Has anyone every used one of these to start a bird?
11-12-2008, 05:27
Gary, when I had my coach on a consignment lot, they never had it on shore power. Thus the batteries were dead. I attached jumper cables to the generator battery and started the generator. In just a short time, I was up and running and left that facility.
Ernie Ekberg 83PT40 Weatherford, Texas |
11-12-2008, 09:27
I had to crawl under the coach
11-12-2008, 10:19
I'm still in search of an economical way to ABSOLUTELY quickly get
started after dry camping. I'm a little paranoid because we accidently turned on the security lights one night and had to wait the entire next day for a jump. Couldn't get the genset to charge the batteries enough within a few hours. Has anyone ever used something like either of these two items to start a bird? http://www.harborfreight.com/cpi/ctaf/di...mber=46944 http://www.harborfreight.com/cpi/ctaf/di...mber=47449 I used to have one like the first item to start my tractors after sitting for a week or two but am curious if they would provide a nearly immediate start as long as the genset came alive. If you take the time to read the manual of the second item, it could be rigged up to autostart the genset with a minimum of trouble. Movin on, GPSGary 1984FC35 |
11-12-2008, 13:35
If the bird is asleep, how do you get to the generator battery to get
jumper cables on it? My gen tray won't come out without air up. I can start the generator but it takes a long time to get the batteries to where the Cat will purr. Regards, GPSGary 1984FC35 --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Gary, when I had my coach on a consignment lot, they never had it on shore > power. Thus the batteries were dead. I attached jumper cables to the generator > battery and started the generator. In just a short time, I was up and running > and left that facility. > > Ernie Ekberg > 83PT40 > Weatherford, Texas > > **************Get the Moviefone Toolbar. Showtimes, theaters, movie news & > more! (http://pr.atwola.com/promoclk/100000075x...12037/aol? redir=htt > p://toolbar.aol.com/moviefone/download.html? ncid=emlcntusdown00000001) > |
11-12-2008, 13:41
I carry a 200 AMP booster that plugs into AC, makes it easy to use any available AC
to soup up the batteries quick and it can delivery 400 amps for 30 seconds to help start the engine. Dorn Hetzel 77FC35 Hogansville, GA On Wed, Nov 12, 2008 at 8:35 PM, hippieforever3 <"debra@ticogps.com"> wrote:
11-12-2008, 13:55
> I carry a 200 AMP booster that plugs into AC, makes it easy to use any What make? Where'd you get it? How much? Regards, GPSGary |
11-12-2008, 14:09
11-12-2008, 14:10
I've had mine like 15 years and everything that tells who made it has long since worn off,
but here is a similar example I found for around $125 at northern tool: http://www.northerntool.com/webapp/wcs/s..._200332525 Regards, Dorn Hetzel 77FC35 On Wed, Nov 12, 2008 at 8:55 PM, hippieforever3 <"debra@ticogps.com"> wrote:
11-12-2008, 14:17
Gary,
If you are dry camping how do you get AC? A good generator battery is the answer to your problem. I should not take all day to charge the engine batteries off the generator if your chargers are working properly.
Chet Geist
1981 FC33, Austin, Texas
11-12-2008, 14:46
Gary, I maybe a little confused, you want to have a charger on the coach so that you can charge the coach while dry camping?? run the generator, for a while press the parrell switch and hopefully the big engine will kick over jim riordan 88 WBWL XXV stuart, fl hippieforever3
