New replacement Rear camera- 450 and 380?
08-15-2014, 01:38
RE: New replacement Rear camera- 450 and 380?
This is a great system. I did have to make a 1 inch spacer to allow the right camera to shoot between the awning support rails.
09-28-2019, 22:33
Hi
I just purchased a new wired system for my 2001 LXi from Tadibrothers. I installed the rear and two side cameras. I Installed the rear night vision (IR) behind the glass. It works great during the light hours but in the dark it is blinded by the IR's. Is their any solution other than installing the camera outside? They are sending me another rear camera (they say it is their highest end. I have not installed it yet but I really don't see why it should be any better. Believe me running the cables from the rear to the front was quite a chore, Open to any suggestions. Thanks Urnie Urnie & Medie Krueger Yorkville, IL 2001 LXi One Slide 1983 FC35 sold |
09-30-2019, 13:49
The plexiglass cover reflects the IR. I think if you change it to glass, it won't reflect it, but it will depend on the glass.
1 user Likes Arcticdude's post |
09-30-2019, 19:56
Thanks - that could work. I will remove the camera and shine it inside the RV thru a glass panel. If anyone has done this please let me know to possibly save some time.
thanks Urnie Urnie & Medie Krueger Yorkville, IL 2001 LXi One Slide 1983 FC35 sold |
