Free A/C Parts - PRWillms@... - 04-30-2010 05:43
K.. thanks.
-----Original Message-----
Sent: Fri, Apr 30, 2010 10:37 am
Subject: Re: [WanderlodgeForum] Re: Free A/C Parts
A/C exterior shrouds no longer available.
Curt Sprenger
Anaheim Hills, CA
On Fri, Apr 30, 2010 at 10:24 AM, <"PRWillms@aol.com"> wrote:
Hi Mike,
Judy and I will be down to San Diego then back to South Lake Tahoe in a week. I'm interested in the exterior covers. I could drive through to pick them up if no one else has claimed them.
Thanks,
Paul and Judy Williams
88XXV 40' 8V92 "SeekingOz"
South Lake Tahoe, CA
Sent: Fri, Apr 30, 2010 10:15 am
Mike,
The ceiling assemblies are the mechanical control, no thermostat. Same as the original A/Cs.
Curt Sprenger
Anaheim Hills, CA
On Fri, Apr 30, 2010 at 9:12 AM, mbulriss <"mbulriss@yahoo.com"> wrote:
Curt,
Can I assume you had to change out all the thermostats also? How much trouble to run the new thermostat cables? Where did you pick up the 12V from?
Thanks,
1991 WB40 "Texas Minivan"
--- In "WanderlodgeForum%40yahoogroups.com", Curt Sprenger ...> wrote:
> George, others,
> The new Dometic low profile 13,500 A/Cs are a bit quieter, no compressor
> drone, 3 blower settings, push a little more air, no heat strip,
> Curt Sprenger
> Anaheim Hills, CA
> On Thu, Apr 29, 2010 at 10:43 PM, George Burke wrote:
> > Curt, Would be interested in knowing what you used as replacement units.
> > Are they more efficient, quieter, have better heat strips. I am asking
> > because I had some Carrier Air V units in another bus, that worked well for
> > cooling, then I added heat strips, and they did not work as expected.
> > There were low and high speeds, with the high almost nullifying the heat
> > coming out. A low and medium speed would have been much better. My units are
> > the original Fridgiking, (for 1977), and may have to replace either one or
> > both this year. Thanks, George Burke 1977 FC31 Charlotte
> > On Thu, Apr 29, 2010 at 11:47 PM, Curt Sprenger ...>wrote:
> >> *4.29.2010 - FREE, YOU PAY THE PACKAGING/SHIPPINGâââ¬Ã¦*
> >> *Removed from our âââ‰â¢87 PT38âââ¬Ã¦*
> >> Replaced the three 13,500 A/C units on our Bird. Two of the A/C units are
> >> not worth saving; the third unit has worked fine for 24 years.
> >> The three ceiling assemblies, mechanical, are in good shape and include
> >> the heat units; I tested the heat units about 5 years ago and they worked
> >> then; filters are good.
> >> The three exterior covers are in good condition.
> >> So, everything is for FREE when you pay for the packaging and shipping. No
> >> charge for my time. The units are the low profile Dometic 13,500 units,
> >> beige color roof top/ceiling.
> >> Curt Sprenger
> >> Anaheim Hills, CA
Free A/C Parts - Ernie Ekberg - 04-30-2010 09:20
Hey Pul, all the snow gone?
83PT40
Wanderlodge
Weatherford, Tx 817-475-3991
Date: Friday, April 30, 2010, 12:24 PM
Hi Mike,
Thanks,
Mike,
Curt Sprenger
Anaheim Hills, CA
On Fri, Apr 30, 2010 at 9:12 AM, mbulriss <mbulriss@yahoo. com> wrote:
Curt,
Thanks,
--- In WanderlodgeForum@ yahoogroups. com, Curt Sprenger wrote:
> George, others,
> Curt Sprenger
> Anaheim Hills, CA
> >> Curt Sprenger
> >> Anaheim Hills, CA
