Primus heat - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Primus heat (/showthread.php?tid=8683) Pages: 1 2 |
Primus heat - ronmarabito2002 - 12-04-2009 02:31 Stephen: Is there anyone around that can rejuvinate the circuit boards for the Primus? What about the new parts cost. Both of my units now are refusing to shut off when they are running. R.E. (Ron) Marabito --- In WanderlodgeForum@yahoogroups.com, "cape0001" > > we have the parts and we will offer tech advise > if they are noisy I would clean the boiler and check the burner grate > if you change to webasto be prepared to pay around 2600.00 plus labour for the install around 5,000 grand complete for a lot less I can replace all the electronic > Gas solenoid, pumps, electrode, burner plate > feel free to give me a call > Stephen 77fc35 with a webasto > 97 bmc 37 with an aquahot (its half a Webasto) > > > --- In WanderlodgeForum@yahoogroups.com, "dreamcatcher7300" <bat73@> wrote: > > > > Steven, availability of parts, can't get tech advice, always running low on propane, noisy boilers. other then that it's ok Lee Brown 94WB40 > > > > --- In WanderlodgeForum@yahoogroups.com, "cape0001" > > > > > > Why are you Changing systems > > > > > > Stephen 97 bmc 37 > > > > > > --- In WanderlodgeForum@yahoogroups.com, "dreamcatcher7300" <bat73@> wrote: > > > > > > > > I want to convert my primus system to a diesel fired system, I understand there two different systems ava, anyone have a recomendation? > > > > Lee Brown 94WB40 > > > > > > > > > > Primus heat - dreamcatcher7300 - 12-04-2009 03:19 Thanks all for your input, I do like the system, have had a few problems over the years but was always able to solve them by contacting Mark Dexter, the guy who sold the system in the US, I recently tryed to call him but the numbers I have wouldn't go through. My pump went out a couple years ago and I bought one from Mark, couldn't get the old one out so am pumping through the old one, recently discovered you can get at the old pump by removing the chassis batteries, thats my next project. Lee Brown 94WB40 Primus heat - dreamcatcher7300 - 12-04-2009 03:32 Ron, check the ,( thermister) I had that same problem, a wire broke, do the boilers shut off from high temp and the convectors keep running? Lee Brown 94WB40 --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" wrote: > > Stephen: Is there anyone around that can rejuvinate the circuit boards for the Primus? What about the new parts cost. Both of my units now are refusing to shut off when they are running. > > R.E. (Ron) Marabito > > --- In WanderlodgeForum@yahoogroups.com, "cape0001" > > > > we have the parts and we will offer tech advise > > if they are noisy I would clean the boiler and check the burner grate > > if you change to webasto be prepared to pay around 2600.00 plus labour for the install around 5,000 grand complete for a lot less I can replace all the electronic > > Gas solenoid, pumps, electrode, burner plate > > feel free to give me a call > > Stephen 77fc35 with a webasto > > 97 bmc 37 with an aquahot (its half a Webasto) > > > > > > --- In WanderlodgeForum@yahoogroups.com, "dreamcatcher7300" <bat73@> wrote: > > > > > > Steven, availability of parts, can't get tech advice, always running low on propane, noisy boilers. other then that it's ok Lee Brown 94WB40 > > > > > > --- In WanderlodgeForum@yahoogroups.com, "cape0001" > > > > > > > > Why are you Changing systems > > > > > > > > Stephen 97 bmc 37 > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "dreamcatcher7300" <bat73@> wrote: > > > > > > > > > > I want to convert my primus system to a diesel fired system, I understand there two different systems ava, anyone have a recomendation? > > > > > Lee Brown 94WB40 > > > > > > > > > > > > > > > Primus heat - ronmarabito2002 - 12-04-2009 03:38 I changed out the thermistors about a year ago. Boiler keeps going along with the fan and pump. The night before last, the system was operating just fine. When I fired it up last night, it would not shut down no matter what setting the dial was on. R.E. (Ron) Marabito, Dallas, TX 92WB40 Currently in Stonewall, TX --- In WanderlodgeForum@yahoogroups.com, "dreamcatcher7300" <bat73@...> wrote: > > Ron, check the ,( thermister) I had that same problem, a wire broke, do the boilers shut off from high temp and the convectors keep running? Lee Brown 94WB40 > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" wrote: > > > > Stephen: Is there anyone around that can rejuvinate the circuit boards for the Primus? What about the new parts cost. Both of my units now are refusing to shut off when they are running. > > > > R.E. (Ron) Marabito > > > > --- In WanderlodgeForum@yahoogroups.com, "cape0001" > > > > > > we have the parts and we will offer tech advise > > > if they are noisy I would clean the boiler and check the burner grate > > > if you change to webasto be prepared to pay around 2600.00 plus labour for the install around 5,000 grand complete for a lot less I can replace all the electronic > > > Gas solenoid, pumps, electrode, burner plate > > > feel free to give me a call > > > Stephen 77fc35 with a webasto > > > 97 bmc 37 with an aquahot (its half a Webasto) > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "dreamcatcher7300" <bat73@> wrote: > > > > > > > > Steven, availability of parts, can't get tech advice, always running low on propane, noisy boilers. other then that it's ok Lee Brown 94WB40 > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "cape0001" > > > > > > > > > > Why are you Changing systems > > > > > > > > > > Stephen 97 bmc 37 > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "dreamcatcher7300" <bat73@> wrote: > > > > > > > > > > > > I want to convert my primus system to a diesel fired system, I understand there two different systems ava, anyone have a recomendation? > > > > > > Lee Brown 94WB40 > > > > > > > > > > > > > > > > > > > > > Primus heat - dreamcatcher7300 - 12-04-2009 08:50 John, If I decide to make the change I'll let you know, Lee Brown 94WB40 --- In WanderlodgeForum@yahoogroups.com, jvredden@... wrote: > > Lee. > I have decided to stick with Primus. Are you going to sell your old > primus parts? > > John Redden > 91PT-40 > NC > > > In a message dated 12/3/2009 4:59:57 P.M. Eastern Standard Time, > cape0001@... writes: > > > > > Why are you Changing systems > > Stephen 97 bmc 37 > > --- In _WanderlodgeForum@WanderlodgeFWan_ > (mailto:WanderlodgeForum@yahoogroups.com) , "dreamcatcher7300" <bat73@> wrote: > > > > I want to convert my primus system to a diesel fired system, I > understand there two different systems ava, anyone have a recomendation? > > Lee Brown 94WB40 > > > Primus heat - cape0001 - 12-04-2009 13:09 ron sorry but the board cannot be rejuvenated parts are listed on our website dupreeproducts.com If you have any call for parts not listed on our website please call 888 668 4288 Stephen 97 bmc 37foot 10 inch --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" wrote: > > Stephen: Is there anyone around that can rejuvinate the circuit boards for the Primus? What about the new parts cost. Both of my units now are refusing to shut off when they are running. > > R.E. (Ron) Marabito > > --- In WanderlodgeForum@yahoogroups.com, "cape0001" > > > > we have the parts and we will offer tech advise > > if they are noisy I would clean the boiler and check the burner grate > > if you change to webasto be prepared to pay around 2600.00 plus labour for the install around 5,000 grand complete for a lot less I can replace all the electronic > > Gas solenoid, pumps, electrode, burner plate > > feel free to give me a call > > Stephen 77fc35 with a webasto > > 97 bmc 37 with an aquahot (its half a Webasto) > > > > > > --- In WanderlodgeForum@yahoogroups.com, "dreamcatcher7300" <bat73@> wrote: > > > > > > Steven, availability of parts, can't get tech advice, always running low on propane, noisy boilers. other then that it's ok Lee Brown 94WB40 > > > > > > --- In WanderlodgeForum@yahoogroups.com, "cape0001" > > > > > > > > Why are you Changing systems > > > > > > > > Stephen 97 bmc 37 > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "dreamcatcher7300" <bat73@> wrote: > > > > > > > > > > I want to convert my primus system to a diesel fired system, I understand there two different systems ava, anyone have a recomendation? > > > > > Lee Brown 94WB40 > > > > > > > > > > > > > > > Primus heat - ronmarabito2002 - 12-05-2009 07:14 What is the problem that prevents the Primus Boards from being rejuvinated? If they were manufactured in the first place, which we know they were, then why can't they be repaired? Is there someone that has a schematic of the board? R.E.(ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "cape0001" > > ron > sorry but the board cannot be rejuvenated > parts are listed on our website > dupreeproducts.com > If you have any call for parts not listed on our website please call > 888 668 4288 > Stephen 97 bmc 37foot 10 inch > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" wrote: > > > > Stephen: Is there anyone around that can rejuvinate the circuit boards for the Primus? What about the new parts cost. Both of my units now are refusing to shut off when they are running. > > > > R.E. (Ron) Marabito > > > > --- In WanderlodgeForum@yahoogroups.com, "cape0001" > > > > > > we have the parts and we will offer tech advise > > > if they are noisy I would clean the boiler and check the burner grate > > > if you change to webasto be prepared to pay around 2600.00 plus labour for the install around 5,000 grand complete for a lot less I can replace all the electronic > > > Gas solenoid, pumps, electrode, burner plate > > > feel free to give me a call > > > Stephen 77fc35 with a webasto > > > 97 bmc 37 with an aquahot (its half a Webasto) > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "dreamcatcher7300" <bat73@> wrote: > > > > > > > > Steven, availability of parts, can't get tech advice, always running low on propane, noisy boilers. other then that it's ok Lee Brown 94WB40 > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "cape0001" > > > > > > > > > > Why are you Changing systems > > > > > > > > > > Stephen 97 bmc 37 > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "dreamcatcher7300" <bat73@> wrote: > > > > > > > > > > > > I want to convert my primus system to a diesel fired system, I understand there two different systems ava, anyone have a recomendation? > > > > > > Lee Brown 94WB40 > > > > > > > > > > > > > > > > > > > > > Primus heat - cape0001 - 12-05-2009 09:20 I do not have a schematic of the board and yes we know who manufactured the board but they ceased production or were bought out or went bust in 1995 There is a liability problem if the present owner provides the wiring schematic and I have tried to obtain it and of course they made money selling new parts To the best of my knowledge there is no test equipment to test or exercise the boards or I would have it The best bet is to replace the parts when they become defective they are sealed in the box and opening same usually destroys it or the circuit board again I have tried without to much success it maybe something we have to learn to live with Stephen 97 bmc 37 --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" wrote: > > What is the problem that prevents the Primus Boards from being rejuvinated? If they were manufactured in the first place, which we know they were, then why can't they be repaired? Is there someone that has a schematic of the board? > > R.E.(ron) Marabito, Dallas, TX 92WB40 > > --- In WanderlodgeForum@yahoogroups.com, "cape0001" > > > > ron > > sorry but the board cannot be rejuvenated > > parts are listed on our website > > dupreeproducts.com > > If you have any call for parts not listed on our website please call > > 888 668 4288 > > Stephen 97 bmc 37foot 10 inch > > > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" wrote: > > > > > > Stephen: Is there anyone around that can rejuvinate the circuit boards for the Primus? What about the new parts cost. Both of my units now are refusing to shut off when they are running. > > > > > > R.E. (Ron) Marabito > > > > > > --- In WanderlodgeForum@yahoogroups.com, "cape0001" > > > > > > > > we have the parts and we will offer tech advise > > > > if they are noisy I would clean the boiler and check the burner grate > > > > if you change to webasto be prepared to pay around 2600.00 plus labour for the install around 5,000 grand complete for a lot less I can replace all the electronic > > > > Gas solenoid, pumps, electrode, burner plate > > > > feel free to give me a call > > > > Stephen 77fc35 with a webasto > > > > 97 bmc 37 with an aquahot (its half a Webasto) > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "dreamcatcher7300" <bat73@> wrote: > > > > > > > > > > Steven, availability of parts, can't get tech advice, always running low on propane, noisy boilers. other then that it's ok Lee Brown 94WB40 > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "cape0001" > > > > > > > > > > > > Why are you Changing systems > > > > > > > > > > > > Stephen 97 bmc 37 > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "dreamcatcher7300" <bat73@> wrote: > > > > > > > > > > > > > > I want to convert my primus system to a diesel fired system, I understand there two different systems ava, anyone have a recomendation? > > > > > > > Lee Brown 94WB40 > > > > > > > > > > > > > > > > > > > > > > > > > > > > |
