Hot water and boondocking - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Hot water and boondocking (/showthread.php?tid=3987) Pages: 1 2 |
Hot water and boondocking - erniecarpet@... - 12-12-2006 06:48 It sure was a relatively easy build when the factory did all our plumbing. After they installed the bed, cabinets, closets- then it became a chore to work on. I'll probably replace the street side plumbing with pex when I get back to Montana next year. At least I have a few months to either think about that project- or just forget about it. Ernie Ekberg 83PT40 Weatherford, tx [Non-text portions of this message have been removed] Hot water and boondocking - Jeff Miller - 12-12-2006 07:21 I'm used to the household system which has a return line to the cold/supply side of the water heater, with a check valve, and convection keeps the hot water circulating throughout the system. A manual valve in the return is also employed to restrict flow. Works great in a household water heater, whether it would also work in the relatively short RV-size tank I don't know. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" wrote: > > We took a 4 day trip and had only power available. I left with a > full water tank and mostly empty grey and black tanks. By the last > day I had about 1/4 tank of water left. I began to think about ways > to conserve water to streach the time we could stay. One thought was > the waste of water waiting for the sink or shower hot water to come > up to temperature. It was cold outside so it took a while, wasted > water and holding tank capacity. > > In hotels/motels/large buildings they use a circulating system > that keeps the hot water supply hot so you don't wait for hot water > at the tub or tap. It would seem that this could be done in an RV by > adding a return line from the far end of the hot water system, a one- > way valve and a pump. Then all you would need to do is activate the > pump for a minute or so to charge the system, and then start the > shower. It would conserve the water supply as well as the grey tank > space. > > Has anyone seen this kind of system in use? > > Gardner > 78FC33 > Hot water and boondocking - Gary Miller - 12-12-2006 09:21 An interesting thought for water conservation but, since the copper hot water pipes are bundled next to the copper cold water pipes, then wrapped in heat tape, you'll have to find a way to keep your cold water cold once you start keeping your hot water hot... With every yin, there's a yang... Gary Miller 83 FC 33 Milwaukee area --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" wrote: > > We took a 4 day trip and had only power available. I left with a > full water tank and mostly empty grey and black tanks. By the last > day I had about 1/4 tank of water left. I began to think about ways > to conserve water to streach the time we could stay. One thought was > the waste of water waiting for the sink or shower hot water to come > up to temperature. It was cold outside so it took a while, wasted > water and holding tank capacity. > > In hotels/motels/large buildings they use a circulating system > that keeps the hot water supply hot so you don't wait for hot water > at the tub or tap. It would seem that this could be done in an RV by > adding a return line from the far end of the hot water system, a one- > way valve and a pump. Then all you would need to do is activate the > pump for a minute or so to charge the system, and then start the > shower. It would conserve the water supply as well as the grey tank > space. > > Has anyone seen this kind of system in use? > > Gardner > 78FC33 > Hot water and boondocking - Bill - 12-23-2006 11:15 Hi all: Back onto this topic. I was doing some browsing of the net, and Lucas Willemese (did I spell that right?) had a gizmo in his coach. Well I am not sure if this was the item or not, but it is called a "chillipepper". Just the thing that we should have on our coaches. Look it up and let me know what you think. http://www.chilipepperapp.com/hwcs.htm Bill 84FC35SB Terrace, B.C. I began to think about > ways > > to conserve water to streach the time we could stay. One thought > was > > the waste of water waiting for the sink or shower hot water to > come > > up to temperature. It was cold outside so it took a while, wasted > > water and holding tank capacity. > > > > In hotels/motels/large buildings they use a circulating system > > that keeps the hot water supply hot so you don't wait for hot > water > > at the tub or tap. It would seem that this could be done in an RV > by > > adding a return line from the far end of the hot water system, a > one- > > way valve and a pump. Then all you would need to do is activate > the > > pump for a minute or so to charge the system, and then start the > > shower. It would conserve the water supply as well as the grey > tank > > space. > > > > Has anyone seen this kind of system in use? > > > > Gardner > > 78FC33 > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > Hot water and boondocking - Gardner Yeaw - 12-23-2006 13:39 Bill, I don't know if my previous post made it, I got a bad message, so here I go again. Nice find on the Chilipepper. I may even install one in my house. I need to install a bypass for the hot water heater in the Bird for winterization, so it might be a good time to install one of these as well. I had to replace the ice maker module in the U-line, and the microwave krumped, so I don't think the Chilipepper will be on the imediate horizon. I was thinking I might paint the Bird Visa blue with Red ink trim. What do you think? Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Bill" wrote: > > Hi all: > Back onto this topic. I was doing some browsing of the net, and > Lucas Willemese (did I spell that right?) had a gizmo in his coach. > Well I am not sure if this was the item or not, but it is called > a "chillipepper". Just the thing that we should have on our coaches. > Look it up and let me know what you think. > http://www.chilipepperapp.com/hwcs.htm > > Bill > 84FC35SB > Terrace, B.C. > > > I began to think about > > ways > > > to conserve water to streach the time we could stay. One thought > > was > > > the waste of water waiting for the sink or shower hot water to > > come > > > up to temperature. It was cold outside so it took a while, wasted > > > water and holding tank capacity. > > > > > > In hotels/motels/large buildings they use a circulating system > > > that keeps the hot water supply hot so you don't wait for hot > > water > > > at the tub or tap. It would seem that this could be done in an RV > > by > > > adding a return line from the far end of the hot water system, a > > one- > > > way valve and a pump. Then all you would need to do is activate > > the > > > pump for a minute or so to charge the system, and then start the > > > shower. It would conserve the water supply as well as the grey > > tank > > > space. > > > > > > Has anyone seen this kind of system in use? > > > > > > Gardner > > > 78FC33 > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > Hot water and boondocking - Pete Masterson - 12-23-2006 15:01 Hey, a 'bird is better than a boat. Boats sink. (Well, a 'bird would, too, but they're usually not _intentionally_ put into water.) Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA On Dec 23, 2006, at 5:39 PM, Gardner Yeaw wrote: > <snip> > > I was thinking I might paint the Bird Visa blue with Red ink trim. > What do you think? [Non-text portions of this message have been removed] Hot water and boondocking - Gregory OConnor - 12-23-2006 18:39 Bill, Lucas and Linda have all the cool stuff. The little green toad was the best. Years back California had a water shortage and one method we used to save the resource and get the hotwater to the shower was to simply brush your teeth with the cold water that comes out of the hot tap at the sink prior to hitting the shower (won't work if you clean them in a cup). Chillipepper is cool and I can see where it is a must have on a Yacht like the Willemese have. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Bill" wrote: > > Hi all: > Back onto this topic. I was doing some browsing of the net, and > Lucas Willemese (did I spell that right?) had a gizmo in his coach. > Well I am not sure if this was the item or not, but it is called > a "chillipepper". Just the thing that we should have on our coaches. > Look it up and let me know what you think. > http://www.chilipepperapp.com/hwcs.htm > > Bill > 84FC35SB > Terrace, B.C. > > > I began to think about > > ways > > > to conserve water to streach the time we could stay. One thought > > was > > > the waste of water waiting for the sink or shower hot water to > > come > > > up to temperature. It was cold outside so it took a while, wasted > > > water and holding tank capacity. > > > > > > In hotels/motels/large buildings they use a circulating system > > > that keeps the hot water supply hot so you don't wait for hot > > water > > > at the tub or tap. It would seem that this could be done in an RV > > by > > > adding a return line from the far end of the hot water system, a > > one- > > > way valve and a pump. Then all you would need to do is activate > > the > > > pump for a minute or so to charge the system, and then start the > > > shower. It would conserve the water supply as well as the grey > > tank > > > space. > > > > > > Has anyone seen this kind of system in use? > > > > > > Gardner > > > 78FC33 > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > Hot water and boondocking - Wilhelmus Schreurs - 12-24-2006 05:39 Greg: You right, they had all sorts of cool stuff, and that little green toad was awesome. For a little car, it was quite roomy in the back seat LOL. And you right about the cup thing too - hehe. Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: Gregory OConnor To: WanderlodgeForum@yahoogroups.com Sent: Saturday, December 23, 2006 10:39:16 PM Subject: [WanderlodgeForum] Re: Hot water and boondocking Bill, Lucas and Linda have all the cool stuff. The little green toad was the best. Years back California had a water shortage and one method we used to save the resource and get the hotwater to the shower was to simply brush your teeth with the cold water that comes out of the hot tap at the sink prior to hitting the shower (won't work if you clean them in a cup). Chillipepper is cool and I can see where it is a must have on a Yacht like the Willemese have. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@ yahoogroups. com, "Bill" wrote: > > Hi all: > Back onto this topic. I was doing some browsing of the net, and > Lucas Willemese (did I spell that right?) had a gizmo in his coach. > Well I am not sure if this was the item or not, but it is called > a "chillipepper" . Just the thing that we should have on our coaches. > Look it up and let me know what you think. > http://www.chilipep perapp.com/ hwcs.htm > > Bill > 84FC35SB > Terrace, B.C. > > > I began to think about > > ways > > > to conserve water to streach the time we could stay. One thought > > was > > > the waste of water waiting for the sink or shower hot water to > > come > > > up to temperature. It was cold outside so it took a while, wasted > > > water and holding tank capacity. > > > > > > In hotels/motels/ large buildings they use a circulating system > > > that keeps the hot water supply hot so you don't wait for hot > > water > > > at the tub or tap. It would seem that this could be done in an RV > > by > > > adding a return line from the far end of the hot water system, a > > one- > > > way valve and a pump. Then all you would need to do is activate > > the > > > pump for a minute or so to charge the system, and then start the > > > shower. It would conserve the water supply as well as the grey > > tank > > > space. > > > > > > Has anyone seen this kind of system in use? > > > > > > Gardner > > > 78FC33 > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] Hot water and boondocking - Wilhelmus Schreurs - 12-24-2006 06:12 Gardner: Have you tried putting your bus pic into a pic gallery and painting it there before you actually paint it? I liked the color of one of the FC's, it was white, blue and red, and my wife hated it, hmmm it is all in the eye of the beholder LOL Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: Gardner Yeaw To: WanderlodgeForum@yahoogroups.com Sent: Saturday, December 23, 2006 5:39:37 PM Subject: [WanderlodgeForum] Re: Hot water and boondocking Bill, I don't know if my previous post made it, I got a bad message, so here I go again. Nice find on the Chilipepper. I may even install one in my house. I need to install a bypass for the hot water heater in the Bird for winterization, so it might be a good time to install one of these as well. I had to replace the ice maker module in the U-line, and the microwave krumped, so I don't think the Chilipepper will be on the imediate horizon. I was thinking I might paint the Bird Visa blue with Red ink trim. What do you think? Gardner 78FC33 --- In WanderlodgeForum@ yahoogroups. com, "Bill" wrote: > > Hi all: > Back onto this topic. I was doing some browsing of the net, and > Lucas Willemese (did I spell that right?) had a gizmo in his coach. > Well I am not sure if this was the item or not, but it is called > a "chillipepper" . Just the thing that we should have on our coaches. > Look it up and let me know what you think. > http://www.chilipep perapp.com/ hwcs.htm > > Bill > 84FC35SB > Terrace, B.C. > > > I began to think about > > ways > > > to conserve water to streach the time we could stay. One thought > > was > > > the waste of water waiting for the sink or shower hot water to > > come > > > up to temperature. It was cold outside so it took a while, wasted > > > water and holding tank capacity. > > > > > > In hotels/motels/ large buildings they use a circulating system > > > that keeps the hot water supply hot so you don't wait for hot > > water > > > at the tub or tap. It would seem that this could be done in an RV > > by > > > adding a return line from the far end of the hot water system, a > > one- > > > way valve and a pump. Then all you would need to do is activate > > the > > > pump for a minute or so to charge the system, and then start the > > > shower. It would conserve the water supply as well as the grey > > tank > > > space. > > > > > > Has anyone seen this kind of system in use? > > > > > > Gardner > > > 78FC33 > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] Hot water and boondocking - Gardner Yeaw - 12-24-2006 09:55 Bill, My wife is a photographer and well versed in Photoshop. When I get ready to actually paint, that is where we will start. But for now, I have lots of things to do before I start to get ready for the painting stage. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs > > Gardner: > Have you tried putting your bus pic into a pic gallery and painting it there before you actually paint it? > I liked the color of one of the FC's, it was white, blue and red, and my wife hated it, hmmm it is all in the eye of the beholder LOL > > Bill 84 FC 35 SB "$quanderlodge" > Terrace, B.C. Canada > > > > > ----- Original Message ---- > From: Gardner Yeaw > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, December 23, 2006 5:39:37 PM > Subject: [WanderlodgeForum] Re: Hot water and boondocking > > Bill, > I don't know if my previous post made it, I got a bad message, so > here I go again. > > Nice find on the Chilipepper. I may even install one in my house. > I need to install a bypass for the hot water heater in the Bird for > winterization, so it might be a good time to install one of these as > well. > > I had to replace the ice maker module in the U-line, and the > microwave krumped, so I don't think the Chilipepper will be on the > imediate horizon. > > I was thinking I might paint the Bird Visa blue with Red ink trim. > What do you think? > > Gardner > 78FC33 > > --- In WanderlodgeForum@ yahoogroups. com, "Bill" > wrote: > > > > Hi all: > > Back onto this topic. I was doing some browsing of the net, and > > Lucas Willemese (did I spell that right?) had a gizmo in his > coach. > > Well I am not sure if this was the item or not, but it is called > > a "chillipepper" . Just the thing that we should have on our > coaches. > > Look it up and let me know what you think. > > http://www.chilipep perapp.com/ hwcs.htm > > > > Bill > > 84FC35SB > > Terrace, B.C. > > > > > > I began to think about > > > ways > > > > to conserve water to streach the time we could stay. One > thought > > > was > > > > the waste of water waiting for the sink or shower hot water to > > > come > > > > up to temperature. It was cold outside so it took a while, > wasted > > > > water and holding tank capacity. > > > > > > > > In hotels/motels/ large buildings they use a circulating system > > > > that keeps the hot water supply hot so you don't wait for hot > > > water > > > > at the tub or tap. It would seem that this could be done in an > RV > > > by > > > > adding a return line from the far end of the hot water system, > a > > > one- > > > > way valve and a pump. Then all you would need to do is > activate > > > the > > > > pump for a minute or so to charge the system, and then start > the > > > > shower. It would conserve the water supply as well as the grey > > > tank > > > > space. > > > > > > > > Has anyone seen this kind of system in use? > > > > > > > > Gardner > > > > 78FC33 > > > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > > [Non-text portions of this message have been removed] > |
