Kingsley Coach on Ebay
05-26-2013, 09:09
Fun to look at! Ebay item number: 181145553110
05-27-2013, 09:46
RE: Kingsley Coach on Ebay
I like the way it is classified as a "class A" motorhome.
05-28-2013, 08:39
I've looked at several truck conversions as they would probably be my close second choice after a bus conversion. The one thing they do have over buses is ease of maintenance. Most things are way easier to get to and just about any truck garage will welcome your business.
TOM |
05-28-2013, 20:10
I hear ya Tom. My next task, and one that I've been procrastinating on, is replacement of the o-ring seals on my Series-60 oil cooler. If it were a Class-C Kingsley the job would've been done long ago. On a class-a bus I'm sure you're intimately familiar with the hoops I gotta jump thru to get 'er done!
05-29-2013, 00:15
(05-28-2013 20:10)davidmbrady Wrote: I hear ya Tom. My next task, and one that I've been procrastinating on, is replacement of the o-ring seals on my Series-60 oil cooler. If it were a Class-C Kingsley the job would've been done long ago. On a class-a bus I'm sure you're intimately familiar with the hoops I gotta jump thru to get 'er done! What hoops??!! You take it apart, swap the rings and put it all back!! What's different??? John Mace 06 450LXi bigger bird living in the wild hinterlands of the north free to roam without the man getting me down |
1 user Likes Arcticdude's post |
05-29-2013, 11:27
I know John. It's simple! Just a bolt on, but to get to it I need to remove the underbody shrouding, drain the radiator, remove a coolant pipe, tear the bedroom apart to gain access to the hatch, and possibly remove the turbo and associated exhaust pipework, and then I need a skinny person with long arms. What really hurts is that it was misting way back when I had the radiator out. With the radiator out I could have simply walked up to it, much like a Kingsley. Alas, a Kingsley is not for me. I'm way to much into the flat floor from bumper to bumper and optimization of space that a Class-A provides.
05-29-2013, 14:29
(05-29-2013 11:27)davidmbrady Wrote: What really hurts is that it was misting way back when I had the radiator out. With the radiator out I could have simply walked up to it, much like a Kingsley. Two thoughts immediately come to mind: 1) How sick were you that day???? and the more obvious 2) DOH! John Mace 06 450LXi bigger bird living in the wild hinterlands of the north free to roam without the man getting me down |
05-29-2013, 14:34
Ouch! rub it in... I remember seeing the misting but I also remember wiping it off and... well... then it was gone and I forgot about it! Poof! No more leak!
05-29-2013, 16:53
(05-29-2013 11:27)davidmbrady Wrote: I know John. It's simple! Just a bolt on, but to get to it I need to remove the underbody shrouding, drain the radiator, remove a coolant pipe, tear the bedroom apart to gain access to the hatch, and possibly remove the turbo and associated exhaust pipework, and then I need a skinny person with long arms. What really hurts is that it was misting way back when I had the radiator out. With the radiator out I could have simply walked up to it, much like a Kingsley. Alas, a Kingsley is not for me. I'm way to much into the flat floor from bumper to bumper and optimization of space that a Class-A provides. Yep. It's the "gettin' to it" that's the killer. Of course, there are some things on trucks that can try your patience too. Size wise that Kingsley is 45' long. Plenty of room! AND, it's a Peterbilt with a Prevost back! What's not to like! TOM |
