Cold weather camping, part 2 - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Cold weather camping, part 2 (/showthread.php?tid=3943) |
Cold weather camping, part 2 - Pete Masterson - 12-05-2006 05:08 NASA went to space and the astronauts used plastic baggies and bottled water. That was only after they "graduated" from diapers! Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA On Dec 4, 2006, at 5:17 PM, erniecarpet@... wrote: > Hi Steve- thanks for your input. Glad to know that I'm not the only > one that > has cold weather issues. Wish we could figure a way around the > cold- other > then going south. > I know that the water line runs are enclosed and that no warm air > can get > to them. I wonder if there is something better then heat tape to > help us out? > If Nasa can go in space~ ernie- 83PT40 in Texas- water lines > thawed- holding > tanks- not [Non-text portions of this message have been removed] Cold weather camping, part 2 - Bob & Carol Howald` - 12-05-2006 05:45 Maybe I don't understand the problem or question???But, my onboard aux compressor is plumbed thru the Drier...In order to get air to the bag's etc it has to go thru the drier. Bob 93pt-Il. might get a little melting today. In WanderlodgeForum@yahoogroups.com, Tom Warner > > Ron are you saying your aux air compressor is plumbed through the air > dryer? If not how will that help? > > tom warner > vernon center,ny > 1985 PT 40 > > At 11:40 AM 12/5/2006, you wrote: > >A nice feature for some of us equipped with an Auxiliary Compressor is > >the fact that you can do that without running the engine. > > > >R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > >--- In WanderlodgeForum@yahoogroups.com, "whistles_n_bells" > > > > > > > > Ernie: > > > > > > Glad to learn that you are closer to your home. Just a thought; when you > > > were in Montana during cold temperatures, did you use your bus while > > > you were there? I was thinking that if you didn't run your engine, the > > > air dryer would not be activated and any condensation would of course > > > freeze. One of the reasons us old bus drivers and truckers keep the > > > engines running in cold climates. Again Ernie, just a thought. Enjoy the > > > warm weather. > > > > > > Joe (Pappy) Hagan > > > St. George, UT > > > Wannabe > > > > > > --- In WanderlodgeForum@yahoogroups.com, erniecarpet@ wrote: > > > > > > > > Tom, you may be correct. i have noticed that when the dryer blows off, > > > there > > > > is a little more air coming through. It used to blow off then quit- no > > > more > > > > air. Since I'll be home for a while, I can address this issue without > > > lying > > > > on ice~ ernie -83PT40 in Texas > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > Cold weather camping, part 2 - Terry Neal - 12-05-2006 06:04 Tom, Aren't you are saying the aux compressor should be plumbed into the Bird air dryer system? That means that all the air going in to the coach system has been filtered through the air dryer. At least that's how I read your post. Please correct me if I read it wrong. This is how my aux air compressor is going to be routed. Terry Neal Bozeman, MT 82PT40 74FC34 Tom Warner wrote: > Ron are you saying your aux air compressor is plumbed through the air > dryer? If not how will that help? > > tom warner > vernon center,ny > 1985 PT 40 > > At 11:40 AM 12/5/2006, you wrote: > >A nice feature for some of us equipped with an Auxiliary Compressor is > >the fact that you can do that without running the engine. > > > >R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > >--- In WanderlodgeForum@yahoogroups.com > > > > > > > > > Ernie: > > > > > > Glad to learn that you are closer to your home. Just a thought; > when you > > > were in Montana during cold temperatures, did you use your bus while > > > you were there? I was thinking that if you didn't run your engine, the > > > air dryer would not be activated and any condensation would of course > > > freeze. One of the reasons us old bus drivers and truckers keep the > > > engines running in cold climates. Again Ernie, just a thought. > Enjoy the > > > warm weather. > > > > > > Joe (Pappy) Hagan > > > St. George, UT > > > Wannabe > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > Tom, you may be correct. i have noticed that when the dryer > blows off, > > > there > > > > is a little more air coming through. It used to blow off then > quit- no > > > more > > > > air. Since I'll be home for a while, I can address this issue > without > > > lying > > > > on ice~ ernie -83PT40 in Texas > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > Cold weather camping, part 2 - Bob & Carol Howald` - 12-05-2006 06:36 I used to have a 84 1/2pt-40 without a onboard compressor. I installed one and ran the line to the same line that goes to the shrader valve in the rear of the coach this in turn goes directly to the drier. Can't imagine an on board compressor without going to the drier?? Bob 93pt 40 In WanderlodgeForum@yahoogroups.com, Terry Neal > > Tom, Aren't you are saying the aux compressor should be plumbed into the > Bird air dryer system? That means that all the air going in to the > coach system has been filtered through the air dryer. At least that's > how I read your post. Please correct me if I read it wrong. This is > how my aux air compressor is going to be routed. > > Terry Neal > Bozeman, MT > 82PT40 > 74FC34 > > > > Tom Warner wrote: > > > Ron are you saying your aux air compressor is plumbed through the air > > dryer? If not how will that help? > > > > tom warner > > vernon center,ny > > 1985 PT 40 > > > > At 11:40 AM 12/5/2006, you wrote: > > >A nice feature for some of us equipped with an Auxiliary Compressor is > > >the fact that you can do that without running the engine. > > > > > >R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > > > >--- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > Ernie: > > > > > > > > Glad to learn that you are closer to your home. Just a thought; > > when you > > > > were in Montana during cold temperatures, did you use your bus while > > > > you were there? I was thinking that if you didn't run your engine, the > > > > air dryer would not be activated and any condensation would of course > > > > freeze. One of the reasons us old bus drivers and truckers keep the > > > > engines running in cold climates. Again Ernie, just a thought. > > Enjoy the > > > > warm weather. > > > > > > > > Joe (Pappy) Hagan > > > > St. George, UT > > > > Wannabe > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > Tom, you may be correct. i have noticed that when the dryer > > blows off, > > > > there > > > > > is a little more air coming through. It used to blow off then > > quit- no > > > > more > > > > > air. Since I'll be home for a while, I can address this issue > > without > > > > lying > > > > > on ice~ ernie -83PT40 in Texas > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > Cold weather camping, part 2 - Terry Neal - 12-05-2006 07:39 Agree with you Bob. Thanks for your confirmation. I am using a small SENCO compressor for my aux system. Should be large enough for my needs and the coach air system for early am startups. It is rated at 125 PSI & has a small single tank but I will use the existing outside air connection for all of my tire & tool needs so this one is just to get it all started without running the engine. I'll probably mount it above the new IOTA chargers on a shelf. Should be room for it and a new inverter. I'll put a shut off valve with a T into the rear shrader valve inlet so I can still use the external air inlet of the shrader valve too. Terry Neal Bozeman, MT 82PT40 74FC34 Bob & Carol Howald` wrote: > I used to have a 84 1/2pt-40 without a onboard compressor. I > installed one and ran the line to the same line that goes to the > shrader valve in the rear of the coach this in turn goes directly to > the drier. Can't imagine an on board compressor without going to the > drier?? > Bob 93pt 40 > > In WanderlodgeForum@yahoogroups.com > > > > > Tom, Aren't you are saying the aux compressor should be plumbed > into the > > Bird air dryer system? That means that all the air going in to the > > coach system has been filtered through the air dryer. At least > that's > > how I read your post. Please correct me if I read it wrong. This > is > > how my aux air compressor is going to be routed. > > > > Terry Neal > > Bozeman, MT > > 82PT40 > > 74FC34 > > > > > > > > Tom Warner wrote: > > > > > Ron are you saying your aux air compressor is plumbed through the > air > > > dryer? If not how will that help? > > > > > > tom warner > > > vernon center,ny > > > 1985 PT 40 > > > > > > At 11:40 AM 12/5/2006, you wrote: > > > >A nice feature for some of us equipped with an Auxiliary > Compressor is > > > >the fact that you can do that without running the engine. > > > > > > > >R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > > > > > > >--- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > Ernie: > > > > > > > > > > Glad to learn that you are closer to your home. Just a > thought; > > > when you > > > > > were in Montana during cold temperatures, did you use your > bus while > > > > > you were there? I was thinking that if you didn't run your > engine, the > > > > > air dryer would not be activated and any condensation would > of course > > > > > freeze. One of the reasons us old bus drivers and truckers > keep the > > > > > engines running in cold climates. Again Ernie, just a > thought. > > > Enjoy the > > > > > warm weather. > > > > > > > > > > Joe (Pappy) Hagan > > > > > St. George, UT > > > > > Wannabe > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > Tom, you may be correct. i have noticed that when the dryer > > > blows off, > > > > > there > > > > > > is a little more air coming through. It used to blow off > then > > > quit- no > > > > > more > > > > > > air. Since I'll be home for a while, I can address this > issue > > > without > > > > > lying > > > > > > on ice~ ernie -83PT40 in Texas > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > Cold weather camping, part 2 - Tom Warner - 12-05-2006 08:04 Bob just for clarification does the rear shrader valve go to the output or the input of the air dryer? I do not have a drawing to show that. Is this the same for the 80 series years or only for the 90s? tom warner vernon center,ny 1985 PT 40 At 01:36 PM 12/5/2006, you wrote: > I used to have a 84 1/2pt-40 without a onboard compressor. I >installed one and ran the line to the same line that goes to the >shrader valve in the rear of the coach this in turn goes directly to >the drier. Can't imagine an on board compressor without going to the >drier?? >Bob 93pt 40 > > > > > > > In WanderlodgeForum@yahoogroups.com, Terry Neal > > > > Tom, Aren't you are saying the aux compressor should be plumbed >into the > > Bird air dryer system? That means that all the air going in to the > > coach system has been filtered through the air dryer. At least >that's > > how I read your post. Please correct me if I read it wrong. This >is > > how my aux air compressor is going to be routed. > > > > Terry Neal > > Bozeman, MT > > 82PT40 > > 74FC34 > > > > > > > > Tom Warner wrote: > > > > > Ron are you saying your aux air compressor is plumbed through the >air > > > dryer? If not how will that help? > > > > > > tom warner > > > vernon center,ny > > > 1985 PT 40 > > > > > > At 11:40 AM 12/5/2006, you wrote: > > > >A nice feature for some of us equipped with an Auxiliary >Compressor is > > > >the fact that you can do that without running the engine. > > > > > > > >R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > > > > > > >--- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > Ernie: > > > > > > > > > > Glad to learn that you are closer to your home. Just a >thought; > > > when you > > > > > were in Montana during cold temperatures, did you use your >bus while > > > > > you were there? I was thinking that if you didn't run your >engine, the > > > > > air dryer would not be activated and any condensation would >of course > > > > > freeze. One of the reasons us old bus drivers and truckers >keep the > > > > > engines running in cold climates. Again Ernie, just a >thought. > > > Enjoy the > > > > > warm weather. > > > > > > > > > > Joe (Pappy) Hagan > > > > > St. George, UT > > > > > Wannabe > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > Tom, you may be correct. i have noticed that when the dryer > > > blows off, > > > > > there > > > > > > is a little more air coming through. It used to blow off >then > > > quit- no > > > > > more > > > > > > air. Since I'll be home for a while, I can address this >issue > > > without > > > > > lying > > > > > > on ice~ ernie -83PT40 in Texas > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > Cold weather camping, part 2 - Dan Darst - 12-05-2006 08:15 Bob. I did my own install on the aux air compressor and connected the air line (copper tubing) to the wet tank. At that point I believe that the air does not flow through the drier because it never purges. Jeff was the guidance on this place to tie it in. Has so far worked exactly as needed. Once I could not air up for a trip and did not know the purge valve was stuck open at the time. Ran the aux air compressor and did the trip as normal. Air cannot return to the aux compressor from the wet tank due to a check valve. dandarst86fc35rbhuntleyil. >From: "Bob & Carol Howald`" >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: [WanderlodgeForum] Re: Cold weather camping, part 2 >Date: Tue, 05 Dec 2006 17:45:11 -0000 > > Maybe I don't understand the problem or question???But, my >onboard aux compressor is plumbed thru the Drier...In order to get >air to the bag's etc it has to go thru the drier. Bob 93pt-Il. might >get a little melting today. > > > > > > > >In WanderlodgeForum@yahoogroups.com, Tom Warner > > > > Ron are you saying your aux air compressor is plumbed through the >air > > dryer? If not how will that help? > > > > tom warner > > vernon center,ny > > 1985 PT 40 > > > > At 11:40 AM 12/5/2006, you wrote: > > >A nice feature for some of us equipped with an Auxiliary >Compressor is > > >the fact that you can do that without running the engine. > > > > > >R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > > > >--- In WanderlodgeForum@yahoogroups.com, "whistles_n_bells" > > > > > > > > > > > Ernie: > > > > > > > > Glad to learn that you are closer to your home. Just a thought; >when you > > > > were in Montana during cold temperatures, did you use your bus >while > > > > you were there? I was thinking that if you didn't run your >engine, the > > > > air dryer would not be activated and any condensation would of >course > > > > freeze. One of the reasons us old bus drivers and truckers >keep the > > > > engines running in cold climates. Again Ernie, just a thought. >Enjoy the > > > > warm weather. > > > > > > > > Joe (Pappy) Hagan > > > > St. George, UT > > > > Wannabe > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, erniecarpet@ wrote: > > > > > > > > > > Tom, you may be correct. i have noticed that when the dryer >blows off, > > > > there > > > > > is a little more air coming through. It used to blow off then >quit- no > > > > more > > > > > air. Since I'll be home for a while, I can address this issue >without > > > > lying > > > > > on ice~ ernie -83PT40 in Texas > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > _________________________________________________________________ Stay up-to-date with your friends through the Windows Live Spaces friends list. http://clk.atdmt.com/MSN/go/msnnkwsp0070000001msn/direct/01/?href=http://spaces.\ live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx&mk Cold weather camping, part 2 - p_a_lazar - 12-05-2006 08:53 For those without aux compressor in mid 90's WBs, there is a pipe fitting that is capped in the second bay, street side in the rear. This is the input to the air system from the aux compressor if you had one. All you need to do is plumb the output from ANY compressor into this and it feeds to the air drier input side and has a check valve to prevent back feed. Also, in that same compartment, is the electrical box that is controlled by the AUX compressor switch on the dashboard. Paul 97wb43 Cold weather camping, part 2 - The Squires - 12-07-2006 16:09 Gardner, Slight correction. The brass monkeys (the cannon ball stands) were used on board the old sailing ships. You can image loose cannon balls rolling everywhere in rough seas. They were square on the bottom with indentions for each cannon ball. The next row up was simply between the balls on the bottom row until you achieve a pyramid of cannon balls. The part about "being cold enough to freeze..." is still the same principle. Jimmy -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Gardner Yeaw Sent: Monday, December 04, 2006 7:57 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Cold weather camping, part 2 Ernie, I was reading on some obscure website about cold, brass, and monkeys. It seems that back in the day there were stands used in the forts to stack cannon balls on. These stands were made of brass. So when the weather got really, really cold, the brass stand contracted enough for the cannon balls to fall off. Hence the infamous expression! Believe it or not! Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Hi Steve- thanks for your input. Glad to know that I'm not the only one that > has cold weather issues. Wish we could figure a way around the cold- other > then going south. > I know that the water line runs are enclosed and that no warm air can get > to them. I wonder if there is something better then heat tape to help us out? > If Nasa can go in space~ ernie- 83PT40 in Texas- water lines thawed- holding > tanks- not > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
