Jetta TDI as Toad and daily Driver
07-18-2005, 05:40
Well I made a plunge into a 2000 Jetta TDI
5 speed manual (Turbo Diesel) to setup as my Toad in place of the LandRover that was costing me too much to keep running (that is a different story). See photo below at the dealer of my TOAD. http://www.davidwbeatty.com/photos/Autos/Tail.jpg With the first tank of diesel consumed in my 2000 Jetta TDI, to my delight I got 45.6 MPG and I was driving mostly in the city with AC running. On the open road, I would expect over 50 mpg since Volkswagen claims 30 city / 45 hiway. With my annual mileage of 18000 I will be saving over $1700 per year in Fuel cost over the cost of driving the LandRover. I can definitely use the $$$ to keep my Bird on the road as retirement days approach. My question to the Team is: Is there a simple way to transfer around 10 gallons at a time from my 265 gallon Wanderlodge to my Jetta ? This would allow me to buy diesel when price is lower and help keep my Wanderlodge Diesel in a fresher state. Thanks for the help.... Dave Beatty 83 FC35SB (BirdCage) Federal Way, Washington State |
07-18-2005, 05:54
Dave
You might try searching for "fuel transfer pump" You will like your VW diesel, We picked up a Liberty CRD a couple months ago and are impressed greatly. Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge PT41 |
07-18-2005, 06:33
I did a quick web search and found
http://www.farmhardware.com/SuperStore/S...oduct.asp? ProductID=7269 Hand operated Fuel Transfer Pump for $32. Is this what you have seen in your travels with a diesel Toad ?? What sort of MPG do you get with your Liberty. I know the Jeep Liverty is alot larger Toad than my Jetta. Thanks for the help. Dave Beatty beattyd at yahoo dot com --- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" wrote: Dave You might try searching for "fuel transfer pump" You will like your VW diesel, We picked up a Liberty CRD a couple months ago and are impressed greatly. Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge PT41 |
07-18-2005, 07:14
Dave
That pump should work fine,although it may take a while to pump 15 gallons or so. If you want a little more volume,you should look for a larger pump. We don't have enough miles on the Liberty to judge mileage,but we have seen 24 mpg so far (they claim 27 mpg), a lot different than the 16 mpg we got with the Grand Cherokee. Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge PT41 |
07-18-2005, 07:18
Hi Dave,
Good choice for the Jetta. I've been thinking of getting one for just a daily driver here. As for transferring fuel, I would think the quickest and most flexible way would be to get an aftermarket cheap electric fuel pump, attach a hose and feed it down your filler tube. Hook it to 12Volts (possibly w/ jumper cables?) and let 'er rip. Not sure how long it would take to fill it up, though. That would depend on the size of the pump. This way you wouldn't have to mount a separate tank. However, if you're looking for a more permanent installation, let the other guys recommend something. Have your seen the veggie oil conversion kits they're selling for small cars and motorhomes now? Check it out at http://www.greasecar.com . I've seen a few they've made for big motorcoaches with 100 gallon tanks for holding the oil. Steve Dave Beatty <beattyd@...> wrote: Well I made a plunge into a 2000 Jetta TDI 5 speed manual (Turbo Diesel) to setup as my Toad in place of the LandRover that was costing me too much to keep running (that is a different story). See photo below at the dealer of my TOAD. http://www.davidwbeatty.com/photos/Autos/Tail.jpg With the first tank of diesel consumed in my 2000 Jetta TDI, to my delight I got 45.6 MPG and I was driving mostly in the city with AC running. On the open road, I would expect over 50 mpg since Volkswagen claims 30 city / 45 hiway. With my annual mileage of 18000 I will be saving over $1700 per year in Fuel cost over the cost of driving the LandRover. I can definitely use the $$$ to keep my Bird on the road as retirement days approach. My question to the Team is: Is there a simple way to transfer around 10 gallons at a time from my 265 gallon Wanderlodge to my Jetta ? This would allow me to buy diesel when price is lower and help keep my Wanderlodge Diesel in a fresher state. Thanks for the help.... Dave Beatty 83 FC35SB (BirdCage) Federal Way, Washington State --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- Steve Wicker http://www.360partybus.com 828-236-2841/301-0245 __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
07-18-2005, 08:29
Thanks Steve for the advise.
Another website I found that is for a company in the local Seattle area that promotes BioDiesel use is http://www.greencarco.com/ I dream of getting a second VW TDI but this time make it a New Beetle with the advantage of wide entry doors for this wide body of mine. But to keep this Post related to the Wanderlodge.... I will thank you for the tip about the electric fuel pump to add to the BlueBird Fuel system. I would like to really see if way to make fool-proof to use with a hose out the side of the BlueBird that I can just park the Toad Vehicle next to and pump away. If convenient to use then I will more likely use the fuel transfer system. Dave Beatty 1983 FC35SB (BirdCage) 2000 Jetta TDI GL Federal Way, Washington --- In WanderlodgeForum@yahoogroups.com, steve wicker Hi Dave, Good choice for the Jetta. I've been thinking of getting one for just a daily driver here. As for transferring fuel, I would think the quickest and most flexible way would be to get an aftermarket cheap electric fuel pump, attach a hose and feed it down your filler tube. Hook it to 12Volts (possibly w/ jumper cables?) and let 'er rip. Not sure how long it would take to fill it up, though. That would depend on the size of the pump. This way you wouldn't have to mount a separate tank. However, if you're looking for a more permanent installation, let the other guys recommend something. Have your seen the veggie oil conversion kits they're selling for small cars and motorhomes now? Check it out at http://www.greasecar.com . I've seen a few they've made for big motorcoaches with 100 gallon tanks for holding the oil. Steve Dave Beatty <beattyd@...> wrote: Well I made a plunge into a 2000 Jetta TDI 5 speed manual (Turbo Diesel) to setup as my Toad in place of the LandRover that was costing me too much to keep running (that is a different story). See photo below at the dealer of my TOAD. http://www.davidwbeatty.com/photos/Autos/Tail.jpg With the first tank of diesel consumed in my 2000 Jetta TDI, to my delight I got 45.6 MPG and I was driving mostly in the city with AC running. On the open road, I would expect over 50 mpg since Volkswagen claims 30 city / 45 hiway. With my annual mileage of 18000 I will be saving over $1700 per year in Fuel cost over the cost of driving the LandRover. I can definitely use the $$$ to keep my Bird on the road as retirement days approach. My question to the Team is: Is there a simple way to transfer around 10 gallons at a time from my 265 gallon Wanderlodge to my Jetta ? This would allow me to buy diesel when price is lower and help keep my Wanderlodge Diesel in a fresher state. Thanks for the help.... Dave Beatty 83 FC35SB (BirdCage) Federal Way, Washington State --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- Steve Wicker http://www.360partybus.com 828-236-2841/301-0245 __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
07-18-2005, 11:51
You might consider setting up some kind of filter with the pump,
there is the possibility of picking up debris from the steel tank in bird. Mine seems to have rusticles in the neck of the tank, I wouldn't want that in my new VW. I don't know if the filter system is as forgiving as in the bird. Thanks Bruce Campbell Clearwater, FL 83'FCSB "Blue Skies" formerly "Rainbow Chaser", darn those stripes are hard to get off "sorry Arley!" --- In WanderlodgeForum@yahoogroups.com, "Dave Beatty" <beattyd@y...> wrote: > Thanks Steve for the advise. > > Another website I found that is for a company in the > local Seattle area that promotes BioDiesel use is > http://www.greencarco.com/ I dream of getting a > second VW TDI but this time make it a New Beetle > with the advantage of wide entry doors for this wide > body of mine. > > But to keep this Post related to the Wanderlodge.... > I will thank you for the tip about the electric fuel > pump to add to the BlueBird Fuel system. I would > like to really see if way to make fool-proof to use > with a hose out the side of the BlueBird that I can > just park the Toad Vehicle next to and pump away. > If convenient to use then I will more likely use > the fuel transfer system. > > Dave Beatty > 1983 FC35SB (BirdCage) > 2000 Jetta TDI GL > Federal Way, Washington > > --- In WanderlodgeForum@yahoogroups.com, steve wicker Hi Dave, > > Good choice for the Jetta. I've been thinking of getting one for > just a daily driver here. As for transferring fuel, I would think > the quickest and most flexible way would be to get an aftermarket > cheap electric fuel pump, attach a hose and feed it down your filler > tube. Hook it to 12Volts (possibly w/ jumper cables?) and let 'er > rip. Not sure how long it would take to fill it up, though. > That would depend on the size of the pump. This way you wouldn't > have to mount a separate tank. However, if you're looking for a more > permanent installation, let the other guys recommend something. > Have your seen the veggie oil conversion kits they're selling for > small cars and motorhomes now? Check it out at http://www.greasecar.com . > I've seen a few they've made for big motorcoaches with 100 gallon > tanks for holding the oil. > > Steve > > Dave Beatty <beattyd@> wrote: > Well I made a plunge into a 2000 Jetta TDI > 5 speed manual (Turbo Diesel) to setup as > my Toad in place of the LandRover that was > costing me too much to keep running (that > is a different story). > > See photo below at the dealer of my TOAD. > > http://www.davidwbeatty.com/photos/Autos/Tail.jpg > > With the first tank of diesel consumed in my > 2000 Jetta TDI, to my delight I got 45.6 MPG > and I was driving mostly in the city with AC > running. On the open road, I would expect > over 50 mpg since Volkswagen claims > 30 city / 45 hiway. With my annual mileage > of 18000 I will be saving over $1700 per year > in Fuel cost over the cost of driving the > LandRover. I can definitely use the $$$ to > keep my Bird on the road as retirement days > approach. > > My question to the Team is: > > Is there a simple way to transfer around 10 > gallons at a time from my 265 gallon Wanderlodge > to my Jetta ? This would allow me to buy diesel > when price is lower and help keep my Wanderlodge > Diesel in a fresher state. > > Thanks for the help.... > > Dave Beatty > 83 FC35SB (BirdCage) > Federal Way, Washington State > > > > > > --------------------------------- > YAHOO! GROUPS LINKS > > > Visit your group "WanderlodgeForum" on the web. > > To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > --------------------------------- > > > > > Steve Wicker > http://www.360partybus.com > 828-236-2841/301-0245 > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > > [Non-text portions of this message have been removed] |
07-18-2005, 12:50
That sounds great but you would have to eat a LOT of french fries to
fuel your bird ![]() Thanks Bruce Campbell Clearwater, FL 83'FCSB "Blue Skies" formerly "Rainbow Chaser", darn those stripes are hard to get off "sorry Arley!" --- In WanderlodgeForum@yahoogroups.com, "Dave Beatty" <beattyd@y...> wrote: > Thanks Steve for the advise. > > Another website I found that is for a company in the > local Seattle area that promotes BioDiesel use is > http://www.greencarco.com/ I dream of getting a > second VW TDI but this time make it a New Beetle > with the advantage of wide entry doors for this wide > body of mine. > > But to keep this Post related to the Wanderlodge.... > I will thank you for the tip about the electric fuel > pump to add to the BlueBird Fuel system. I would > like to really see if way to make fool-proof to use > with a hose out the side of the BlueBird that I can > just park the Toad Vehicle next to and pump away. > If convenient to use then I will more likely use > the fuel transfer system. > > Dave Beatty > 1983 FC35SB (BirdCage) > 2000 Jetta TDI GL > Federal Way, Washington > > --- In WanderlodgeForum@yahoogroups.com, steve wicker Hi Dave, > > Good choice for the Jetta. I've been thinking of getting one for > just a daily driver here. As for transferring fuel, I would think > the quickest and most flexible way would be to get an aftermarket > cheap electric fuel pump, attach a hose and feed it down your filler > tube. Hook it to 12Volts (possibly w/ jumper cables?) and let 'er > rip. Not sure how long it would take to fill it up, though. > That would depend on the size of the pump. This way you wouldn't > have to mount a separate tank. However, if you're looking for a more > permanent installation, let the other guys recommend something. > Have your seen the veggie oil conversion kits they're selling for > small cars and motorhomes now? Check it out at http://www.greasecar.com . > I've seen a few they've made for big motorcoaches with 100 gallon > tanks for holding the oil. > > Steve > > Dave Beatty <beattyd@> wrote: > Well I made a plunge into a 2000 Jetta TDI > 5 speed manual (Turbo Diesel) to setup as > my Toad in place of the LandRover that was > costing me too much to keep running (that > is a different story). > > See photo below at the dealer of my TOAD. > > http://www.davidwbeatty.com/photos/Autos/Tail.jpg > > With the first tank of diesel consumed in my > 2000 Jetta TDI, to my delight I got 45.6 MPG > and I was driving mostly in the city with AC > running. On the open road, I would expect > over 50 mpg since Volkswagen claims > 30 city / 45 hiway. With my annual mileage > of 18000 I will be saving over $1700 per year > in Fuel cost over the cost of driving the > LandRover. I can definitely use the $$$ to > keep my Bird on the road as retirement days > approach. > > My question to the Team is: > > Is there a simple way to transfer around 10 > gallons at a time from my 265 gallon Wanderlodge > to my Jetta ? This would allow me to buy diesel > when price is lower and help keep my Wanderlodge > Diesel in a fresher state. > > Thanks for the help.... > > Dave Beatty > 83 FC35SB (BirdCage) > Federal Way, Washington State > > > > > > --------------------------------- > YAHOO! GROUPS LINKS > > > Visit your group "WanderlodgeForum" on the web. > > To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > --------------------------------- > > > > > Steve Wicker > http://www.360partybus.com > 828-236-2841/301-0245 > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > > [Non-text portions of this message have been removed] |
07-18-2005, 13:24
Well, Dave, I had a setup similar to what you are asking, but I did it
backwards. (Seems like I do a lot of things this way, according to my Wife)! My Toad is a Jeep CJ model. I replaced the mechanical pump with an electric, and then added a second electric pump in the rear, near the tank. I ran a rubber gas hose from the front fuel pump to the carb. One day when the Bird was empty, I simply pulled the Jeep alongside, and unhooked the gas hose from the carb, and stuck it into the Birds tank, and turned the key on. (I can do this because our Bird has that mighty 391 Ford engine)! This takes a few minuits, but I usually have a few things to do anyway. But you get the idea, In fact, put a "T: in the Birds fuel line with a valve and hose to fuel up the VW. This is assuming your Bird has a simple fuel setup like my Jeep.. Jack Smith 1973FC31 In 102 digree SoCal.. --- In WanderlodgeForum@yahoogroups.com, "Dave Beatty" <beattyd@y...> wrote: > Well I made a plunge into a 2000 Jetta TDI > 5 speed manual (Turbo Diesel) to setup as > my Toad in place of the LandRover that was > costing me too much to keep running (that > is a different story). > > See photo below at the dealer of my TOAD. > > http://www.davidwbeatty.com/photos/Autos/Tail.jpg > > With the first tank of diesel consumed in my > 2000 Jetta TDI, to my delight I got 45.6 MPG > and I was driving mostly in the city with AC > running. On the open road, I would expect > over 50 mpg since Volkswagen claims > 30 city / 45 hiway. With my annual mileage > of 18000 I will be saving over $1700 per year > in Fuel cost over the cost of driving the > LandRover. I can definitely use the $$$ to > keep my Bird on the road as retirement days > approach. > > My question to the Team is: > > Is there a simple way to transfer around 10 > gallons at a time from my 265 gallon Wanderlodge > to my Jetta ? This would allow me to buy diesel > when price is lower and help keep my Wanderlodge > Diesel in a fresher state. > > Thanks for the help.... > > Dave Beatty > 83 FC35SB (BirdCage) > Federal Way, Washington State |
07-18-2005, 15:45
Another great idea.
Seems like the "T: in the Birds fuel line with a valve and hose to fuel up the VW" should work well and does not require much cost. I will ask the repair shop that does my LOFF (Lube Oil Filters) about this option next time I go in for a LOFF. Thanks to all again and again and again. Dave Beatty 1983 FC35SB (Birdcage) 2000 Volkswagen Jetta GL TDI Federal Way, Washington State beattyd at yahoo dot com --- In WanderlodgeForum@yahoogroups.com, "Jack & Donna Smith" From: "Jack & Donna Smith" Date: Mon Jul 18, 2005 6:24 pm Subject: Re: Jetta TDI as Toad and daily Driver Well, Dave, I had a setup similar to what you are asking, but I did it backwards. (Seems like I do a lot of things this way, according to my Wife)! My Toad is a Jeep CJ model. I replaced the mechanical pump with an electric, and then added a second electric pump in the rear, near the tank. I ran a rubber gas hose from the front fuel pump to the carb. One day when the Bird was empty, I simply pulled the Jeep alongside, and unhooked the gas hose from the carb, and stuck it into the Birds tank, and turned the key on. (I can do this because our Bird has that mighty 391 Ford engine)! This takes a few minuits, but I usually have a few things to do anyway. But you get the idea, In fact, put a "T: in the Birds fuel line with a valve and hose to fuel up the VW. This is assuming your Bird has a simple fuel setup like my Jeep.. Jack Smith 1973FC31 In 102 digree SoCal.. --- In WanderlodgeForum@yahoogroups.com, "Dave Beatty" wrote: Well I made a plunge into a 2000 Jetta TDI 5 speed manual (Turbo Diesel) to setup as my Toad in place of the LandRover that was costing me too much to keep running (that is a different story). See photo below at the dealer of my TOAD. http://www.davidwbeatty.com/photos/Autos/Tail.jpg With the first tank of diesel consumed in my 2000 Jetta TDI, to my delight I got 45.6 MPG and I was driving mostly in the city with AC running. On the open road, I would expect over 50 mpg since Volkswagen claims 30 city / 45 hiway. With my annual mileage of 18000 I will be saving over $1700 per year in Fuel cost over the cost of driving the LandRover. I can definitely use the $$$ to keep my Bird on the road as retirement days approach. My question to the Team is: Is there a simple way to transfer around 10 gallons at a time from my 265 gallon Wanderlodge to my Jetta ? This would allow me to buy diesel when price is lower and help keep my Wanderlodge Diesel in a fresher state. Thanks for the help.... Dave Beatty 83 FC35SB (BirdCage) Federal Way, Washington State |
