re-inverters - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: re-inverters (/showthread.php?tid=4126) Pages: 1 2 |
re-inverters - worktohobby - 01-09-2007 13:06 Hi all, On the subject of battery combiners, those marketed today are intelligent and only combine when a charge voltage of say 13 volts or better is present. This works very well. There is no voltage drop like a battery isolator, so if your running an intelligent converter, your genset battery will get an excellant charge. Regards, Don Duncan 1987 PT 40 Beaverton, Oregon --- In WanderlodgeForum@yahoogroups.com, "freewill2008" > > Terry - All you hafta do is wire the dedicated genset cranking > battery in parallel with the rest of the batteries and then mount a > battery isolator between the genset battery and the coach batteries. > This will charge the genset battery along with the coach batteries, > but will keep the genset battery from discharging along with the > coach batteries. > > You can use a regular 3 terminal isolator, except you only use the > center terminal and one end terminal. A garden-variety isolator will > work, but you will get a better charge by using a Schotky isolator > like they use in ambulances. Costs more but ya get what ya pay for. > > Pay attention to the wiring instructions. Hook it up backwards and > you will only discharge the genset battery and never charge it )> > As an alternative, you could use a combiner relay where the isolator > would have gone. This relay connects the genset battery to the > alternator and coach batteries only while the engine is running. The > only problem with this method is if you get into a discharge > situation (alternator or regulator fails) while on the road, then you > will discharge both coach and genset batteries which is what you are > trying to avoid. > > Bob Griesel '84 FC31 WLII WA > > > > --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs > > > > > Terry, I don't understand what you are trying to do. > > Do I have it right, you are going to put a charger on the genset > battery, which is going to be powered from the main battery bank? Is > the genset battery not charged now by the inverters/alternator setup? > > > > Bill 84 FC 35 SB "$quanderlodge" > > Terrace, B.C. Canada > > > > > > > > > > ----- Original Message ---- > > From: Gregory OConnor > > To: WanderlodgeForum@yahoogroups.com > > Sent: Tuesday, January 9, 2007 7:28:41 AM > > Subject: [WanderlodgeForum] Re: re-inverters > > > > Terry, thank you for the info. I cant down load the specs but I > guess > > it is somehow protectes the genset start battery from becomming one > > of the coach inverter bank batteries. The inverter also powers the > > battery charge? this looks like the way to go. You would think the > > genset would have a winding output of 14 volts just for the start > > battery function? > > > > As it turned out with a bench test at a local starter alt rebuilder > > my Genset Kubota starter was drawing way more amps than spec and I > > had it rebuilt for $135.00 (Riverside Alt 951-354-2373) . I ran the > 8 > > 12V deep cycle back to Campingworld and they were clueless as to > how > > to test them. they offered to just replace all 8 with a prorate. I > > paid a battery shop to do the Hydro test and 3 units were found to > > have issue with one battery grounded short. CW replaced the 3 for > me. > > I was alarmed that CW employees could not believe that there is a > > Motorhome with 8 batteries in a bank. I used CW for the origional > > purchase because I knew little about inverters and just assumed > they > > were up on that. > > > > GregoryO'Connor > > 94ptRomolandCa- -- In WanderlodgeForum@ yahoogroups. com, Terry > Neal > > > > > > > > Morning Greg. I'm installing one of these Xantex auxiliary > > chargers in > > > my coach just to keep the gen battery up to full charge. I use an > > > Optima Blue top for the gen set too. I will pull the charger > input > > off > > > of my house battery bank so the gen battery will always be > charged > > > either from my engine alternator, the Heart Inverter or my IOTA > > > chargers. They are on eBay for $50-60. > > > > > > Link is at > > http://www.xantrex. com/web/id/ 103/p/docs/ pt/20/product. asp > > > > > > Terry Neal > > > Bozeman, MT > > > 82PT40 > > > 74FC34 > re-inverters - freewill2008 - 01-09-2007 14:08 Thanks Don. I did not know we could get a combiner with those kind of smarts. I like it - the best possible combination of features. Bob Griesel > > Hi all, > > On the subject of battery combiners, those marketed today are > intelligent and only combine when a charge voltage of say 13 volts or > better is present. This works very well. > > There is no voltage drop like a battery isolator, so if your running > an intelligent converter, your genset battery will get an excellant > charge. > > Regards, > > Don Duncan > 1987 PT 40 > Beaverton, Oregon > > > --- In WanderlodgeForum@yahoogroups.com, "freewill2008" > > > > > Terry - All you hafta do is wire the dedicated genset cranking > > battery in parallel with the rest of the batteries and then mount a > > battery isolator between the genset battery and the coach > batteries. > > This will charge the genset battery along with the coach batteries, > > but will keep the genset battery from discharging along with the > > coach batteries. > > > > You can use a regular 3 terminal isolator, except you only use the > > center terminal and one end terminal. A garden-variety isolator > will > > work, but you will get a better charge by using a Schotky isolator > > like they use in ambulances. Costs more but ya get what ya pay for. > > > > Pay attention to the wiring instructions. Hook it up backwards and > > you will only discharge the genset battery and never charge it )> > > > As an alternative, you could use a combiner relay where the > isolator > > would have gone. This relay connects the genset battery to the > > alternator and coach batteries only while the engine is running. > The > > only problem with this method is if you get into a discharge > > situation (alternator or regulator fails) while on the road, then > you > > will discharge both coach and genset batteries which is what you > are > > trying to avoid. > > > > Bob Griesel '84 FC31 WLII WA > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs > > > > > > > > Terry, I don't understand what you are trying to do. > > > Do I have it right, you are going to put a charger on the genset > > battery, which is going to be powered from the main battery bank? > Is > > the genset battery not charged now by the inverters/alternator > setup? > > > > > > Bill 84 FC 35 SB "$quanderlodge" > > > Terrace, B.C. Canada > > > > > > > > > > > > > > > ----- Original Message ---- > > > From: Gregory OConnor > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Tuesday, January 9, 2007 7:28:41 AM > > > Subject: [WanderlodgeForum] Re: re-inverters > > > > > > Terry, thank you for the info. I cant down load the specs but I > > guess > > > it is somehow protectes the genset start battery from becomming > one > > > of the coach inverter bank batteries. The inverter also powers > the > > > battery charge? this looks like the way to go. You would think > the > > > genset would have a winding output of 14 volts just for the start > > > battery function? > > > > > > As it turned out with a bench test at a local starter alt > rebuilder > > > my Genset Kubota starter was drawing way more amps than spec and > I > > > had it rebuilt for $135.00 (Riverside Alt 951-354-2373) . I ran > the > > 8 > > > 12V deep cycle back to Campingworld and they were clueless as to > > how > > > to test them. they offered to just replace all 8 with a prorate. > I > > > paid a battery shop to do the Hydro test and 3 units were found > to > > > have issue with one battery grounded short. CW replaced the 3 for > > me. > > > I was alarmed that CW employees could not believe that there is a > > > Motorhome with 8 batteries in a bank. I used CW for the origional > > > purchase because I knew little about inverters and just assumed > > they > > > were up on that. > > > > > > GregoryO'Connor > > > 94ptRomolandCa- -- In WanderlodgeForum@ yahoogroups. com, Terry > > Neal > > > > > > > > > > > Morning Greg. I'm installing one of these Xantex auxiliary > > > chargers in > > > > my coach just to keep the gen battery up to full charge. I use > an > > > > Optima Blue top for the gen set too. I will pull the charger > > input > > > off > > > > of my house battery bank so the gen battery will always be > > charged > > > > either from my engine alternator, the Heart Inverter or my IOTA > > > > chargers. They are on eBay for $50-60. > > > > > > > > Link is at > > > http://www.xantrex. com/web/id/ 103/p/docs/ pt/20/product. asp > > > > > > > > Terry Neal > > > > Bozeman, MT > > > > 82PT40 > > > > 74FC34 > > > re-inverters - Wilhelmus Schreurs - 01-11-2007 15:24 Terry: As you read from Bob's message, good suggestions, but if you decide to boondock, and want to make sure that your genset battery has power, add a small to medium size solar panel just to the genset battery, that will keepit topped up, and ready for use. Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada Bill, I had to replace my original Rediline & battery chargers. I installed 2 IOTA chargers for my main battery bank (I have 2 "house" batteries) I am keeping the gen set charging outside the rest of the system. Then my gen set gets charged by the engine alternator, shore power (Chargers) or the generator itself. Still working on what type/size inverter to use in the coach and will probably add a solar panel to the coach too. __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] re-inverters - Stephen Birtles - 01-11-2007 16:14 http://www.xantrex.com/support/howlong.asp Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs > > Terry: > As you read from Bob's message, good suggestions, but if you decide to boondock, and want to make sure that your genset battery has power, add a small to medium size solar panel just to the genset battery, that will keepit topped up, and ready for use. > > Bill 84 FC 35 SB "$quanderlodge" > Terrace, B.C. Canada > > > > > > > > > > > > > > > > > Bill, > > > > I had to replace my original Rediline & battery chargers. I installed 2 > > IOTA chargers for my main battery bank (I have 2 "house" batteries) I > > am keeping the gen set charging outside the rest of the system. Then my > > gen set gets charged by the engine alternator, shore power (Chargers) or > > the generator itself. Still working on what type/size inverter to use > > in the coach and will probably add a solar panel to the coach too. > > > > > > > > > > > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > > [Non-text portions of this message have been removed] > |
