Fresh Water Tank Drain - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Fresh Water Tank Drain (/showthread.php?tid=3582) Pages: 1 2 |
Fresh Water Tank Drain - Pete Masterson - 10-22-2008 02:01 My coach has a water drain on the curb side (near where the water pump is located) that requires the pump to operate in order to drain the tank. It also has a 2" valve (similar to the 3" valves used for the holding tanks) behind a door in the water/holding tank hookup bay that drains the fresh water tank by gravity (and fairly quickly, I might add). The fresh water plumbing is white plastic, while the holding tank plumbing is black plastic pipe in my coach. I believe that the pump-required drain has something to do with winterizing (but that's not a problem where I live as it never freezes there). Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Edinburg, VA On Oct 21, 2008, at 2:55 PM, williamcharrison wrote: > My fresh water tank will not drain unless the pump is on, how do I > drain it otherwise? > > Chuck Harrison > Akron, Ohio > 90 SP36 > > Fresh Water Tank Drain - jim riordan - 10-23-2008 01:25 There should be a lever on the base of the bed. otherwise lift up the bed and look next to the pump you should find a way to open the valve. I also have a hand washing spigot on the curb side of my coach, i havent tried it to drain the tank but i guess that it wold work also. Jim Riordan 88 wbwl xxv Donald Spithaler
