Genset regulator - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Genset regulator (/showthread.php?tid=6813) Pages: 1 2 |
Genset regulator - Fred Hulse - 06-04-2008 14:01 Greg
The box that houses the regulator and the circuit brakers and reset switch is insulated with rubber mounts and plenty of air space inside the box.Moving the regulator elswhere might be a good idea, but I don't know where.It sits about 10 inches from the back of the motor with room around it.
Fred & Jeanne Hulse
Morristown Arizona 1997 Wanderlodge WLWB41 Genset regulator - Larry Kehler - 06-04-2008 14:13 Fred When I had my generator replaced at Power Tech last fall, they replaced my regulator but they modified the mounting. The tech said that they are now mounting them on long machine screws and three nuts per screw. The regulator is mounted with about one inch space between the back of the regulator and the box side. It seems like a reasonable modification to keep air circulating around the unit. Larry Kehler 1994 PT-40WBDA "BAM" St Louis --- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" > > Greg > The box that houses the regulator and the circuit brakers and reset switch is insulated with rubber mounts and plenty of air space inside the box.Moving the regulator elswhere might be a good idea, but I don't know where.It sits about 10 inches from the back of the motor with room around it. > Fred & Jeanne Hulse > Morristown Arizona > 1997 Wanderlodge WLWB41 > Genset regulator - Fred Hulse - 06-04-2008 14:33 Larry
That is a good thought,I still have time to do that which I wil.
Thanks
Fred & Jeanne Hulse
