Power Steering Problems - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Power Steering Problems (/showthread.php?tid=6132) Pages: 1 2 |
Power Steering Problems - Scott Forman - 12-22-2007 10:28 Let me throw this out... My 82 FC had pretty much the same symptoms you describe for the two years I owned it. I, too, had read the posts here about it, and was just "enduring" it waiting for the whole thing to crap out so I would be forced to address it. Just before I sold it, I was driving and lost all PS suddenly. I figured that I would finally need a new pump on its way out the door. Upon investigation, I found that I had thrown off the ps belt, so I figured that I would just replace the belt first on the outside chance that it would return to "normal". What I found was that replacing the belt sovled a huge amount of the original problems. The effort was lower, the strange sounds stopped, the kickback stopped, it was better than it had even been. I guess the old belt was either too loose or too worn to turn the pump effectively. You may want to replace your belt before you do anything else. Scott Forman 86 PT38 Memphis --- In WanderlodgeForum@yahoogroups.com, "ridgemede310" wrote: > > I'm having a problem with the power steering on my '83 FC-35, and > after looking through the archives I'm afraid I probably know what the > answer is, but being a "new" BB owner; just wanted the experts to > confirm my suspicions of needing a new or rebuilt PS pump. > > The problem I'm having is that I can only turn the wheel less then a > 1/4 turn when the coach is stationary. Beyond that point, the wheel > stiffens up, accompanied by some loud squealing and growling. When > moving, it seems to work ok, but at low speeds (such as when parking > in a tight spot) it doesn't want to turn more then a 1/4 turn of the > wheel. When I took a test drive prior to purchasing it, all worked > fine during the brief trip. Now however, it's a different story. I > was able to back the coach into it's storage spot by making what > seemed like a 30-point turn, but I need to move it to a different > location soon and I'm at somewhat of a loss as to what I'm up against > in terms of the repair. Considering the time of year & weather, I'd > like to get a mobile mechanic out to look at it if I can, but not sure > I'd have much luck with that. How involved of a R&R job is this? > > Graham > Baltimore, MD > 83 FC-35 > Power Steering Problems - Andy Coleman - 12-22-2007 12:51 I installed a new PS pump in my 83' FC-35, and replaced my reservoir with a new vented one built by Babb Steering. I replaced the belts and changed the fluid. The front wheels still do not like to turn when stationary. When I turn the wheel all the way, mine does not squeel - the steering wheel actually shakes. It turns better at slow speed, but that is hard to do in a tight area. I too live in a house with limited back yard space to turn my bird around. It is time consuming. I was very surprized (still am) about the poor turning characteristics of the FC-35. I have a 35' rear engine thomas bus, and it turns much tighter. If anybody finds a way to improve upon this, please let us know! Good luck Graham! Andy Coleman 83' FC-35 Spring Lake Hts., NJ --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Let me throw this out... > > My 82 FC had pretty much the same symptoms you describe for the two > years I owned it. I, too, had read the posts here about it, and was > just "enduring" it waiting for the whole thing to crap out so I would > be forced to address it. > > Just before I sold it, I was driving and lost all PS suddenly. I > figured that I would finally need a new pump on its way out the > door. Upon investigation, I found that I had thrown off the ps belt, > so I figured that I would just replace the belt first on the outside > chance that it would return to "normal". > > What I found was that replacing the belt sovled a huge amount of the > original problems. The effort was lower, the strange sounds stopped, > the kickback stopped, it was better than it had even been. I guess > the old belt was either too loose or too worn to turn the pump > effectively. > > You may want to replace your belt before you do anything else. > > Scott Forman > 86 PT38 > Memphis > > --- In WanderlodgeForum@yahoogroups.com, "ridgemede310" > wrote: > > > > I'm having a problem with the power steering on my '83 FC-35, and > > after looking through the archives I'm afraid I probably know what > the > > answer is, but being a "new" BB owner; just wanted the experts to > > confirm my suspicions of needing a new or rebuilt PS pump. > > > > The problem I'm having is that I can only turn the wheel less then a > > 1/4 turn when the coach is stationary. Beyond that point, the wheel > > stiffens up, accompanied by some loud squealing and growling. When > > moving, it seems to work ok, but at low speeds (such as when parking > > in a tight spot) it doesn't want to turn more then a 1/4 turn of the > > wheel. When I took a test drive prior to purchasing it, all worked > > fine during the brief trip. Now however, it's a different story. I > > was able to back the coach into it's storage spot by making what > > seemed like a 30-point turn, but I need to move it to a different > > location soon and I'm at somewhat of a loss as to what I'm up > against > > in terms of the repair. Considering the time of year & weather, I'd > > like to get a mobile mechanic out to look at it if I can, but not > sure > > I'd have much luck with that. How involved of a R&R job is this? > > > > Graham > > Baltimore, MD > > 83 FC-35 > > > Power Steering Problems - Mike Hohnstein - 12-22-2007 13:13 Ya didn't get all the air out. Rule of thumb, with the front tires off the ground, a dozen lock to lock cycles with the engine off. Start the engine and at low idle do another dozen lock to lock cycles. MH ----- Original Message ----- From: Andy Coleman To: WanderlodgeForum@yahoogroups.com Sent: Saturday, December 22, 2007 6:51 PM Subject: [WanderlodgeForum] Re: Power Steering Problems I installed a new PS pump in my 83' FC-35, and replaced my reservoir with a new vented one built by Babb Steering. I replaced the belts and changed the fluid. The front wheels still do not like to turn when stationary. When I turn the wheel all the way, mine does not squeel - the steering wheel actually shakes. It turns better at slow speed, but that is hard to do in a tight area. I too live in a house with limited back yard space to turn my bird around. It is time consuming. I was very surprized (still am) about the poor turning characteristics of the FC-35. I have a 35' rear engine thomas bus, and it turns much tighter. If anybody finds a way to improve upon this, please let us know! Good luck Graham! Andy Coleman 83' FC-35 Spring Lake Hts., NJ --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Let me throw this out... > > My 82 FC had pretty much the same symptoms you describe for the two > years I owned it. I, too, had read the posts here about it, and was > just "enduring" it waiting for the whole thing to crap out so I would > be forced to address it. > > Just before I sold it, I was driving and lost all PS suddenly. I > figured that I would finally need a new pump on its way out the > door. Upon investigation, I found that I had thrown off the ps belt, > so I figured that I would just replace the belt first on the outside > chance that it would return to "normal". > > What I found was that replacing the belt sovled a huge amount of the > original problems. The effort was lower, the strange sounds stopped, > the kickback stopped, it was better than it had even been. I guess > the old belt was either too loose or too worn to turn the pump > effectively. > > You may want to replace your belt before you do anything else. > > Scott Forman > 86 PT38 > Memphis > > --- In WanderlodgeForum@yahoogroups.com, "ridgemede310" > wrote: > > > > I'm having a problem with the power steering on my '83 FC-35, and > > after looking through the archives I'm afraid I probably know what > the > > answer is, but being a "new" BB owner; just wanted the experts to > > confirm my suspicions of needing a new or rebuilt PS pump. > > > > The problem I'm having is that I can only turn the wheel less then a > > 1/4 turn when the coach is stationary. Beyond that point, the wheel > > stiffens up, accompanied by some loud squealing and growling. When > > moving, it seems to work ok, but at low speeds (such as when parking > > in a tight spot) it doesn't want to turn more then a 1/4 turn of the > > wheel. When I took a test drive prior to purchasing it, all worked > > fine during the brief trip. Now however, it's a different story. I > > was able to back the coach into it's storage spot by making what > > seemed like a 30-point turn, but I need to move it to a different > > location soon and I'm at somewhat of a loss as to what I'm up > against > > in terms of the repair. Considering the time of year & weather, I'd > > like to get a mobile mechanic out to look at it if I can, but not > sure > > I'd have much luck with that. How involved of a R&R job is this? > > > > Graham > > Baltimore, MD > > 83 FC-35 > > > [Non-text portions of this message have been removed] |
