Differential oil level SP36
04-18-2006, 01:33
Just completed a lube job on my 90 SP36 and noted only one place
on the differential having what looked like an inspection plug.
It appears to be a slotted end shaft with a locknut on it. Is this
where the oil level is checked? If so, what should the level be
and is there any guidelines for how far the slotted shaft should be
screwed back in?
Chuck Harrison
90 SP36
Akron, Ohio
04-18-2006, 01:43
That's the pinion gear preload. It wouldn't be good to disturb
that setting. The road side of the carrier should have a 1/2" npt plug a little
below the pinion center line, your lube should be with in 1/2 inch of that
opening, coach sitting on a level surface.
Mike Hohnstein
Sent: Tuesday, April 18, 2006 8:33 AM
Subject: [WanderlodgeForum] Differential oil level SP36
screwed back in?
Chuck Harrison
90 SP36
Akron, Ohio
SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance
Recreational vehicle dealer Used recreational vehicles Automotive
radiators
YAHOO! GROUPS LINKS
04-18-2006, 02:37
Thanks Mike.
plug a little below the pinion center line, your lube should be with
in 1/2 inch of that opening, coach sitting on a level surface.
> Mike Hohnstein
> From: williamcharrison
place
this
be
> screwed back in?
> Chuck Harrison
> 90 SP36
> Akron, Ohio
maintenance
Automotive radiators
> YAHOO! GROUPS LINKS
of Service.
Loading...
