Safe Combo - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Safe Combo (/showthread.php?tid=508) Pages: 1 2 |
Safe Combo - Al here - 05-06-2005 02:25 Thanks for all the help guys! I was informed last night by a member that the numbers I found were probably mt coach #'s, not a safe combo. Since I'm on the road now, I don't think I'll remove it or have it drilled so it will have to sit there and just look cool for now. Thanks for all the advice! Al _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Kurt Achenbach Sent: Friday, May 06, 2005 7:15 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Safe Combo Hello Al, Just had my Safe serviced and reset. The Combination is (usualy) Left 4 turns to # ? Right 3 turns to # ? left 2 turns to # ? Right 1 turn to STOP Kurt 83FC35SB in NH --- In WanderlodgeForum@yahoogroups.com, "Al here" > I tried the message archieve but it wouldn't work for me, so I thought I > would try you guys. > > > > My safe combo has been changed from the original factory setting as per 2 > different locksmiths. They would have drilled it but since I assume it's > > empty and there are no replacement parts, I didn't see the point in ruining > a great safe. I was going to hid a new one somewhere until I found these > > #'s under the couch seats covering the safe (shhhh, don't tell anyone). > > > > 50 452 > > > > Not really having used dial safes in the past I don't know the proper order > of spins and what direction to start turning. Anyone have any advice? > > > > Al S. > > 1981 31' FC > > > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of sfedeli3 > Sent: Thursday, May 05, 2005 5:37 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Headlight switch > > > > Hi Sid, > > I just replaced mine with one from Blue Bird. Was around $100 or > so... like everything else. Brand was "ohmite". Was pretty easy to > get to. New one works beautifully. Could not find a match at any > auto parts stores, but did not try a "good" NAPA (the one here in > Hershey is pretty sad) I can walk you throught the removal and > installation if needed. > > Shane Fedeli > 85PT40 > Hershey, PA > > --- In WanderlodgeForum@yahoogroups.com, "Sidney Breese" > <ssbreese@a...> wrote: > > Well, I think my switch has bit the dust. Some time ago I wrote > that > > the switch did not work in the parking position, but the headlight > > came on, but the tail lights didn't. Someone suggested WD40 and > that > > worked for a while. Doesn't work this time. I have headlights, > but > > no marker or tailights. Does anyone know the brand or model of the > > switch. I went to a couple of parts stores and the said I needed > to > > bring the old one in and they would match it. Everything is > working > > fine and I am not thinking of night driving, so I hate to take the > > dash apart to get at the switch. Hoping someone has a model > number. > > thanks. > > Sid Breese > > 85PT40 > > St. Joseph, MO > > > > > > _____ > > Yahoo! Groups Links > > * To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! > <http://docs.yahoo.com/info/terms/> Terms of Service. > > > > [Non-text portions of this message have been removed] _____ Yahoo! Groups Links * To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. [Non-text portions of this message have been removed] Safe Combo - Mark Garber - 05-06-2005 02:33 my first thought would be to try it as 50 4 52, then maybe 50 45 2, or 50 45 20 good luck Mark 80FC35 PA for awhile pattypape Hi AL, My Safe needs six numbers in the combination to open. You may be missing a digit. Example is; 25 35 45 Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "Al here" > I tried the message archieve but it wouldn't work for me, so I thought I > would try you guys. > > > > My safe combo has been changed from the original factory setting as per 2 > different locksmiths. They would have drilled it but since I assume it's > > empty and there are no replacement parts, I didn't see the point in ruining > a great safe. I was going to hid a new one somewhere until I found these > > #'s under the couch seats covering the safe (shhhh, don't tell anyone). > > > > 50 452 > > > > Not really having used dial safes in the past I don't know the proper order > of spins and what direction to start turning. Anyone have any advice? > > > > Al S. > > 1981 31' FC > > > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of sfedeli3 > Sent: Thursday, May 05, 2005 5:37 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Headlight switch > > > > Hi Sid, > > I just replaced mine with one from Blue Bird. Was around $100 or > so... like everything else. Brand was "ohmite". Was pretty easy to > get to. New one works beautifully. Could not find a match at any > auto parts stores, but did not try a "good" NAPA (the one here in > Hershey is pretty sad) I can walk you throught the removal and > installation if needed. > > Shane Fedeli > 85PT40 > Hershey, PA > > --- In WanderlodgeForum@yahoogroups.com, "Sidney Breese" > <ssbreese@a...> wrote: > > Well, I think my switch has bit the dust. Some time ago I wrote > that > > the switch did not work in the parking position, but the headlight > > came on, but the tail lights didn't. Someone suggested WD40 and > that > > worked for a while. Doesn't work this time. I have headlights, > but > > no marker or tailights. Does anyone know the brand or model of the > > switch. I went to a couple of parts stores and the said I needed > to > > bring the old one in and they would match it. Everything is > working > > fine and I am not thinking of night driving, so I hate to take the > > dash apart to get at the switch. Hoping someone has a model > number. > > thanks. > > Sid Breese > > 85PT40 > > St. Joseph, MO > > > > > > _____ > > Yahoo! Groups Links > > * To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! > <http://docs.yahoo.com/info/terms/> Terms of Service. > > > > [Non-text portions of this message have been removed] --------------------------------- Yahoo! Groups Links To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- Yahoo! Mail Stay connected, organized, and protected. Take the tour [Non-text portions of this message have been removed] Safe Combo - pattypape - 05-06-2005 10:05 Opps! Sorry Hank, that you received a copy of my response. I was responding to the subject: Safe Combo. See attached postings, I think Al got the message. Bill 88FC Michigan --- In WanderlodgeForum@yahoogroups.com, hank robb wrote: > I'M NOT AL. CHECK YOUR SEND ADDRESS. HATE TO SEE AL > MISS A MESSAAGE. > SINCERELY, > HANK HANNIGAN > 90SP36 > SYDNEY AUSTRALIA FOR NOW > --- pattypape > > Hi AL, > > > > My Safe needs six numbers in the combination to > > open. > > You may be missing a digit. > > > > Example is; 25 35 45 > > > > Bill 88 FC > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Al here" > > > > > I tried the message archieve but it wouldn't work > > for me, so I > > thought I > > > would try you guys. > > > > > > > > > > > > My safe combo has been changed from the original > > factory setting as > > per 2 > > > different locksmiths. They would have drilled it > > but since I assume > > it's > > > > > > empty and there are no replacement parts, I didn't > > see the point in > > ruining > > > a great safe. I was going to hid a new one > > somewhere until I found > > these > > > > > > #'s under the couch seats covering the safe > > (shhhh, don't tell > > anyone). > > > > > > > > > > > > 50 452 > > > > > > > > > > > > Not really having used dial safes in the past I > > don't know the > > proper order > > > of spins and what direction to start turning. > > Anyone have any > > advice? > > > > > > > > > > > > Al S. > > > > > > 1981 31' FC > > > > > > > > > > > > _____ > > > > > > From: WanderlodgeForum@yahoogroups.com > > > [mailto:WanderlodgeForum@yahoogroups.com] On > > Behalf Of sfedeli3 > > > Sent: Thursday, May 05, 2005 5:37 PM > > > To: WanderlodgeForum@yahoogroups.com > > > Subject: [WanderlodgeForum] Re: Headlight switch > > > > > > > > > > > > Hi Sid, > > > > > > I just replaced mine with one from Blue Bird. > > Was around $100 or > > > so... like everything else. Brand was "ohmite". > > Was pretty easy to > > > get to. New one works beautifully. Could not find > > a match at any > > > auto parts stores, but did not try a "good" NAPA > > (the one here in > > > Hershey is pretty sad) I can walk you throught the > > removal and > > > installation if needed. > > > > > > Shane Fedeli > > > 85PT40 > > > Hershey, PA > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Sidney > > Breese" > > > <ssbreese@a...> wrote: > > > > Well, I think my switch has bit the dust. Some > > time ago I wrote > > > that > > > > the switch did not work in the parking position, > > but the headlight > > > > came on, but the tail lights didn't. Someone > > suggested WD40 and > > > that > > > > worked for a while. Doesn't work this time. I > > have headlights, > > > but > > > > no marker or tailights. Does anyone know the > > brand or model of > > the > > > > switch. I went to a couple of parts stores and > > the said I needed > > > to > > > > bring the old one in and they would match it. > > Everything is > > > working > > > > fine and I am not thinking of night driving, so > > I hate to take the > > > > dash apart to get at the switch. Hoping someone > > has a model > > > number. > > > > thanks. > > > > Sid Breese > > > > 85PT40 > > > > St. Joseph, MO > > > > > > > > > > > > > > > > > > _____ > > > > > > Yahoo! Groups Links > > > > > > * To visit your group on the web, go to: > > > http://groups.yahoo.com/group/WanderlodgeForum/ > > > > > > * To unsubscribe from this group, send an email > > to: > > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > > > > > > > * Your use of Yahoo! Groups is subject to the > > Yahoo! > > > <http://docs.yahoo.com/info/terms/> Terms of > > Service. > > > > > > > > > > > > [Non-text portions of this message have been > > removed] > > > > > > > > > > __________________________________ > Do you Yahoo!? > Read only the mail you want - Yahoo! Mail SpamGuard. > http://promotions.yahoo.com/new_mail Safe Combo - dwalks@... - 05-07-2005 10:09 why didn't you have the locksmith come to the BB???????? [Non-text portions of this message have been removed] Safe Combo - Al here - 05-07-2005 15:18 I did, two of them. The combo has been changed and there are no replacement parts. So when they drilled the safe, it would have been destroyed. I think it was Jeff that pointed out they could drill it from the side so it can still be used. Didn't know that when they came by. Al S. _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of dwalks@... Sent: Saturday, May 07, 2005 7:09 PM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Re: Safe Combo why didn't you have the locksmith come to the BB???????? [Non-text portions of this message have been removed] _____ Yahoo! Groups Links * To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! Terms <http://docs.yahoo.com/info/terms/> of Service. [Non-text portions of this message have been removed] |
