Microphor toilet and variable speed pump - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Microphor toilet and variable speed pump (/showthread.php?tid=4650) Pages: 1 2 |
Microphor toilet and variable speed pump - Stephen Birtles - 04-13-2007 03:31 hey quit rubbing in about being warm Snow flurries here today yuck Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > > Pete Masterson > > '95 Blue Bird Wanderlodge WBDA 42 > > Currently in Amarillo TX -- heading south out of winter's last gasp... > > So Pete,.... are you going to join us in San Antonio at the Lone Star > Birds Rally this weekend? We are definitely south of Amarillo! And warm. > > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > > > > > --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > wrote: > > > > My original post was about _water_ pressure. But the air pressure > > issue is also an excellent point. As it happens, I have a Microphor > > 12v compressor that's independent from the coach air system. It's > > limited to 90 psi. I plan to move my dump valves over to the > > Microphor compressor when time allows as it will eliminate needing to > > 'air up' to dump. > > > > I notice that the air-dump valves seem to work ok with about 70 psi > > but are a little sluggish with less -- but I was in a very cold place > > when I was taking note of the pressures (I'd pumped up the coach with > > an external compressor since it wasn't worth the difficulty in > > starting the engine in 25 degree weather...) > > > > Pete Masterson > > '95 Blue Bird Wanderlodge WBDA 42 > > Currently in Amarillo TX -- heading south out of winter's last gasp... > > aeonix1@ > > > > > > > > On Apr 12, 2007, at 11:29 AM, Richard Hayden wrote: > > > > > Along with air regulators for the Microphor we all should put them > > > on the air line to the dump valves. According to Randy it would > > > extend the valves life by not pushing so hard when running with the > > > air pressure is over 100 lbs. Just another project I haven't > > > gotten around too yet. > > > > > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > > > > > ----- Original Message ----- > > > From: Pete Masterson > > > To: > > > WanderlodgeForum@yahoogroups.com > > > Sent: Wednesday, April 11, 2007 7:37 PM > > > Subject: Re: [WanderlodgeForum] Microphor toilet and variable > > > speed pump > > > > > > > > > Yes, I have the air-operated Microphor (with a small 12v compressor > > > in the basement compartment nearby). It would be worthwhile to check > > > the Microphor website for the installation/troubleshooting manual > > > for > > > your model. > > <snip> > > > Microphor toilet and variable speed pump - mbulriss - 04-13-2007 04:02 --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > hey quit rubbing in about being warm > Snow flurries here today yuck > Stephen 77fc35 Sorry Stephen, but it was only 72 degrees here at 8am. My wife is talking to her Mom in upstate NY who is reporting 6 inches of wet snow right now, so you could be worse. There's a reason we don't live there anymore. Mike Bulriss - really leaving for the LSB rally now 1991 WB40 "Texas Minivan" San Antonio, TX > > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> wrote: > > > > > Pete Masterson > > > '95 Blue Bird Wanderlodge WBDA 42 > > > Currently in Amarillo TX -- heading south out of winter's last gasp... > > > > So Pete,.... are you going to join us in San Antonio at the Lone Star > > Birds Rally this weekend? We are definitely south of Amarillo! And > warm. > > > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > > wrote: > > > > > > My original post was about _water_ pressure. But the air pressure > > > issue is also an excellent point. As it happens, I have a Microphor > > > 12v compressor that's independent from the coach air system. It's > > > limited to 90 psi. I plan to move my dump valves over to the > > > Microphor compressor when time allows as it will eliminate needing > to > > > 'air up' to dump. > > > > > > I notice that the air-dump valves seem to work ok with about 70 psi > > > but are a little sluggish with less -- but I was in a very cold > place > > > when I was taking note of the pressures (I'd pumped up the coach > with > > > an external compressor since it wasn't worth the difficulty in > > > starting the engine in 25 degree weather...) > > > > > > Pete Masterson > > > '95 Blue Bird Wanderlodge WBDA 42 > > > Currently in Amarillo TX -- heading south out of winter's last gasp... > > > aeonix1@ > > > > > > > > > > > > On Apr 12, 2007, at 11:29 AM, Richard Hayden wrote: > > > > > > > Along with air regulators for the Microphor we all should put them > > > > on the air line to the dump valves. According to Randy it would > > > > extend the valves life by not pushing so hard when running with > the > > > > air pressure is over 100 lbs. Just another project I haven't > > > > gotten around too yet. > > > > > > > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > > > > > > > ----- Original Message ----- > > > > From: Pete Masterson > > > > To: > > > > WanderlodgeForum@yahoogroups.com > > > > Sent: Wednesday, April 11, 2007 7:37 PM > > > > Subject: Re: [WanderlodgeForum] Microphor toilet and variable > > > > speed pump > > > > > > > > > > > > Yes, I have the air-operated Microphor (with a small 12v > compressor > > > > in the basement compartment nearby). It would be worthwhile to > check > > > > the Microphor website for the installation/troubleshooting > manual > > > > for > > > > your model. > > > <snip> > > > > > > Microphor toilet and variable speed pump - Pete Masterson - 04-13-2007 06:34 Mike, I didn't expect to be this far south so soon... We planned to stay in Golden for a couple of weeks... but the weather didn't cooperate. We'll be staying near Brady, TX tonight ... I guess we could "make" San Antonio on Saturday. (We were actually heading for Austin where my wife has an event later in the month ... we were just going to 'hang out' there until here deal...) Since we weren't planning to be this far south this soon, I didn't note the details of your get together... Could you send 'em to me? Wife is "interested" but we wouldn't arrive before until mid-day on Saturday.... If you don't want to send the info to the list again, send it directly to aeonix1@.... Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 Just outside Abilene Tx -- where the weather is _warm_... aeonix1@... On Apr 13, 2007, at 10:13 AM, mbulriss wrote: >> Pete Masterson >> '95 Blue Bird Wanderlodge WBDA 42 >> Currently in Amarillo TX -- heading south out of winter's last >> gasp... > > So Pete,.... are you going to join us in San Antonio at the Lone Star > Birds Rally this weekend? We are definitely south of Amarillo! > And warm. > > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > > Microphor toilet and variable speed pump - Travis Martin - 04-13-2007 08:00 Please; send it to the list again. I'm in Lubbock and toying with the idea of going... Travis On Apr 13, 2007, at 1:34 PM, Pete Masterson wrote: > > If you don't want to send the info to the list again, send it > directly to aeonix1@.... |
