450LXi Intellitec problems
09-12-2013, 16:13
(This post was last modified: 09-12-2013 17:00 by dentmac.)
Hi.
.poorlly written here. no wifi and no data plan Using a Kindle. sow and tough to edit but only ting available (and free) Problem......everything working well until I shut off chassis and hose Battery switches then restarted . Thermostats are blank.Dry camping. the switch panals will light up with a touch but not cause action. Light up green only other then shades and panel liht button which go red as normal but do not fuction. Dc power distribution arae checked Modules b and F show no lights but all fuses good.power is there and th signal power is 7.75v. Fuses curb side rear closet OK. Found one bad fuse 12 v chassis block back centre closet but no chage. Wierd because so much out. Nowater. thermoststs.aux air compressor. blinds . all itellitec out but panels light up. I have a call in to intellitec (M and M Electronics) but they have not called back yet. Anyone experienced similar issued.. What have I missed. Thanks. Ross MacKillop Wiarton Ontario 2006 450 Lxi |
09-12-2013, 20:35
RE: 450LXi Intellitec problems
dummy.. worse really .... COACH MASTER switch was off. I really wanted to delete this thread. Having LARGE wine now.
09-12-2013, 20:41
Ross,
Glad you got it figured out. So turning off the chassis and house battery disconnect switches has the effect of toggling off the coach master switch? Sounds like the master switch is implemented with a latching relay that resets when power is lost? david brady, '02 Wanderlodge LXi 'Smokey' (Sold), '04 Prevost H3 Vantare 'SpongeBob' "I don't like being wrong, but I really hate being right" |
