Has anyone every used one of these to start a bird? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Has anyone every used one of these to start a bird? (/showthread.php?tid=7364) Pages: 1 2 |
Has anyone every used one of these to start a bird? - hippieforever3 - 11-12-2008 14:53 > run the generator, for a while press the parrell switch and hopefully > the big engine will kick over My problem is that my charger takes a long time to get to starting voltage. I'm looking to replace the charger too. Regards, GPSGary Has anyone every used one of these to start a bird? - Chuck Wheeler - 11-12-2008 15:19 Gary,
We travel in cold weather a lot with some dry camping. I have been concerned about the batteries being down and not being able to get started. I carry a small Honda in one side compartment for emergencies. I used it one weekend when the lights were left on and could start the BB after about 20 minutes.If you could run the generator I don't understand why the chargers would not have brought the batteries up so you could start. We have a 60 amp Intell-Power charger and it will geta dead battery to enough power to start in less than a half an hour.
- Chuck Wheeler-
FC 31SB Fort Worth TX
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of hippieforever3 Sent: Wednesday, November 12, 2008 4:19 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Has anyone every used one of these to start a bird? I'm still in search of an economical way to ABSOLUTELY quickly get started after dry camping. I'm a little paranoid because we accidently turned on the security lights one night and had to wait the entire next day for a jump. Couldn't get the genset to charge the batteries enough within a few hours. Has anyone ever used something like either of these two items to start a bird? http://www.harborfr http://www.harborfr I used to have one like the first item to start my tractors after sitting for a week or two but am curious if they would provide a nearly immediate start as long as the genset came alive. If you take the time to read the manual of the second item, it could be rigged up to autostart the genset with a minimum of trouble. Movin on, GPSGary 1984FC35 Has anyone every used one of these to start a bird? - Jack & Donna Smith - 11-12-2008 15:44 I donno, but if I have a dead battery in our old 'Bird when dry camping or leaving something on, I just wheel the trusty CJ over and use the K-mart jumper cables... Starts every time, but then, the Jeep probably thinks the 391 in the 'Bird is just a Thunderbird. :-) Jack Smith 1973FC31 SoCal --- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > Gary, > > We travel in cold weather a lot with some dry camping. I have been > concerned about the batteries being down and not being able to get started. > I carry a small Honda in one side compartment for emergencies. I used it > one weekend when the lights were left on and could start the BB after about > 20 minutes. If you could run the generator I don't understand why the > chargers would not have brought the batteries up so you could start. We > have a 60 amp Intell-Power charger and it will get a dead battery to enough > power to start in less than a half an hour. > > - Chuck Wheeler- > FC 31SB Fort Worth TX > > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of hippieforever3 > Sent: Wednesday, November 12, 2008 4:19 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Has anyone every used one of these to start a > bird? > > > > I'm still in search of an economical way to ABSOLUTELY quickly get > started after dry camping. > > I'm a little paranoid because we accidently turned on the security > lights one night and had to wait the entire next day for a jump. > Couldn't get the genset to charge the batteries enough within a few > hours. > > Has anyone ever used something like either of these two items to > start a bird? > > http://www.harborfr > <http://www.harborfreight.com/cpi/ctaf/displayitem.taf? Itemnumber=46944> > eight.com/cpi/ctaf/displayitem.taf?Itemnumber=46944 > http://www.harborfr > <http://www.harborfreight.com/cpi/ctaf/displayitem.taf? Itemnumber=47449> > eight.com/cpi/ctaf/displayitem.taf?Itemnumber=47449 > > I used to have one like the first item to start my tractors after > sitting for a week or two but am curious if they would provide a > nearly immediate start as long as the genset came alive. > > If you take the time to read the manual of the second item, it could > be rigged up to autostart the genset with a minimum of trouble. > > Movin on, > GPSGary > 1984FC35 > Has anyone every used one of these to start a bird? - Pete Masterson - 11-12-2008 17:37 The generator will bring up my batteries (sufficiently to start the engine) in a couple of hours. If your batteries aren't charging that quickly, I'd suggest checking your regular chargers and upgrading them to more modern ones. Check out offerings from Iota. A charger with 40 to 60 amps ought to be plenty fast to get you on the road after running the generator for an hour or two. I note, too, that it's very unwise to run batteries down below 50% of their rated amp-hours as that can damage them. Even at 50%, most BBs should be able to turn over the engine -- but I've never had to put my coach to that test... Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Lockhart Texas Has anyone every used one of these to start a bird? - sfedeli3 - 11-12-2008 23:07 Gary, On my '85, you can rock the "aux battery" switch on the dash and it will bridge the house and genny batteries- giving you added power to start the genset. If the genny battery is losing its charge, it would be cheaper to solve that problem with a "Battery Link ACR" (just google it) and get rid of whatever convoluted crap was in there before- usually a diode or battery isolator- to eliminate the voltage drain. My genny battery stays connected all winter while in storage and is like new in the spring. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "hippieforever3" wrote: > > If the bird is asleep, how do you get to the generator battery to get > jumper cables on it? My gen tray won't come out without air up. > > I can start the generator but it takes a long time to get the > batteries to where the Cat will purr. > > Regards, > GPSGary > 1984FC35 > > > > --- In WanderlodgeForum@yahoogroups.com, erniecarpet@ wrote: > > > > Gary, when I had my coach on a consignment lot, they never had it > on shore > > power. Thus the batteries were dead. I attached jumper cables to > the generator > > battery and started the generator. In just a short time, I was up > and running > > and left that facility. > > > > Ernie Ekberg > > 83PT40 > > Weatherford, Texas > > > > **************Get the Moviefone Toolbar. Showtimes, theaters, movie > news & > > more! > (http://pr.atwola.com/promoclk/100000075x1212774565x1200812037/aol? > redir=htt > > p://toolbar.aol.com/moviefone/download.html? > ncid=emlcntusdown00000001) > > > Has anyone every used one of these to start a bird? - Al Scudder - 11-13-2008 04:34 I was just going to say that. I have left my BB for 6 weeks (the longest) at rest-not plugged in. I learned the hard way that you must, turn off the DC main at the door, turn off the aux battery on the dash, turn off the converter or you will not start after a short period. I learned this AFTER I had found out that the AC power that I was using at storage barn was on a ground fault on the other side of a barn When I am stopped for any period of time and do not need any power that is what I have done.At other times I just turn on the switch for auto start if the coach is standing alone for a unexpectedlonger time than what was planned. Scooter 2000XL Plymouth, MI
Has anyone every used one of these to start a bird? - Jean Eichenlaub - 11-13-2008 08:18 I have two "portable power" units. Both are small 12 volt batteries. One has started the coach, though only when there was some power in the coach batteries. When the batteries were really flat it took an F-350 plus the portable power. Jean Eichenlaub '87 FC 35' Has anyone every used one of these to start a bird? - Frank Damp - 11-14-2008 15:23 I inherited a Coleman "Emergency Start" unit when my son emigrated to Japan. The main thing I use it for is its compressor, to assist in keeping tires up to pressure. The other day, a neighbor had a dead battery in her Mazda 3, having left a door not properly closed for a few days. The Coleman couldn't give the Mazda battery enough juice to get the engine to turn over. I've figured out why Coleman don't sell that unit any more! |
