Neutral safty switch - Curt Sprenger -  11-06-2011 12:11
Same Key for the '87 PT38. My guess is yours is the same.  Curt Sprenger
Anaheim Hills, CA
"curtsprenger@gmail.com"
One of the "Birds of a Feather" (BoF) Organizers
 On Sun, Nov 6, 2011 at 4:01 PM, "wlb52@hotmail.com"  <"wlb52@hotmail.com"> wrote:
à
I try flipping the toggle switch from front to back four or five times and it didn't start. I'm trying to find the key for the back start spot. Do you think it could be the front key switch
Connected by DROID on Verizon Wireless
-----Original message-----
To: ""WanderlodgeForum@yahoogroups.com"" <"WanderlodgeForum@yahoogroups.com">
Sent: Sun, Nov 6, 2011 23:41:31 GMT+00:00
Subject: Re: [WanderlodgeForum] Neutral safty switch
On my former coach (1985 PT40) I had your same symptoms a few times caused by two different things. The switch for remote start back in the engine compartment apparently had bad contact points, it would act upàoccasionaly and If I flipped it from front to rear and back aàfew times the coach wouldàthen start. I replaced the switch after this happened a couple of times and that eliminated that problem. Another time I had the exact same symptoms, hit the key,àit did not crank the engine over and the starter made no noise. That time it turned out to be a jammed (stuck starter), the starter was pulled and the drive gear on the starter was easily freed up and the starter put back on, it never got stuck again.
à
Good Luck
Wayne Kotila
96PT42àà
Sent: Saturday, November 5, 2011 7:06 PM
à
Got to the neutral salty switch cut the two wires put them together and no start. Anyone no of anything it could be short of the starter. It dose not make a sound so I think its not the starter.à Thanks.àà Bill
To: Wanderlodge Forum
Sent: Fri, Nov 4, 2011 20:18:46 GMT+00:00
 Attached the bottom of the shifter mechanism
Safe travels, Ralph Charolette Fullenwider
'84 FC35 "Ruff Diamond"
Duncan, Oklahoma
Sent via BlackBerry by AT&T
-----Original Message-----
Sender: "WanderlodgeForum@yahoogroups.com"
Date: Fri, 04 Nov 2011 19:30:51
To:
Reply-To: "WanderlodgeForum@yahoogroups.com"
Subject: [WanderlodgeForum] Neutral safty switch
I have a 1985 pt 40 that started one day and the next day I get no sound out of the starter. I think it may be the neutral safty switch but I can not find it. I looked on the trans and I didn't see dose anyone know where it would be
located
Yahoo! Groups Links
Yahoo! Groups Links
*> To visit your group on the web, go to:
*> Your email settings:
*> To change settings online go to:
(Yahoo! ID required)
*> To change settings via email:
*> To unsubscribe from this group, send an email to:
*> Your use of Yahoo! Groups is subject to:
Neutral safty switch - Ralph -  11-06-2011 12:13
Rarely. Ahh let's try one more thing quickly. Sit in the drivers seat. On the lower up dash, find a switch labeled AT. Be sure it is switched to the left. If right then switch it and startSafe travels, Ralph Charolette Fullenwider
Duncan, Oklahoma
 Date: Sun, 6 Nov 2011 19:01:59 -0500 To:  Subject: Re: [WanderlodgeForum] Neutral safty switch
On my former coach (1985 PT40) I had your same symptoms a few times caused by two different things. The switch for remote start back in the engine compartment apparently had bad contact points, it would act upoccasionaly and If I flipped it from front to rear and back afew times the coach wouldthen start. I replaced the switch after this happened a couple of times and that eliminated that problem. Another time I had the exact same symptoms, hit the key,it did not crank the engine over and the starter made no noise. That time it turned out to be a jammed (stuck starter), the starter was pulled and the drive gear on the starter was easily freed up and the starter put back on, it never got stuck again.
Good Luck
Wayne Kotila
96PT42
Got to the neutral salty switch cut the two wires put them together and no start. Anyone no of anything it could be short of the starter. It dose not make a sound so I think its not the starter. Thanks. Bill
Duncan, Oklahoma
Sender: WanderlodgeForum@yahoogroups.com
To:
Reply-To: WanderlodgeForum@yahoogroups.com
located
Yahoo! Groups Links
Yahoo! Groups Links
Neutral safty switch - wlb52@... -  11-06-2011 12:52
What is the at switch. I will go out and see if I can find it
Sent: Mon, Nov 7, 2011 00:13:24 GMT+00:00
Rarely. Ahh let's try one more thing quickly. Sit in the drivers seat. On the lower up dash, find a switch labeled AT. Be sure it is switched to the left. If right then switch it and start Safe travels, Ralph Charolette Fullenwider
Duncan, Oklahoma
Good Luck
Wayne Kotila
96PT42
Duncan, Oklahoma
To:
located
Yahoo! Groups Links
Yahoo! Groups Links
Neutral safty switch - wlb52@... -  11-06-2011 12:59
Can't find a at switch. I will try taking a pic
Duncan, Oklahoma
Good Luck
Wayne Kotila
96PT42
Duncan, Oklahoma
To:
located
Yahoo! Groups Links
Yahoo! Groups Links
Neutral safty switch - Don Bradner -  11-06-2011 13:00
AT is anti-theft. Simple way to make sure the coach can't be started, but a
b**** when you don't know it got switched!
Connected
>GMT+00:00
Rarely.
Safe travels,
>                             Ralph & Charolette Fullenwider
'84 FC35
>"Ruff Diamond"
Duncan, Oklahoma
-----Original
>Message-----
Sender:
To:
Reply-To:
>safty switch
Connected by
>GMT+00:00
On my
>again.
à
Good Luck
Wayne
>Kotila
96PT42àà
________________________________
>"wlb52@..."
To:
>PM
à
Got to the
Connected by
>GMT+00:00
>switch
>Safe travels,
>Duncan,
>Oklahoma
>From:
>"William B"
>Date: Fri, 04 Nov
>2011 19:30:51
>To:
>Subject:
>located
>Yahoo! Groups
>Links
>Yahoo! Groups
>Links
>to:
>*> Your email
>settings:
>go to:
>(Yahoo! ID
>required)
>email:
>to:
Neutral safty switch - wlb52@... -  11-06-2011 13:04
This one is down under on the right and it kills everything.
Sent: Mon, Nov 7, 2011 01:00:55 GMT+00:00
 AT is anti-theft. Simple way to make sure the coach can't be started, but a b**** when you don't know it got switched!
Connected
>GMT+00:00
Rarely.
Safe travels,
'84 FC35
>"Ruff Diamond"
Duncan, Oklahoma
-----Original
>Message-----
Sender:
To:
Reply-To:
>safty switch
Connected by
>GMT+00:00
On my
>up��occasionaly and If I flipped it from front to rear and back a��few
>times the coach would��then start. I replaced the switch after this
>I had the exact same symptoms, hit the key,��it did not crank the engine
>again.
Good Luck
Wayne
>Kotila
96PT42����
>"wlb52@..."
To:
>PM
Got to the
>sound so I think its not the starter.�� Thanks.���� Bill
Connected by
>GMT+00:00
>switch
>Safe travels,
>Duncan,
>Oklahoma
>From:
>"William B"
>Date: Fri, 04 Nov
>2011 19:30:51
>To:
>Subject:
>located
>Yahoo! Groups
>Links
>Yahoo! Groups
>Links
>to:
>*> Your email
>settings:
>go to:
>(Yahoo! ID
>required)
>email:
>to:
Yahoo! Groups Links
Neutral safty switch - wlb52@... -  11-06-2011 13:07
This is our baby so you know what your helping me with
Duncan, Oklahoma
Good Luck
Wayne Kotila
96PT42
Duncan, Oklahoma
To:
located
Yahoo! Groups Links
Yahoo! Groups Links
