Water leak... - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Water leak... (/showthread.php?tid=3655) Pages: 1 2 |
Water leak... - John - 10-17-2006 13:02 First of all I want to thank everyone for the replies...all were very helpful! I got the spoiler off and am in the process of cleaning off the sealant that was between it and the roof. I agree that it is probably un-necessary to seal all the way around the spoiler. I think when I replace it I will mainly just seal around where the screws enter the roof. Rob, I found that Home Depot had a Butyl sealant. It Dap Butyl-Flex rubber sealant. It says Gutter & Flashing on the tube. It was about $3.50 for the 10oz. tube. McCoys hardware had the NP-1 as well. Thanks again everyone, John C --- In WanderlodgeForum@yahoogroups.com, David Brady > > Rob, > > Where do you buy Buytal? I did some internet searches > an the best I can come up with is ebay. > > Thanks, > David B > '02 LXi, Smokey > Va > > Rob Robinson wrote: > > John I would seal the individual mounting holes with Urethane or Buytal. If > > the mounting holes in the fiberglass cap have small radiating stress cracks > > you could use a self-leveling sealant like Dicor 501 lap sealant or Sikoflex > > > > > > > >>> > >> > >> > > > > > > > > > > > > [Non-text portions of this message have been removed] > Water leak... - Alex Smith - 10-18-2006 04:29 Check with any major builders supply house or professional painters supply. They should have a number of different sealants and someone on staff should be able to recommend the proper product. Alex Smith Tallahassee 82FC35 Stephen Birtles search on butyl sealant some canajuns cantspel Stephen 77fc35 have a great day rob --- In WanderlodgeForum@yahoogroups.com, David Brady > > Rob, > > Where do you buy Buytal? I did some internet searches > an the best I can come up with is ebay. > > Thanks, > David B > '02 LXi, Smokey > Va > > Rob Robinson wrote: > > John I would seal the individual mounting holes with Urethane or Buytal. If > > the mounting holes in the fiberglass cap have small radiating stress cracks > > you could use a self-leveling sealant like Dicor 501 lap sealant or Sikoflex > > > > > > > >>> > >> > >> > > > > > > > > > > > > [Non-text portions of this message have been removed] > --------------------------------- How low will we go? Check out Yahoo! Messengerâs low PC-to-Phone call rates. [Non-text portions of this message have been removed] Water leak... - Rob Robinson - 10-18-2006 12:36 David I have bought butyl tape at paint and body shop suppliers. It is usually used to seal windshields. I believe you can buy it in both tape and liquid form. I use the tape and pull small pieces off and wind them around each SS lag screw I put into a roof. On 18/10/06, Alex Smith > > Check with any major builders supply house or professional painters > supply. They should have a number of different sealants and someone on staff > should be able to recommend the proper product. > Alex Smith > Tallahassee > 82FC35 > > Stephen Birtles > search on butyl sealant > some canajuns cantspel > Stephen 77fc35 have a great day rob > > --- In WanderlodgeForum@yahoogroups.com > David Brady > > > > Rob, > > > > Where do you buy Buytal? I did some internet searches > > an the best I can come up with is ebay. > > > > Thanks, > > David B > > '02 LXi, Smokey > > Va > > > > Rob Robinson wrote: > > > John I would seal the individual mounting holes with Urethane or > Buytal. If > > > the mounting holes in the fiberglass cap have small radiating > stress cracks > > > you could use a self-leveling sealant like Dicor 501 lap sealant > or Sikoflex > > > > > > > > > > > >>> > > >> > > >> > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > --------------------------------- > How low will we go? Check out Yahoo! Messenger's low PC-to-Phone call > rates. > > [Non-text portions of this message have been removed] > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] Water leak... - John - 10-18-2006 13:05 I just wanted to update my situation. I ended up pulling off the spoiler and cleaning up everything as well as possible. I used the NP-1 around all the screws to reattach the spoiler. I wish I had been able to get it done a little earlier, but it had about 4 or 5 hours of sunny hot weather to cure before it started pouring rain again. Went inside and so far everything was still dry as a chip! I just hope that was long enough for the NP1 to cure. Thanks again for all the replies and help. John C 98 Wanderlodge LX --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > David I have bought butyl tape at paint and body shop suppliers. It is > usually used to seal windshields. I believe you can buy it in both tape and > liquid form. I use the tape and pull small pieces off and wind them around > each SS lag screw I put into a roof. > > On 18/10/06, Alex Smith > > > > Check with any major builders supply house or professional painters > > supply. They should have a number of different sealants and someone on staff > > should be able to recommend the proper product. > > Alex Smith > > Tallahassee > > 82FC35 > > > > Stephen Birtles > > search on butyl sealant > > some canajuns cantspel > > Stephen 77fc35 have a great day rob > > > > --- In WanderlodgeForum@yahoogroups.com > > David Brady > > > > > > Rob, > > > > > > Where do you buy Buytal? I did some internet searches > > > an the best I can come up with is ebay. > > > > > > Thanks, > > > David B > > > '02 LXi, Smokey > > > Va > > > > > > Rob Robinson wrote: > > > > John I would seal the individual mounting holes with Urethane or > > Buytal. If > > > > the mounting holes in the fiberglass cap have small radiating > > stress cracks > > > > you could use a self-leveling sealant like Dicor 501 lap sealant > > or Sikoflex > > > > > > > > > > > > > > > >>> > > > >> > > > >> > > > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > --------------------------------- > > How low will we go? Check out Yahoo! Messenger's low PC-to-Phone call > > rates. > > > > [Non-text portions of this message have been removed] > > > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > > [Non-text portions of this message have been removed] > Water leak... - Leroy Eckert - 10-18-2006 14:59 John, I use NP-1 daily. It's nasty @#$% but it works. If it was applied on a dry substrate metal or otherwise you should be OK. I wouldn't think rain would effect it after 5 hours. Leroy Eckert 1990 WB-40 Niceville, FL Side note. I used NP-1 to apply the polished stainless upgrade on my coach about 1 year ago. It is still there. ----- Original Message ----- From: John To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, October 18, 2006 8:05 PM Subject: [WanderlodgeForum] Re: Water leak... I just wanted to update my situation. I ended up pulling off the spoiler and cleaning up everything as well as possible. I used the NP-1 around all the screws to reattach the spoiler. I wish I had been able to get it done a little earlier, but it had about 4 or 5 hours of sunny hot weather to cure before it started pouring rain again. Went inside and so far everything was still dry as a chip! I just hope that was long enough for the NP1 to cure. Thanks again for all the replies and help. John C 98 Wanderlodge LX --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > David I have bought butyl tape at paint and body shop suppliers. It is > usually used to seal windshields. I believe you can buy it in both tape and > liquid form. I use the tape and pull small pieces off and wind them around > each SS lag screw I put into a roof. > > On 18/10/06, Alex Smith > > > > Check with any major builders supply house or professional painters > > supply. They should have a number of different sealants and someone on staff > > should be able to recommend the proper product. > > Alex Smith > > Tallahassee > > 82FC35 > > > > Stephen Birtles > > search on butyl sealant > > some canajuns cantspel > > Stephen 77fc35 have a great day rob > > > > --- In WanderlodgeForum@yahoogroups.com > > David Brady > > > > > > Rob, > > > > > > Where do you buy Buytal? I did some internet searches > > > an the best I can come up with is ebay. > > > > > > Thanks, > > > David B > > > '02 LXi, Smokey > > > Va > > > > > > Rob Robinson wrote: > > > > John I would seal the individual mounting holes with Urethane or > > Buytal. If > > > > the mounting holes in the fiberglass cap have small radiating > > stress cracks > > > > you could use a self-leveling sealant like Dicor 501 lap sealant > > or Sikoflex > > > > > > > > > > > > > > > >>> > > > >> > > > >> > > > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > --------------------------------- > > How low will we go? Check out Yahoo! Messenger's low PC-to-Phone call > > rates. > > > > [Non-text portions of this message have been removed] > > > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
