what is this?
09-01-2005, 09:41
what is this?
was planning on heading out today but now for some reason water pump
isn't working. drat...thought we were set to go. Hope I didn't burn it up, had let the water get down so I could add fresh (don't think it was left on but it could have been) anyway no pumping water, tho of course when I am connected to water it flows, just not certain we will have a water connection where we are going. I am hearing a hiss and when I uncovered the water tank & heater found a round item next to the wall (about 3" long and 2 " diameter, which is black, red & silver) the hiss seems to be coming from it. When I put my finger underneath it I can feel the air, there is an opening about the size of the end of finger..... I took a digital pic but haven't managed to get it uploaded to this site..... help? Rose Mary 82 FC 33 Oregon |
09-01-2005, 11:47
what is this?
The item you are seeing is the electric valve the directs chassis air into
the freshwater line to blow out the water for winterization. next to the bed is a drop down door and inside is a switch to turn that valve on and off. Turn it to off. Also there should be instructions on the drop down door to tell you that during normal operation the two knobs should be in a certain posititon. Close the top one and open the bottom one. Then go in the bathroom and under the sink there is another drop down door. There is a ball valve with a handle on it. Pull it out so it is perpendicular to the pipes. Then go outside at the drivers rear of the coach and there is another door that opens to reveal the fresh water input, electrical connections etc. There is a switch there, turn it to off. This closes the sporlan valve that is on the floor near the valve you show as "what is this". Now you should be able to pump water. tom 1982 FC35 Vernon Center,NY tAt 09:41 PM 9/1/2005 +0000, you wrote: >was planning on heading out today but now for some reason water pump >isn't working. drat...thought we were set to go. Hope I didn't burn it >up, had let the water get down so I could add fresh (don't think it was >left on but it could have been) >anyway no pumping water, tho of course when I am connected to water it >flows, just not certain we will have a water connection where we are >going. >I am hearing a hiss and when I uncovered the water tank & heater found >a round item next to the wall (about 3" long and 2 " diameter, which is >black, red & silver) the hiss seems to be coming from it. When I put my >finger underneath it I can feel the air, there is an opening about the >size of the end of finger..... >I took a digital pic but haven't managed to get it uploaded to this >site..... >help? >Rose Mary >82 FC 33 >Oregon > > > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
09-01-2005, 12:05
what is this?
Tom
the outside fill switch is off, had it on when I put water in, haven't changed anything else, where is the water pump, it may have been on when the coach was low on water. Thought it was off but... Rose Mary --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > The item you are seeing is the electric valve the directs chassis air into > the freshwater line to blow out the water for winterization. next to the > bed is a drop down door and inside is a switch to turn that valve on and > off. Turn it to off. Also there should be instructions on the drop down > door to tell you that during normal operation the two knobs should be in a > certain posititon. Close the top one and open the bottom one. Then go in > the bathroom and under the sink there is another drop down door. There is a > ball valve with a handle on it. Pull it out so it is perpendicular to the > pipes. Then go outside at the drivers rear of the coach and there is > another door that opens to reveal the fresh water input, electrical > connections etc. There is a switch there, turn it to off. This closes the > sporlan valve that is on the floor near the valve you show as "what is > this". Now you should be able to pump water. > > tom > 1982 FC35 > Vernon Center,NY > > tAt 09:41 PM 9/1/2005 +0000, you wrote: > >was planning on heading out today but now for some reason water pump > >isn't working. drat...thought we were set to go. Hope I didn't burn it > >up, had let the water get down so I could add fresh (don't think it was > >left on but it could have been) > >anyway no pumping water, tho of course when I am connected to water it > >flows, just not certain we will have a water connection where we are > >going. > >I am hearing a hiss and when I uncovered the water tank & heater found > >a round item next to the wall (about 3" long and 2 " diameter, which is > >black, red & silver) the hiss seems to be coming from it. When I put my > >finger underneath it I can feel the air, there is an opening about the > >size of the end of finger..... > >I took a digital pic but haven't managed to get it uploaded to this > >site..... > >help? > >Rose Mary > >82 FC 33 > >Oregon > > > > > > > > > > > >---------- > >YAHOO! GROUPS LINKS > > > > * Visit your group > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > > * > > * To unsubscribe from this group, send an email to: > > * > > > > > > * > > * Your use of Yahoo! Groups is subject to the > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > >---------- |
09-01-2005, 13:35
what is this?
If yours is a sidebath then the water pump is under the kitchen sink.
Remove the drawer and shelves and you should find a removable panel in the back, remove it. The pump is in the rear by the wall. If you have the original design pump (quite expensive and one of the best pumps on the market) you can run it dry with no ill effects. You didnt say that you had the other valves in the correct position? Does the pump even run? You should hear it under the sink. If it is not running its possible you blew the fuse. tom 1982 FC35 Vernon Center,NY At 12:05 AM 9/2/2005 +0000, you wrote: >Tom >the outside fill switch is off, had it on when I put water in, >haven't changed anything else, where is the water pump, it may have >been on when the coach was low on water. Thought it was off but... >Rose Mary >--- In WanderlodgeForum@yahoogroups.com, Tom Warner >wrote: > > The item you are seeing is the electric valve the directs chassis >air into > > the freshwater line to blow out the water for winterization. next >to the > > bed is a drop down door and inside is a switch to turn that valve >on and > > off. Turn it to off. Also there should be instructions on the drop >down > > door to tell you that during normal operation the two knobs should >be in a > > certain posititon. Close the top one and open the bottom one. Then >go in > > the bathroom and under the sink there is another drop down door. >There is a > > ball valve with a handle on it. Pull it out so it is perpendicular >to the > > pipes. Then go outside at the drivers rear of the coach and there >is > > another door that opens to reveal the fresh water input, electrical > > connections etc. There is a switch there, turn it to off. This >closes the > > sporlan valve that is on the floor near the valve you show as "what >is > > this". Now you should be able to pump water. > > > > tom > > 1982 FC35 > > Vernon Center,NY > > > > tAt 09:41 PM 9/1/2005 +0000, you wrote: > > >was planning on heading out today but now for some reason water >pump > > >isn't working. drat...thought we were set to go. Hope I didn't >burn it > > >up, had let the water get down so I could add fresh (don't think >it was > > >left on but it could have been) > > >anyway no pumping water, tho of course when I am connected to >water it > > >flows, just not certain we will have a water connection where we >are > > >going. > > >I am hearing a hiss and when I uncovered the water tank & heater >found > > >a round item next to the wall (about 3" long and 2 " diameter, >which is > > >black, red & silver) the hiss seems to be coming from it. When I >put my > > >finger underneath it I can feel the air, there is an opening about >the > > >size of the end of finger..... > > >I took a digital pic but haven't managed to get it uploaded to this > > >site..... > > >help? > > >Rose Mary > > >82 FC 33 > > >Oregon > > > > > > > > > > > > > > > > > >---------- > > >YAHOO! GROUPS LINKS > > > > > > * Visit your group > > > > > "<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/group/\ WanderlodgeForum>WanderlodgeForum" > >on the web. > > > * > > > * To unsubscribe from this group, send an email to: > > > * > > > > > > > > > * > > > * Your use of Yahoo! Groups is subject to the > > > > <<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/>Yahoo! > Terms of Service. > > > > > > > > >---------- > > > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
09-01-2005, 14:34
what is this?
Yes, all the valves are in the correct position, the pump makes no
sound, where would its fuse be? The coach is a side bath thank you Rose Mary --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > If yours is a sidebath then the water pump is under the kitchen sink. > Remove the drawer and shelves and you should find a removable panel in the > back, remove it. The pump is in the rear by the wall. If you have the > original design pump (quite expensive and one of the best pumps on the > market) you can run it dry with no ill effects. You didnt say that you had > the other valves in the correct position? > > Does the pump even run? You should hear it under the sink. If it is not > running its possible you blew the fuse. > > tom > 1982 FC35 > Vernon Center,NY > > At 12:05 AM 9/2/2005 +0000, you wrote: > >Tom > >the outside fill switch is off, had it on when I put water in, > >haven't changed anything else, where is the water pump, it may have > >been on when the coach was low on water. Thought it was off but... > >Rose Mary > >--- In WanderlodgeForum@yahoogroups.com, Tom Warner > >wrote: > > > The item you are seeing is the electric valve the directs chassis > >air into > > > the freshwater line to blow out the water for winterization. next > >to the > > > bed is a drop down door and inside is a switch to turn that valve > >on and > > > off. Turn it to off. Also there should be instructions on the drop > >down > > > door to tell you that during normal operation the two knobs should > >be in a > > > certain posititon. Close the top one and open the bottom one. Then > >go in > > > the bathroom and under the sink there is another drop down door. > >There is a > > > ball valve with a handle on it. Pull it out so it is perpendicular > >to the > > > pipes. Then go outside at the drivers rear of the coach and there > >is > > > another door that opens to reveal the fresh water input, electrical > > > connections etc. There is a switch there, turn it to off. This > >closes the > > > sporlan valve that is on the floor near the valve you show as "what > >is > > > this". Now you should be able to pump water. > > > > > > tom > > > 1982 FC35 > > > Vernon Center,NY > > > > > > tAt 09:41 PM 9/1/2005 +0000, you wrote: > > > >was planning on heading out today but now for some reason water > >pump > > > >isn't working. drat...thought we were set to go. Hope I didn't > >burn it > > > >up, had let the water get down so I could add fresh (don't think > >it was > > > >left on but it could have been) > > > >anyway no pumping water, tho of course when I am connected to > >water it > > > >flows, just not certain we will have a water connection where we > >are > > > >going. > > > >I am hearing a hiss and when I uncovered the water tank & heater > >found > > > >a round item next to the wall (about 3" long and 2 " diameter, > >which is > > > >black, red & silver) the hiss seems to be coming from it. When I > >put my > > > >finger underneath it I can feel the air, there is an opening about > >the > > > >size of the end of finger..... > > > >I took a digital pic but haven't managed to get it uploaded to this > > > >site..... > > > >help? > > > >Rose Mary > > > >82 FC 33 > > > >Oregon > > > > > > > > > > > > > > > > > > > > > > > >---------- > > > >YAHOO! GROUPS LINKS > > > > > > > > * Visit your group > > > > > > > > "<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yaho o.com/group/WanderlodgeForum>WanderlodgeForum" > > > >on the web. > > > > * > > > > * To unsubscribe from this group, send an email to: > > > > * > > > > > > > > > > > > * > > > > * Your use of Yahoo! Groups is subject to the > > > > > > <<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/> Yahoo! > > Terms of Service. > > > > > > > > > > > >---------- > > > > > > > > > > > >---------- > >YAHOO! GROUPS LINKS > > > > * Visit your group > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > > * > > * To unsubscribe from this group, send an email to: > > * > > > > > > * > > * Your use of Yahoo! Groups is subject to the > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > >---------- |
