Have your toad push your motorhome (grade assist)
08-18-2013, 11:10
(This post was last modified: 08-30-2013 23:50 by davidbrady.)
This is a topic that comes up every now and then. Its feasibility has always been quickly dismissed. This morning I took a couple minutes to scratch on the back of an envelop. Here's what I found:
A common argument against PUSH (or toad assist on grades) is that the typical tow bar isn't designed for it. Everyone knows that tow bars are designed for towing and not pushing. (Here I don't say anything about any particular bar. I simply draw some generic conclusions that can be applied to any bar). One of the forces that tow bars need to resist is braking. When the bus driver applies his brakes the toad is forced up against the bus. In effect and in the absence of toad auxiliary braking the toad is pushing the bus. A typical bus should be able to stop from 60 mph in 200 ft. This equates to a deceleration rate of (Deceleration = VelocityInitial**2/(2*Distance)), or 20 feet per second squared. I chose the toad weight to be 5000 lbs which seems to be a good estimate for the average toad. As the bus decelerates the toad exerts a force on the bus thru the tow bar. With a toad weight of 5000 lbs and a deceleration rate of 20 feet/sq sec, the force the toad applies to the bus is (Force = mass*deceleration) or 3060 lbs. So in fact, the tow bar needs to be designed to handle significant forces under panic braking. Now, with my 2002 LXi I know that I require 500 HP to climb a 6% grade at 50 mph. Remember that not all of my crankshaft horsepower is applied to the wheels; there are losses along the way and those losses are typically in the range of 20 to 30%. Let's assume that 75% (or .75*500 = 375 HP) of the crankshaft HP appears at the wheel. Let's see what kind of horsepower the toad is exerting on the bus during panic braking. The formula to convert tractive force to horsepower is P = F*S/375 where F is the force exerted by the toad, S is the speed at which the force is exerted, and P is horsepower. Substituting in F=3060 lb, S=50 mph we get 408 HP. Notice how this number meshes well with my 375 HP prediction based on experience. Also notice that we're not applying more force to the tow bar than what would normally occur in an extreme stop. It's likely that your toad isn't capable of 400 HP at the wheels. It may be that you're only capable of 200 wheel HP. This reduction in HP and it's associated reduction in tractive force means that you'll be applying even less force to the tow bar than what it will see in a panic stop. What this quick back-of-the-envelop shows is that there's promise in PUSH assist. Disclaimer: This is a simple physics brainteaser and is far from exhaustive. Lots of real world corrections, factors, and safety practices need to be addressed. I don't recommend anyone push their motorhome due to these issues. In addition there are State laws and DOT statutes to comply with. What this simple analysis shows is that as a campfire discussion the idea can be kicked around some more! david brady, '02 Wanderlodge LXi 'Smokey' (Sold), '04 Prevost H3 Vantare 'SpongeBob' "I don't like being wrong, but I really hate being right" |
08-18-2013, 12:03
RE: Have your toad push your motorhome (grade assist)
(08-18-2013 11:10)davidbrady Wrote: This is a topic that comes up every now and then. Its feasibility has always been quickly dismissed. This morning I took a couple minutes to scratch on the back of an envelop. Here's what I found: Well, I don't know about all the physics, but I remember that Ralph used his old Jeep toad to push Dream 35 out of an intersection when he lost power. So I guess it works!
Mike Bulriss 2001 LXi 43' DS Millennium Edition San Antonio, TX |
08-18-2013, 17:39
I guess, since I tow my Yukon in an enclosed trailer- I'm outta luck
08-18-2013, 21:17
Since my toad is 4 cyl, std shift, 2 wheel drive, I guess I'm out of the picture also. Now if I used my Edsel
, that would make a difference.But, since no one makes a tow bar for it........
08-18-2013, 22:36
(This post was last modified: 08-19-2013 12:27 by travelite.)
On the contrary, I think any little bit would help. Whether it's a toad with 350 rear wheel horsepower or one with just enough power to push itself over the hill.
Along the lines of Push power, I always thought it'd be cool to develop an RV platform that has a detachable power unit. The complete drivetrain along with engine, transmission, drive wheels, fuel tank, and everything needed to feed and support the powerplant would be in a detachable trailer. Sort of like an articulated bus but with only the drivetrain in the trailer portion. These power 'modules' would be built to a standard interface so that they easily connect to any motorhome house. When a power unit needs service the owner simply drops off his leased unit at a service center and swaps it for a recently serviced unit. The power unit could be multi-fuel. It could be full battery power for city travel or natural gas for cross country. Still kind of a lame brain half baked idea, but one can dream...
08-19-2013, 09:23
(08-18-2013 22:36)davidbrady Wrote: On the contrary, I think any little bit would help. Whether it's a toad with 350 rear wheel horsepower or one with just enough power to push itself over the hill.I think this is how they get trains over the Rockies. How about a business that supplies push units at the bottom of large inclines? Of course, if one just buys a rig with enough power, it is all moot! Corey Noble Laurel Park, NC 2000 LXi 46,000 miles and counting Added features: Overbuilt cycle lift, built-in vacuum, flat panel LCD TVs, Vetus macerating toilet, Samsung fridge, Lifeline batteries, headlight cover removal campaign. |
