Freeze Protection - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Freeze Protection (/showthread.php?tid=1625) Pages: 1 2 |
Freeze Protection - erniecarpet@... - 12-15-2008 06:06 Jon, do you happen to have the original thermostats that come with our freeze protection heaters? I believe replacement thermostats are available at Grainger.
Ernie Ekberg --where we need heat at 25 degrees today83PT40 Wanderlodge Weatherford, Texas 50 degree difference then Sunday Freeze Protection - freewill2008 - 12-15-2008 06:27 I had a "Doh!" moment last winter when I realized that on a side bath FC with the propane furnaces running, warm return air from the coach interior is being pulled into the back of the furnaces. This pulls warm air along behind the galley, fridge, and bathroom where the pipes run. The area behind the shower might not get protected this way on all models, however. Bob Griesel '84 FC31 WLII WA --- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > Ernie, > > If you are operating in cold weather I have found that the Watts Hot Water > Recirculating System worked well. It circulates back through the cold water > side and keeps both from freezing. We have a side bath so the shower is the > farthest point in the system. I have the return valve at the shower. The > down side is that you get a little burst of hot water from the cold side as > the valve switches but no freezing and you get instant hot water! Since the > family moved I have removed it and use it at the house now. > > - Chuck Wheeler- > 1982 FC 31SB Fort Worth TX > > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of erniecarpet@... > Sent: Monday, December 15, 2008 7:16 AM > To: WanderlodgeForum@yahoogroups.com > Subject: Re: [WanderlodgeForum] Freeze protection > > > > > When I was in the deep freeze of Montana, I had to put hay bales around my > tanks. Since I was able to be on 50 amps, all freeze heaters and some other > electric heaters were running. It still froze. I took the runs up that > covered the water lines and that helped. > > Ernie Ekberg > 83PT40 Wanderlodge > Weatherford, Texas > > > > _____ > > Make your life easier with all your friends, email, and favorite sites in > one place. Try > <http://www.aol.com/?optin=new- dp&icid=aolcom40vanity&ncid=emlcntaolcom00000 > 010> it now. > Freeze Protection - Jon - 12-15-2008 07:28 --- In WanderlodgeForum@yahoogroups.com, "Jon" > > Well I blew down all my water lines this week and now its 20 degrees > outside. So I hope I got all the water out of both lines as it would > be hell to repair water lines that were not drained down. I also set > up a oil electric heater in the coach just for good measures. Oh yes > one more this is that sence only haft the coach has fresh water lines > running from the back I also hung a heavy blanket from a rod (like a > shower curtain) in the front end inside of the coach by the bathroom > door. > > Now I was wondering has anyone here had the misfortune of not checking > there water lines before a big freeze? And do the newer coaches have a > better system to keep the internal pipes from freezing? My coach has that heat tape running from the water storage area back behind the water tank and then goes back behind the refrigerator. But it does not work (to old) and I really can't figure out how to re- wrap the water pipes running forward to the kitchen and then the head. Dave beatty coach has a small electrical heater that's under his bed in the water tank area and its suppose go on when the temp is down to probably 40 degrees in that area. I kind of wonder if this is a good idea as what would happen if that heater decided to short out and caught fire. Probably would never happen but who knows. I have the same style heater I found in a thrift store but need to know where I can get a thermostat that would turn a heater on and oft at a low temperature. Jon(1978 Wanderlodge) > Freeze Protection - Ryan Wright - 12-18-2008 15:32 Hmmm, this is a bit scary to me. I don't do anything to winterize my coach. I'm hooked up to 50 amp service and keep the interior toasty warm, as I'm in here on a daily basis. I assumed keeping the interior warm would keep me safe, and so far, so good, but is there something I'm missing? Are there freeze heaters I don't know about that I should be checking up on? I know where at least two thermostats for freeze heaters are located, but both are in areas of the coach that stay reasonably warm, so I doubt they ever come on. The only "winterizing" I do is dump a bit of that pink RV antifreeze down the shower drain when temps get below freezing, to keep the P trap liquid... -Ryan '86 PT-40 8V92 (lows this week dipping below 0...) On Sun, Dec 14, 2008 at 9:44 PM, Chuck Wheeler > Jon, > You do not say what bb you have, but our 82 has the plumbing wrapped with > heat tape plus freeze heaters in the pipe areas. If you have the power for > a electric heater I would make sure that the others are installed and > working. It would be very difficult to keep the plumbing areas warm by > heating the inside of the coach. I discovered this when I had a electrical > problem that kept the freeze heaters from working. The plumbing froze up > while the inside of the BB was about 75 degrees. Outside temperature was > 14. I was lucky and didn't break any pipes. > > - Chuck Wheeler- > 1982 FC 31SB Fort Worth TX Freeze Protection - freewill2008 - 12-18-2008 16:18 Having survived 50 below (really!) in an RV, it sounds like you should be in good shape. Make sure the freeze stats are really turning on what their supposed to, and leave the doors open on any cupboards or compartments that have plumbing. At home I keep the holding tanks empty and pour in 1/2 gallon of pink into each so the traps have anti-freeze and the excess ends up down at the dump valves. Bob Griesel '84 FC31 WLII WA --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > Hmmm, this is a bit scary to me. I don't do anything to winterize my > coach. I'm hooked up to 50 amp service and keep the interior toasty > warm, as I'm in here on a daily basis. I assumed keeping the interior > warm would keep me safe, and so far, so good, but is there something > I'm missing? Are there freeze heaters I don't know about that I should > be checking up on? I know where at least two thermostats for freeze > heaters are located, but both are in areas of the coach that stay > reasonably warm, so I doubt they ever come on. > > The only "winterizing" I do is dump a bit of that pink RV antifreeze > down the shower drain when temps get below freezing, to keep the P > trap liquid... > > -Ryan > '86 PT-40 8V92 (lows this week dipping below 0...) > > > On Sun, Dec 14, 2008 at 9:44 PM, Chuck Wheeler > > > Jon, > > You do not say what bb you have, but our 82 has the plumbing wrapped with > > heat tape plus freeze heaters in the pipe areas. If you have the power for > > a electric heater I would make sure that the others are installed and > > working. It would be very difficult to keep the plumbing areas warm by > > heating the inside of the coach. I discovered this when I had a electrical > > problem that kept the freeze heaters from working. The plumbing froze up > > while the inside of the BB was about 75 degrees. Outside temperature was > > 14. I was lucky and didn't break any pipes. > > > > - Chuck Wheeler- > > 1982 FC 31SB Fort Worth TX > Freeze Protection - Jon - 12-18-2008 18:32 --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Jon, do you happen to have the original thermostats that come with our > freeze protection heaters? I believe replacement thermostats are available at > Grainger. > > Ernie Ekberg > 83PT40 Wanderlodge > Weatherford, Texas > --where we need heat at 25 degrees today > 50 degree difference then Sunday > **************Make your life easier with all your friends, email, and > favorite sites in one place. Try it now. > (http://www.aol.com/?optin=new- dp&icid=aolcom40vanity&ncid=emlcntaolcom00000010) > My coach did not come with a freeze protection heater but I can install one really easy as I have the original type heater but not the thermostat. I will contact Grainger and see what they have. Thanks Jon PS. It been dipping down into the teens and I have had on my oil heater and the rear end of the coach seems to be staying even at 20 degrees about 50 degree. But I'm glad I blew down my lines just to be sure. Jon Freeze Protection - erniecarpet@... - 12-18-2008 19:59 We just did a total replacement of Mike Kanes water heater. During that time the thermostat had disintegrated from the water damage. He bought one at Grainger and it was easy to install. --the thermostat, that is.
Ernie Ekberg 83PT40 Wanderlodge Weatherford, Texas Freeze Protection - mrkane1952 - 12-20-2008 13:49 Greetings: The original thermostat (actually "Line Voltage Control") for the freeze protection heater was a Dayton 2E206, which Grainger shows as obsolete/short supply. The new replacement is a Dayton 1UHH2, about $68, and it was in stock in Garland, TX. The water heater was probably the original Atwood EHM-II SM. The replacement was identical in size, Atwood model EHP-10, at around $300. While I stood around, Ernie and his collaborator deconstructed the closet enclosure, removed the old heater and moldy rotten flooring in the closet and also the ruined plywood on the bed platform. Then the floor and platform were replaced with new materials, the new heater and thermostat installed with new plumbing connections, and the puzzle of the enclosure re-assembled. There were only two screws left over when they were done! Then they found the bathroom chassis heater core under the refrigerator was leaking coolant... --M.R.Kane 1987 PT40 1985 PT40 for sale currently Terrell, TX --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > We just did a total replacement of Mike Kanes water heater. During that time > the thermostat had disintegrated from the water damage. He bought one at > Grainger and it was easy to install. --the thermostat, that is. > > Ernie Ekberg > 83PT40 Wanderlodge > Weatherford, Texas > |
