Air leaking from PRV's...
09-26-2015, 03:07
Hi all -
Recently brought our 1991 SP36 home and have a few issues to iron out. Never had to deal with air systems before - is it normal on shutdown to have air leaking out of the pressure reducing valves (Bendix 281857)? Noticed it several times from two of these valves - one under the coach near the rear differential and one on the driver's side of the engine compartment. doesn't happen every time I shut down, which caused me to notice it. Ken and Tammy Morgan Fountain Hills, AZ '91 SP36 |
09-26-2015, 08:48
RE: Air leaking from PRV's...
I suspect your coach has been sitting for quite a while. All systems probably need some attention.
