Michelin Tires not available - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Michelin Tires not available (/showthread.php?tid=5648) Pages: 1 2 |
Michelin Tires not available - DONALD BROWN - 10-09-2007 02:11 We ordered 8 new 12R22.5 BF Goodrich tires with late 2007 DOT dates and are still waiting, perhaps the same situation. They are $459 per tire mounted with spin balance and tire disposal. Donald & Mary Anne, LX-40 Palmetto, Florida rogerwwebb WanderlodgeForum@yahoogroups.com, rogerwwebb@... wrote: I had responded to this subject on September 12 that I had the Michelin 12Rx22.5 tires on order. At that time I was told they were out of stock and a new production run scheduled for late September. I am now told the production run is `November'. My local dealer is a bit frustrated too, as he has a large order of over 100 tires for a bus company that is also waiting. He said this has happened before for this size, but could offer no other solution than using another brand or waiting. FWIW. Roger Webb 91 WL Cedar Rapids, IA > > > ************************************** See what's new at http://www.aol.com > > > [Non-text portions of this message have been removed] > --------------------------------- Be a better Globetrotter. Get better travel answers from someone who knows. Yahoo! Answers - Check it out. [Non-text portions of this message have been removed] Michelin Tires not available - David Heibult - 10-09-2007 03:21 Roger; I just priced 2 Michelins at Partner Tire ,Villa Ridge Mo. just outside St. Louis, Mo. he had two in stock, Call Pat at 636-742-4424 or his cell at 314-606-8743 David 91 WBWL,40 To: WanderlodgeForum@...: rvdependent@...: Tue, 9 Oct 2007 07:11:37 -0700Subject: Re: [WanderlodgeForum] Re: Michelin Tires not available We ordered 8 new 12R22.5 BF Goodrich tires with late 2007 DOT dates and are still waiting, perhaps the same situation. They are $459 per tire mounted with spin balance and tire disposal.Donald & Mary Anne, LX-40 Palmetto, Floridarogerwwebb WanderlodgeForum@yahoogroups.com, rogerwwebb@... wrote:I had responded to this subject on September 12 that I had the Michelin 12Rx22.5 tires on order. At that time I was told they were out of stock and a new production run scheduled for late September. I am now told the production run is `November'. My local dealer is a bit frustrated too, as he has a large order of over 100 tires for a bus company that is also waiting. He said this has happened before for this size, but could offer no other solution than using another brand or waiting. FWIW.Roger Webb91 WLCedar Rapids, IA > > > ************************************** See what's new at http://www.aol.com> > > [Non-text portions of this message have been removed]>---------------------------------Be a better Globetrotter. Get better travel answers from someone who knows.Yahoo! Answers - Check it out.[Non-text portions of this message have been removed] [Non-text portions of this message have been removed] Michelin Tires not available - bubblerboy64 - 10-09-2007 23:48 You guys have me really confused about these Michelin tires. Which I might add is not all that hard to do. What do the numbers 12R and 11R mean. I am right now in the process of getting Michelin tires for my FC. They are back ordered with an expected delivery in a week or two(?). But we all know what that means. Now my problem is I have left the details up to the dealer as per which tire to use. I believe they are XZE tires but not certain. What do I need for this FC? Give me some details and more information so I can make certain I end up with what I need. If I see a problem with Mich. then I am going to go with the Bridgestone tires which can be had. Please expand on this so I know at least what questions I need to ask of the dealer. My coach is a 1973 FC converted to diesel. John Heckman > > I just purchased 4, 12R,22.5, 16 ply, Ohtsu tires from Schwab in Anacortes > Wa. They had them in stock for $346.00 mounted and balanced with Equal. Jim > Barone, 1991 WL currently in Tubac Arizona > > > > ************************************** See what's new at http://www.aol.com > > > [Non-text portions of this message have been removed] > Michelin Tires not available - Gregory OConnor - 10-10-2007 01:24 Tires are Tires and good for 8 years give or take a year and a blowout. there is no problem going with 11r's if the weights on all the axles does not exceed the limits on the tire stamp. most tractor trailers use 11r's. 12r are mostly used on transit buses. they are taller and wider then the 11r's. an 18 wheeler with 80,000 lbs and simple math leaves each tire responsible for 4,400. a bus with 6 wheels and 35,000 lbs leaves each tire responsible for 5,800 lbs. 12r's are more than a size they are a class designed for the transport of people. (best math devides heavyest axle by number of tires per that axle to find need) Retreads are perfected now adays and I would not hesitate to use them. Transit busses use them but they run the tread off the tires in a year and the casings are good for another tread life. the casing used to make the retread needs to be new and if you do not have one to give the retreader, you need to add core to the cost of purchase. then you have an old tire casing with a new tread, thus a limited to 8 year of casing age to use the new tread. One way to do it is to GO for the 12r's, put 2 new 12's out front and 4 retreads in the rear (if the savings warrents use) and rotate new steers into the mix every two and 1/2 years. that way you are always steering new rubber. GregoryO'Connor 94ptRomolandCa In WanderlodgeForum@yahoogroups.com, "bubblerboy64" wrote: > > You guys have me really confused about these Michelin tires. Which I > might add is not all that hard to do. What do the numbers 12R and > 11R mean. I am right now in the process of getting Michelin tires > for my FC. They are back ordered with an expected delivery in a week > or two(?). But we all know what that means. Now my problem is I have > left the details up to the dealer as per which tire to use. I > believe they are XZE tires but not certain. What do I need for this > FC? Give me some details and more information so I can make certain > I end up with what I need. If I see a problem with Mich. then I am > going to go with the Bridgestone tires which can be had. Please > expand on this so I know at least what questions I need to ask of the > dealer. My coach is a 1973 FC converted to diesel. John Heckman > > > > I just purchased 4, 12R,22.5, 16 ply, Ohtsu tires from Schwab in > Anacortes > > Wa. They had them in stock for $346.00 mounted and balanced with > Equal. Jim > > Barone, 1991 WL currently in Tubac Arizona > > > > > > > > ************************************** See what's new at > http://www.aol.com > > > > > > [Non-text portions of this message have been removed] > > > Michelin Tires not available - Pete Masterson - 10-10-2007 04:15 11 R is an 11 inch wide tire and 12 R is a 12 inch wide tire. The "R" means it's a radial design (bias ply tires aren't made anymore so far as I know). The 12 inch tire has higher weight capacity and is used on an 8" or wider wheel. The 11 inch tire is used on wheels less than 8" wide. You need to check your wheels to see what width they are. The older birds tend to use the 11R tires while the newer ones use 12R. I think the earlier birds have 7 or 7-1/2 inch wide wheels, so the 11R is the tire to use on your 73 bird. Tires are one of those things that generate much emotion -- I'm running on Toyo tires and they seem quite satisfactory. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Kolob Canyon, Zion NP On Oct 10, 2007, at 5:48 AM, bubblerboy64 wrote: > You guys have me really confused about these Michelin tires. Which I > might add is not all that hard to do. What do the numbers 12R and > 11R mean. I am right now in the process of getting Michelin tires > for my FC. They are back ordered with an expected delivery in a week > or two(?). But we all know what that means. Now my problem is I have > left the details up to the dealer as per which tire to use. I > believe they are XZE tires but not certain. What do I need for this > FC? Give me some details and more information so I can make certain > I end up with what I need. If I see a problem with Mich. then I am > going to go with the Bridgestone tires which can be had. Please > expand on this so I know at least what questions I need to ask of the > dealer. My coach is a 1973 FC converted to diesel. John Heckman >> >> I just purchased 4, 12R,22.5, 16 ply, Ohtsu tires from Schwab in > Anacortes >> Wa. They had them in stock for $346.00 mounted and balanced with > Equal. Jim >> Barone, 1991 WL currently in Tubac Arizona [Non-text portions of this message have been removed] Michelin Tires not available - bubblerboy64 - 10-10-2007 04:59 Ok that is helpful. I am changing wheels at this time too. The new ones will be 8.25 inches wide so as long as the tires match and things fit up under the coach I should be good to go???? John Heckman central Pa 1973 FC > > 11 R is an 11 inch wide tire and 12 R is a 12 inch wide tire. The "R" > means it's a radial design (bias ply tires aren't made anymore so far > as I know). The 12 inch tire has higher weight capacity and is used > on an 8" or wider wheel. The 11 inch tire is used on wheels less than > 8" wide. > > You need to check your wheels to see what width they are. The older > birds tend to use the 11R tires while the newer ones use 12R. I think > the earlier birds have 7 or 7-1/2 inch wide wheels, so the 11R is the > tire to use on your 73 bird. > > Tires are one of those things that generate much emotion -- I'm > running on Toyo tires and they seem quite satisfactory. > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > aeonix1@... > On the road at Kolob Canyon, Zion NP > > > > On Oct 10, 2007, at 5:48 AM, bubblerboy64 wrote: > > > You guys have me really confused about these Michelin tires. Which I > > might add is not all that hard to do. What do the numbers 12R and > > 11R mean. I am right now in the process of getting Michelin tires > > for my FC. They are back ordered with an expected delivery in a week > > or two(?). But we all know what that means. Now my problem is I have > > left the details up to the dealer as per which tire to use. I > > believe they are XZE tires but not certain. What do I need for this > > FC? Give me some details and more information so I can make certain > > I end up with what I need. If I see a problem with Mich. then I am > > going to go with the Bridgestone tires which can be had. Please > > expand on this so I know at least what questions I need to ask of the > > dealer. My coach is a 1973 FC converted to diesel. John Heckman > >> > >> I just purchased 4, 12R,22.5, 16 ply, Ohtsu tires from Schwab in > > Anacortes > >> Wa. They had them in stock for $346.00 mounted and balanced with > > Equal. Jim > >> Barone, 1991 WL currently in Tubac Arizona > > > > [Non-text portions of this message have been removed] > Michelin Tires not available - Pete Masterson - 10-10-2007 13:56 Yes, that ought to do it. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Green River UT in an overpriced KOA... On Oct 10, 2007, at 10:59 AM, bubblerboy64 wrote: > Ok that is helpful. I am changing wheels at this time too. The new > ones will be 8.25 inches wide so as long as the tires match and > things fit up under the coach I should be good to go???? > > John Heckman > central Pa > 1973 FC >> >> 11 R is an 11 inch wide tire and 12 R is a 12 inch wide tire. > The "R" >> means it's a radial design (bias ply tires aren't made anymore so > far >> as I know). The 12 inch tire has higher weight capacity and is > used >> on an 8" or wider wheel. The 11 inch tire is used on wheels less > than >> 8" wide. >> >> You need to check your wheels to see what width they are. The > older >> birds tend to use the 11R tires while the newer ones use 12R. I > think >> the earlier birds have 7 or 7-1/2 inch wide wheels, so the 11R is > the >> tire to use on your 73 bird. >> >> Tires are one of those things that generate much emotion -- I'm >> running on Toyo tires and they seem quite satisfactory. >> >> Pete Masterson >> '95 Blue Bird Wanderlodge WBDA 42 >> aeonix1@... >> On the road at Kolob Canyon, Zion NP >> >> >> >> On Oct 10, 2007, at 5:48 AM, bubblerboy64 wrote: >> >>> You guys have me really confused about these Michelin tires. > Which I >>> might add is not all that hard to do. What do the numbers 12R and >>> 11R mean. I am right now in the process of getting Michelin tires >>> for my FC. They are back ordered with an expected delivery in a > week >>> or two(?). But we all know what that means. Now my problem is I > have >>> left the details up to the dealer as per which tire to use. I >>> believe they are XZE tires but not certain. What do I need for > this >>> FC? Give me some details and more information so I can make > certain >>> I end up with what I need. If I see a problem with Mich. then I > am >>> going to go with the Bridgestone tires which can be had. Please >>> expand on this so I know at least what questions I need to ask of > the >>> dealer. My coach is a 1973 FC converted to diesel. John Heckman >>>> >>>> I just purchased 4, 12R,22.5, 16 ply, Ohtsu tires from Schwab in >>> Anacortes >>>> Wa. They had them in stock for $346.00 mounted and balanced with >>> Equal. Jim >>>> Barone, 1991 WL currently in Tubac Arizona >> >> >> >> [Non-text portions of this message have been removed] >> > > > > > > Yahoo! Groups Links > > > [Non-text portions of this message have been removed] Michelin Tires not available - whistles_n_bells - 10-10-2007 18:11 Pete: If you are doing breakfast/lunch/dinner at a restaurant, I highly recommend the Tamarisk (Best Western River Terrace) on the east side of the river south side of highway - directly across from the John Wesley Powell River Museum. Great food and great service. We use this restaurant on the Elderhostel tours of the National Parks in Utah. Are you heading for Canyonlands and Arches? Regards, Joe (Pappy) Hagan St. George, UT Wannabe --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > Yes, that ought to do it. > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > aeonix1@... > On the road at Green River UT in an overpriced KOA... > > > > On Oct 10, 2007, at 10:59 AM, bubblerboy64 wrote: > > > Ok that is helpful. I am changing wheels at this time too. The new > > ones will be 8.25 inches wide so as long as the tires match and > > things fit up under the coach I should be good to go???? > > > > John Heckman > > central Pa > > 1973 FC > >> > >> 11 R is an 11 inch wide tire and 12 R is a 12 inch wide tire. > > The "R" > >> means it's a radial design (bias ply tires aren't made anymore so > > far > >> as I know). The 12 inch tire has higher weight capacity and is > > used > >> on an 8" or wider wheel. The 11 inch tire is used on wheels less > > than > >> 8" wide. > >> > >> You need to check your wheels to see what width they are. The > > older > >> birds tend to use the 11R tires while the newer ones use 12R. I > > think > >> the earlier birds have 7 or 7-1/2 inch wide wheels, so the 11R is > > the > >> tire to use on your 73 bird. > >> > >> Tires are one of those things that generate much emotion -- I'm > >> running on Toyo tires and they seem quite satisfactory. > >> > >> Pete Masterson > >> '95 Blue Bird Wanderlodge WBDA 42 > >> aeonix1@ > >> On the road at Kolob Canyon, Zion NP > >> > >> > >> > >> On Oct 10, 2007, at 5:48 AM, bubblerboy64 wrote: > >> > >>> You guys have me really confused about these Michelin tires. > > Which I > >>> might add is not all that hard to do. What do the numbers 12R and > >>> 11R mean. I am right now in the process of getting Michelin tires > >>> for my FC. They are back ordered with an expected delivery in a > > week > >>> or two(?). But we all know what that means. Now my problem is I > > have > >>> left the details up to the dealer as per which tire to use. I > >>> believe they are XZE tires but not certain. What do I need for > > this > >>> FC? Give me some details and more information so I can make > > certain > >>> I end up with what I need. If I see a problem with Mich. then I > > am > >>> going to go with the Bridgestone tires which can be had. Please > >>> expand on this so I know at least what questions I need to ask of > > the > >>> dealer. My coach is a 1973 FC converted to diesel. John Heckman > >>>> > >>>> I just purchased 4, 12R,22.5, 16 ply, Ohtsu tires from Schwab in > >>> Anacortes > >>>> Wa. They had them in stock for $346.00 mounted and balanced with > >>> Equal. Jim > >>>> Barone, 1991 WL currently in Tubac Arizona > >> > >> > >> > >> [Non-text portions of this message have been removed] > >> > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > [Non-text portions of this message have been removed] > |
