A/C Compressor Clutch - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: A/C Compressor Clutch (/showthread.php?tid=9648) Pages: 1 2 |
A/C Compressor Clutch - Wallace Craig - 08-28-2012 02:07 Wallace & Faye Craig
95 WLWB 42
Azle, Texas
A/C Compressor Clutch - ronmarabito2002 - 08-28-2012 02:55 Thanks Wallace, but that's the first time I've been accused of clean living. I'm glad it is done and glad that I am still able to do it. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, Wallace Craig wrote: > > Ron, now you know that clean living pays off. > > > Wallace & Faye Craig > 95 WLWB 42 > Azle, Texas > > > >________________________________ > >From: ronmarabito2002 > >To: WanderlodgeForum@yahoogroups.com > >Sent: Monday, August 27, 2012 8:28 PM > >Subject: [WanderlodgeForum] Re: A/C Compressor Clutch > > > >Successfully pulled the compressor and clutch today. You need a special tool to hold the clutch while loosening the bolt that holds the clutch on. > > > >I tried a parts house for a new magnetic coil, but they couldn't x it with anything. I went to a local a/c specialist and he had a new magnet and clutch combination for $95.00 and found an older megnetic coil. He let me have that one for $20.00. I installed it and voila, I have dash air again. > > > >R.E. (Ron) Marabito, Dallas, TXC 92WB40 > > > >--- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" wrote: > >> > >> Thanks. I know that they make 3 different pulleys. Appreciate the assistance. > >> > >> R.E. (Ron) Marabito, Dallas, TX 92WB40 > >> > >> --- In WanderlodgeForum@yahoogroups.com, "jackcj7" > >> > > >> > > >> > > >> > > >> > Yes, Ron...Fred is correct. Just make sure that your replacment clutch is compatable with the belt(s) you are using.. Â Some different cars use a different diameter pulley. Some dual V belts, some a single and, of course the serpintine belt. > >> > As a note, I have a dedicated York mounted on my Jeep as an air pump, to "air up" the tires after offroading... It is the 10 CubicInch compressor, and can run my impact wrench, among other things.. > >> > Jack Smith > >> > NoBird :-( > >> > SoCal > >> > > >> > --- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" > >> > > > >> > > Ron, > >> > > This info is what I recall from long ago, I am certain this is how the clutch is attached: > >> > > A 3/8 or 7/16 bolt is in the center, holding the clutch to the compressor, remove it. > >> > > The comp. has a tapered shaft and a keyway. > >> > > To remove the clutch easily, get a 5/8x11 bolt and screw it into the large female threads in the clutch > >> > > and that is your puller. > >> > > > >> > > Fred & Jeanne Hulse > >> > > > >> > > >> > > > > > > > > > >------------------------------------ > > > >Yahoo! Groups Links > > > > > > > > > > > > > |
