Freeze Protection
11-27-2005, 16:44
Freeze Protection
Just was wondering how many of the old coaches had heaters (Blower
Type ) in the area that contains the water storage tank and hot water heater? And if not has anyone installed this type of device to keep that area above freezing? Jon Jon Lechich 1978 Wanderlodge |
11-27-2005, 16:49
Freeze Protection
Jon:
The early 80's Coaches had heaters in the water tank area, in the fresh water tank area and under the sink, as well as the heat tapes. Am not sure about the pre 80's though. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 04:44 AM 11/28/2005 +0000, you wrote: >Just was wondering how many of the old coaches had heaters (Blower >Type ) in the area that contains the water storage tank and hot water >heater? And if not has anyone installed this type of device to keep >that area above freezing? Jon > >Jon Lechich >1978 Wanderlodge |
11-28-2005, 02:45
Freeze Protection
Jon,
Our previous coach, a 1974 Bird, has the hair dryer type heater in the water storage & water heater area. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Jon wrote: > Just was wondering how many of the old coaches had heaters (Blower > Type ) in the area that contains the water storage tank and hot water > heater? And if not has anyone installed this type of device to keep > that area above freezing? Jon > > Jon Lechich > 1978 Wanderlodge > > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
11-28-2005, 14:30
Freeze Protection
Curt, Hairdryer ?
Greg O'Connor pt40 Romoland,CA --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Jon, > Our previous coach, a 1974 Bird, has the hair dryer type heater in the > water storage & water heater area. > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > Jon wrote: > > > Just was wondering how many of the old coaches had heaters (Blower > > Type ) in the area that contains the water storage tank and hot water > > heater? And if not has anyone installed this type of device to keep > > that area above freezing? Jon > > > > Jon Lechich > > 1978 Wanderlodge > > > > > > > > > > ------------------------------------------------------------------ ------ > > YAHOO! GROUPS LINKS > > > > * Visit your group "WanderlodgeForum > > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > > > * To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > > Service <http://docs.yahoo.com/info/terms/>. > > > > > > ------------------------------------------------------------------ ------ > > > |
11-28-2005, 17:37
Freeze Protection
Yup, that is what they looked like, just a little larger than the
household units. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Gregory OConnor wrote: > Curt, Hairdryer ? > Greg O'Connor pt40 Romoland,CA > > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > > > Jon, > > Our previous coach, a 1974 Bird, has the hair dryer type heater in > the > > water storage & water heater area. > > > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > > > > > Jon wrote: > > > > > Just was wondering how many of the old coaches had heaters (Blower > > > Type ) in the area that contains the water storage tank and hot > water > > > heater? And if not has anyone installed this type of device to > keep > > > that area above freezing? Jon > > > > > > Jon Lechich > > > 1978 Wanderlodge > > > > > > > > > > > > > > > ------------------------------------------------------------------ > ------ > > > YAHOO! GROUPS LINKS > > > > > > * Visit your group "WanderlodgeForum > > > <http://groups.yahoo.com/group/WanderlodgeForum>" on the > web. > > > > > > * To unsubscribe from this group, send an email to: > > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > > > Service <http://docs.yahoo.com/info/terms/>. > > > > > > > > > ------------------------------------------------------------------ > ------ > > > > > > > > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
12-14-2008, 16:03
Freeze Protection
Well I blew down all my water lines this week and now its 20 degrees
outside. So I hope I got all the water out of both lines as it would be hell to repair water lines that were not drained down. I also set up a oil electric heater in the coach just for good measures. Oh yes one more this is that sence only haft the coach has fresh water lines running from the back I also hung a heavy blanket from a rod (like a shower curtain) in the front end inside of the coach by the bathroom door. Now I was wondering has anyone here had the misfortune of not checking there water lines before a big freeze? And do the newer coaches have a better system to keep the internal pipes from freezing? |
12-14-2008, 17:44
Freeze Protection
Jon,
You do not say what bb you have, but our 82 has the plumbing wrapped with heat tape plus freeze heaters in the pipe areas. If you have the power for a electric heater I would make sure that the others are installed and working. It would be very difficult to keep the plumbing areas warm by heating the inside of the coach. I discovered this when I had a electrical problem that kept the freeze heaters from working. The plumbing froze up while the inside of the BB was about 75 degrees. Outside temperature was 14. I was lucky and didn't break any pipes.
- Chuck Wheeler-
1982 FC 31SB Fort Worth TX
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Jon Sent: Sunday, December 14, 2008 10:03 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Freeze protection Well I blew down all my water lines this week and now its 20 degrees outside. So I hope I got all the water out of both lines as it would be hell to repair water lines that were not drained down. I also set up a oil electric heater in the coach just for good measures. Oh yes one more this is that sence only haft the coach has fresh water lines running from the back I also hung a heavy blanket from a rod (like a shower curtain) in the front end inside of the coach by the bathroom door. Now I was wondering has anyone here had the misfortune of not checking there water lines before a big freeze? And do the newer coaches have a better system to keep the internal pipes from freezing? |
12-14-2008, 20:16
Freeze Protection
When I was in the deep freeze of Montana, I had to put hay bales around my tanks. Since I was able to be on 50 amps, all freeze heaters and some other electric heaters were running. It still froze. I took the runs up that covered the water lines and that helped.
Ernie Ekberg 83PT40 Wanderlodge Weatherford, Texas |
12-15-2008, 04:54
Freeze Protection
The newer coaches have a heated basement with a "low temperature" thermostat. (It holds about 40 degrees.) The AquaHot system provides the heat. In moderate (light) freeze conditions, the 2000 watt electric element provides sufficient heat. In colder conditions, the diesel burner must be set to cycle on. My coach also has 'heat tape' on one pipe that runs through a raceway at the edge of the coach.
The electric oil-filled heater is a good choice for inside the coach. I suggest opening the cabinets, especially those with plumbing inside, so the heat will reach the pipes. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Dec 14, 2008, at 8:03 PM, Jon wrote:
12-15-2008, 05:32
Freeze Protection
Ernie,
If you are operating in cold weather I have found that the Watts Hot Water Recirculating System worked well. It circulates back through the cold water side and keeps both from freezing. We have a side bath so the shower is the farthest point in the system. I have the return valve at the shower. The down side is that you get a little burst of hot water from the cold side as the valve switchesbut no freezing and you get instant hot water! Since the family moved I have removed it and use it at the house now.
- Chuck Wheeler-
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of erniecarpet@... Sent: Monday, December 15, 2008 7:16 AM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Freeze protection When I was in the deep freeze of Montana, I had to put hay bales around my tanks. Since I was able to be on 50 amps, all freeze heaters and some other electric heaters were running. It still froze. I took the runs up that covered the water lines and that helped.
