow restriction. Have not had this problem since fall 03, but its back again now. Thanks again. dandarst86fc35rbhuntleyil. >From: "pattypape" >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: [WanderlodgeForum] Re: FC quit running >Date: Tue, 05 Jul 2005 02:06:56 -0000 > > >Jay. >I think you are now beyond my knowledge, maybe the experts will >check in after their 4th July party. >The low fuel in the primary filter should be a clue. Great idea to >clean out the Racor. About a week or two ago there was a thread on >blowing out the fuel lines toward the tank and then forward to the >primary filter with air forced into the racor fuel lines when >disconnected. >Then, I guess it is onto the injectors, Bleed those injectors, until >the fuel runs clear. I can easily reach five of them, and the Cat >always starts. > >Bill 88 FC > >--- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > > > Appreciate the suggestions on the Facet pump... > > > > Dan was able to get started again...though can only run in high >gear > > at 50mph. When a hill climb is required, he must not push the > > throttle too hard as he will have symptoms of low fuel delivery >(such > > as very little or no boost). > > > > When the speed reduces to a point where 3rd gear(of 4 gears)is >being > > used, the fuel and boost return to normal full power. However, as > > soon as 4th gear is engaged, almost immediately, boost level >reduces > > to 1-2psi and thus away goes the horse power. as we slow down and > > then back to 3rd gear, an immediate 10pounds of boost and all the > > horses are back. > > > > Going down a hill with throttle wide open, reached about 63mph >with > > 10pounds of boost, then, while continuing the downhill run, the > > boost reduced to 1-2pounds and the Bird slowed to 50mph. Where it > > will run all day, with 1-3 pounds of boost. > > > > After changing the Racor, it ran bad, as before the change. So he > > stopped and changed the secondary fuel filter, reffered to as > > the "CAT" filter, I suppose to differentiate from the Racor >filter. > > Noticed that the fuel level in the Cat filter was down maybe 2 > > inches in the filter. > > > > Dan replaced the Cat filter with new, primed with the Facet pump >and > > the little hand primer pump, and the bird started and ran, BUT, NO > > CHANGE. Still not making power as it should. > > > > Generator has been running the whole time, no stumbles, no >problems. > > > > The Racor gage is at 1 or 2 inches of vacuum, so normal. > > The filters are fresh. > > The fuel is fresh > > The wire to the "Fuel Shut Off Solenoid" is good. By the way, that > > wire, if broken, causes the Cat to NOT run at all. Been there done > > that. > > > > A fuel delivery issue for sure. > > > > Plans are to remove the bottom bowl from the Racor and clean the > > swirl tube and check ball. > > > > What else? > > > > Thanks for all your help! > > > > Jay Darst > > working toward a fix for 1986 FC 35 RB > > and an owner of the far superior and slightly better(on some days) > > 85PT40 ;~) > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, randydupree > > wrote: > > > also,on my sister in laws coach the wire going to the fuel >sol.on > > the pump broke off,she put a new end on the wire and that fixed >it. > > Randy > > > ----- Original Message ----- > > > From: samax8 > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Monday, July 04, 2005 5:43 PM > > > Subject: [WanderlodgeForum] Re: FC quit running > > > > > > > > > -Could be air in the fuel. If it will run at all, watch water > > > separator for air bubbles. If there, may be defective water > > separator. > > > I had that situation and replacing H2O separator solved the > > problem. > > > Bill > > > 82FC33 > > > > > > > > > -- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > > > > > wrote: > > > > Hey any of you FC owners, brother Dan is traveling in his >86FC > > and > > > the > > > > engine began loosing power. he stopped and changed the Racor > > filter. > > > > Started and ran the same, no boost, no smoke, no power. > > > > > > > > It has now stopped. > > > > > > > > All suggestions appreciated! > > > > > > > > Thanks > > > > Jay Darst > > > > > > > > > > > > > > > ----------------------------------------------------------------- >-- > > ----------- > > > YAHOO! GROUPS LINKS > > > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > > > b.. To unsubscribe from this group, send an email to: > > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! >Terms > > of Service. > > > > > > > > > ----------------------------------------------------------------- >-- > > ----------- > > > > > > > > > > > > [Non-text portions of this message have been removed] > > |
07-05-2005, 03:21
FC quit running
Hi Dan,
Good to hear you drove it home. I think losing only three hours and arriving home before dark was a real accomplishment, especially with three delays. I wish I could have been of more help. I would appreciate knowing what you discover is the problem. We also had a plugged up Racor after only about 3000 miles on a new filter. Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "Dan Darst" wrote: > Thanks everyone for the quick feedback. Made it home at 8pm central time. > Took 8 hours to do a five hour trip. Cat died three times, lack of fuel flow > at high demand. Changed the filters, priming both with the facet pusher > pump on a dash switch we put in. So pump works. Next step is to take racor > apart to try and find something causing flow restriction. Have not had this > problem since fall 03, but its back again now. > > Thanks again. > > dandarst86fc35rbhuntleyil. > > >From: "pattypape" > >Reply-To: WanderlodgeForum@yahoogroups.com > >To: WanderlodgeForum@yahoogroups.com > >Subject: [WanderlodgeForum] Re: FC quit running > >Date: Tue, 05 Jul 2005 02:06:56 -0000 > > > > > >Jay. > >I think you are now beyond my knowledge, maybe the experts will > >check in after their 4th July party. > >The low fuel in the primary filter should be a clue. Great idea to > >clean out the Racor. About a week or two ago there was a thread on > >blowing out the fuel lines toward the tank and then forward to the > >primary filter with air forced into the racor fuel lines when > >disconnected. > >Then, I guess it is onto the injectors, Bleed those injectors, until > >the fuel runs clear. I can easily reach five of them, and the Cat > >always starts. > > > >Bill 88 FC > > > >--- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > > > > > Appreciate the suggestions on the Facet pump... > > > > > > Dan was able to get started again...though can only run in high > >gear > > > at 50mph. When a hill climb is required, he must not push the > > > throttle too hard as he will have symptoms of low fuel delivery > >(such > > > as very little or no boost). > > > > > > When the speed reduces to a point where 3rd gear(of 4 gears)is > >being > > > used, the fuel and boost return to normal full power. However, as > > > soon as 4th gear is engaged, almost immediately, boost level > >reduces > > > to 1-2psi and thus away goes the horse power. as we slow down and > > > then back to 3rd gear, an immediate 10pounds of boost and all the > > > horses are back. > > > > > > Going down a hill with throttle wide open, reached about 63mph > >with > > > 10pounds of boost, then, while continuing the downhill run, the > > > boost reduced to 1-2pounds and the Bird slowed to 50mph. Where it > > > will run all day, with 1-3 pounds of boost. > > > > > > After changing the Racor, it ran bad, as before the change. So he > > > stopped and changed the secondary fuel filter, reffered to as > > > the "CAT" filter, I suppose to differentiate from the Racor > >filter. > > > Noticed that the fuel level in the Cat filter was down maybe 2 > > > inches in the filter. > > > > > > Dan replaced the Cat filter with new, primed with the Facet pump > >and > > > the little hand primer pump, and the bird started and ran, BUT, NO > > > CHANGE. Still not making power as it should. > > > > > > Generator has been running the whole time, no stumbles, no > >problems. > > > > > > The Racor gage is at 1 or 2 inches of vacuum, so normal. > > > The filters are fresh. > > > The fuel is fresh > > > The wire to the "Fuel Shut Off Solenoid" is good. By the way, that > > > wire, if broken, causes the Cat to NOT run at all. Been there done > > > that. > > > > > > A fuel delivery issue for sure. > > > > > > Plans are to remove the bottom bowl from the Racor and clean the > > > swirl tube and check ball. > > > > > > What else? > > > > > > Thanks for all your help! > > > > > > Jay Darst > > > working toward a fix for 1986 FC 35 RB > > > and an owner of the far superior and slightly better(on some days) > > > 85PT40 ;~) > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, randydupree > > > wrote: > > > > also,on my sister in laws coach the wire going to the fuel > >sol.on > > > the pump broke off,she put a new end on the wire and that fixed > >it. > > > Randy > > > > ----- Original Message ----- > > > > From: samax8 > > > > To: WanderlodgeForum@yahoogroups.com > > > > Sent: Monday, July 04, 2005 5:43 PM > > > > Subject: [WanderlodgeForum] Re: FC quit running > > > > > > > > > > > > -Could be air in the fuel. If it will run at all, watch water > > > > separator for air bubbles. If there, may be defective water > > > separator. > > > > I had that situation and replacing H2O separator solved the > > > problem. > > > > Bill > > > > 82FC33 > > > > > > > > > > > > -- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > > > > > > > wrote: > > > > > Hey any of you FC owners, brother Dan is traveling in his > >86FC > > > and > > > > the > > > > > engine began loosing power. he stopped and changed the Racor > > > filter. > > > > > Started and ran the same, no boost, no smoke, no power. > > > > > > > > > > It has now stopped. > > > > > > > > > > All suggestions appreciated! > > > > > > > > > > Thanks > > > > > Jay Darst > > > > > > > > > > > > > > > > > > > > ------------------------------------------------------------- ---- > >-- > > > ----------- > > > > YAHOO! GROUPS LINKS > > > > > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > > > > > b.. To unsubscribe from this group, send an email to: > > > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! > >Terms > > > of Service. > > > > > > > > > > > > ------------------------------------------------------------- ---- > >-- > > > ----------- > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > |
07-06-2005, 04:39
FC quit running
This may not be applicable, but we had similar experiences on our
DD6v92 which turned out to be aged fuel lines. Everything would work until we had been running a few hours (the engine compartment warmed up) and then when you lifted your foot from the throttle, the fuel line would collapse causing fuel starvation. They looked normal and the DD shop said they were good. Just something you might want to check if the fuel lines haven't been replaced. We replaced and everything works fine. Dan Carr 82PT40 6V92 Columbiana, OH --- In WanderlodgeForum@yahoogroups.com, "Dan Darst" > Thanks everyone for the quick feedback. Made it home at 8pm central time. > Took 8 hours to do a five hour trip. Cat died three times, lack of fuel flow > at high demand. Changed the filters, priming both with the facet pusher > pump on a dash switch we put in. So pump works. Next step is to take racor > apart to try and find something causing flow restriction. Have not had this > problem since fall 03, but its back again now. > > Thanks again. > > dandarst86fc35rbhuntleyil. > > >From: "pattypape" > >Reply-To: WanderlodgeForum@yahoogroups.com > >To: WanderlodgeForum@yahoogroups.com > >Subject: [WanderlodgeForum] Re: FC quit running > >Date: Tue, 05 Jul 2005 02:06:56 -0000 > > > > > >Jay. > >I think you are now beyond my knowledge, maybe the experts will > >check in after their 4th July party. > >The low fuel in the primary filter should be a clue. Great idea to > >clean out the Racor. About a week or two ago there was a thread on > >blowing out the fuel lines toward the tank and then forward to the > >primary filter with air forced into the racor fuel lines when > >disconnected. > >Then, I guess it is onto the injectors, Bleed those injectors, until > >the fuel runs clear. I can easily reach five of them, and the Cat > >always starts. > > > >Bill 88 FC > > > >--- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > > > > > Appreciate the suggestions on the Facet pump... > > > > > > Dan was able to get started again...though can only run in high > >gear > > > at 50mph. When a hill climb is required, he must not push the > > > throttle too hard as he will have symptoms of low fuel delivery > >(such > > > as very little or no boost). > > > > > > When the speed reduces to a point where 3rd gear(of 4 gears)is > >being > > > used, the fuel and boost return to normal full power. However, as > > > soon as 4th gear is engaged, almost immediately, boost level > >reduces > > > to 1-2psi and thus away goes the horse power. as we slow down and > > > then back to 3rd gear, an immediate 10pounds of boost and all the > > > horses are back. > > > > > > Going down a hill with throttle wide open, reached about 63mph > >with > > > 10pounds of boost, then, while continuing the downhill run, the > > > boost reduced to 1-2pounds and the Bird slowed to 50mph. Where it > > > will run all day, with 1-3 pounds of boost. > > > > > > After changing the Racor, it ran bad, as before the change. So he > > > stopped and changed the secondary fuel filter, reffered to as > > > the "CAT" filter, I suppose to differentiate from the Racor > >filter. > > > Noticed that the fuel level in the Cat filter was down maybe 2 > > > inches in the filter. > > > > > > Dan replaced the Cat filter with new, primed with the Facet pump > >and > > > the little hand primer pump, and the bird started and ran, BUT, NO > > > CHANGE. Still not making power as it should. > > > > > > Generator has been running the whole time, no stumbles, no > >problems. > > > > > > The Racor gage is at 1 or 2 inches of vacuum, so normal. > > > The filters are fresh. > > > The fuel is fresh > > > The wire to the "Fuel Shut Off Solenoid" is good. By the way, that > > > wire, if broken, causes the Cat to NOT run at all. Been there done > > > that. > > > > > > A fuel delivery issue for sure. > > > > > > Plans are to remove the bottom bowl from the Racor and clean the > > > swirl tube and check ball. > > > > > > What else? > > > > > > Thanks for all your help! > > > > > > Jay Darst > > > working toward a fix for 1986 FC 35 RB > > > and an owner of the far superior and slightly better(on some days) > > > 85PT40 ;~) > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, randydupree > > > wrote: > > > > also,on my sister in laws coach the wire going to the fuel > >sol.on > > > the pump broke off,she put a new end on the wire and that fixed > >it. > > > Randy > > > > ----- Original Message ----- > > > > From: samax8 > > > > To: WanderlodgeForum@yahoogroups.com > > > > Sent: Monday, July 04, 2005 5:43 PM > > > > Subject: [WanderlodgeForum] Re: FC quit running > > > > > > > > > > > > -Could be air in the fuel. If it will run at all, watch water > > > > separator for air bubbles. If there, may be defective water > > > separator. > > > > I had that situation and replacing H2O separator solved the > > > problem. > > > > Bill > > > > 82FC33 > > > > > > > > > > > > -- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > > > > > > > wrote: > > > > > Hey any of you FC owners, brother Dan is traveling in his > >86FC > > > and > > > > the > > > > > engine began loosing power. he stopped and changed the Racor > > > filter. > > > > > Started and ran the same, no boost, no smoke, no power. > > > > > > > > > > It has now stopped. > > > > > > > > > > All suggestions appreciated! > > > > > > > > > > Thanks > > > > > Jay Darst > > > > > > > > > > > > > > > > > > > > ----------------------------------------------------------------- > >-- > > > ----------- > > > > YAHOO! GROUPS LINKS > > > > > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > > > > > b.. To unsubscribe from this group, send an email to: > > > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! > >Terms > > > of Service. > > > > > > > > > > > > ----------------------------------------------------------------- > >-- > > > ----------- > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > |
