Lithium Batteries
11-08-2014, 13:21
Lithium Batteries
Hi,
Switched my Group 31 Gen start battery (68 lbs) to a lithium at 5 lbs. Mounted beside the headlight so great way to reduce 80+ lbs from front axle. SHORAI LFX36L3-BS12 Lithium Battery 36Ah ,540 CCA In changing it, I suggest that you don't have your head under the big one when you try to take it off the shelf
Ross MacKillop Wiarton Ontario 2006 450 Lxi |
