Front upper dash TV
11-07-2005, 12:44
Front upper dash TV
we will probably leave on the 2nd. Don't know the exact time, yet. Ernie in
weatherford -----Original Message----- From: trautoranch To: WanderlodgeForum@yahoogroups.com Sent: Mon, 07 Nov 2005 20:47:48 -0000 Subject: [WanderlodgeForum] Re: Front upper dash TV -- Ernie, Glad you made it back home ok. Are you going to make it to the rally? What day are you leaving if you are? We are leaving on the 1st of December.Tell Brenda hi for us. Best Regards, Rick & Terri Mcintire 86PT38 Patillo,Tx - In WanderlodgeForum@yahoogroups.com, erniecarpet@a... wrote: > > Ed, you are close by. You going to the Boerne rally? Ernie-83pt40 in Weatherford > > -----Original Message----- > From: ED GARDELS > To: WanderlodgeForum@yahoogroups.com > Sent: Mon, 07 Nov 2005 18:11:33 -0000 > Subject: [WanderlodgeForum] Re: Front upper dash TV > > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@y...> > wrote: > > > > Hi Ed, > > > > It would help if you would sign your posts and indicate what model > you > > have so that we can response more accurately. For instance, if you > > are talking about the backup monitor/TV in an 83 PT, the answer is > > that the monitor is connected to the upper dash housing by four > screws > > around the front of the monitor. Disconnect high power cable and > lift > > out. So, what model are you talking about? And, is it the > TV/backup > > monitor or a separate TV? > > > > Thanks, > > > SORRY about not signing, I noticed my mistake as soon as I sent it. > (89sp) and I guess its probably the OVERHEAD dash. Imnew at this as > Ive only had my bb for a few months(2 trips). Dont know much about > it, I readthe forum and trial and error.see msg 6340 for > signing.Thanks for the reply. > ED GARDELS 89SP > ARLINGTON, TEXAS > > > > > Mike Bulriss > > 83 PT40 "Stagecoach" - For Sale - with Financing! > > 91 PT40 "Texas Minivan" > > San Antonio, TX > > > > > > --- In WanderlodgeForum@yahoogroups.com, "ED GARDELS" > > > wrote: > > > > > > Is the TV connected(screwed)to the plywood base it sits on? I am > > > trying to replace it. Have already took off metal strap over tv. > Also > > > does the tv come out the rear with base attached, or through the > front? > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > [Non-text portions of this message have been removed] > Yahoo! Groups Links [Non-text portions of this message have been removed] |
11-07-2005, 14:28
Front upper dash TV
--- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan"
> > --- ED: I have a 90SP36 and put in a 20 inch LCD TV and highly > recommend it. made a metal frame etc. > recommend a 24 in LCD with the speaker ON the bottom..It will fit..u > can get a 24 inch for what I paid for 20 Inch.... > regards, > Hank Hannigan > 90SP36 > Hank-- thanks for the input.I finnaly got the original out today.There is 19.5 inches between the doors. How would a 24" fit? Don said he put in a 20" also. Might go shopping tommorrow. thanks Ed Gardels 89sp Arlington,Tx > > > > In WanderlodgeForum@yahoogroups.com, "ED GARDELS" > wrote: > > > > --- In WanderlodgeForum@yahoogroups.com, "ED GARDELS" > > > wrote: > > > > > > Is the TV connected(screwed)to the plywood base it sits on? I am > > > trying to replace it. Have already took off metal strap over tv. > > Also > > > does the tv come out the rear with base attached, or through the > > front? > > > > > Forgot to mention its a 89sp. > > > |
11-07-2005, 14:29
Front upper dash TV
11-07-2005, 15:34
Front upper dash TV
Ed:
Some owners have modified the overhead slightly and put in larger flat screens. The installs look good too. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 02:28 AM 11/8/2005 +0000, you wrote: >--- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan" > > > > > --- ED: I have a 90SP36 and put in a 20 inch LCD TV and highly > > recommend it. made a metal frame etc. > > recommend a 24 in LCD with the speaker ON the bottom..It will >fit..u > > can get a 24 inch for what I paid for 20 Inch.... > > regards, > > Hank Hannigan > > 90SP36 > > >Hank-- thanks for the input.I finnaly got the original out >today.There is 19.5 inches between the doors. How would a 24" fit? >Don said he put in a 20" also. Might go shopping tommorrow. > thanks > Ed Gardels 89sp > Arlington,Tx |
11-07-2005, 16:50
Front upper dash TV
---ED: I am away from BIRD right now but I figured a 24 would fit IF
I found one with speaker on bottom........thought more than 20 inches door to door. maybe the 90 is different. later, Hank 90SP36 In Hawaii In WanderlodgeForum@yahoogroups.com, "ED GARDELS" wrote: > > --- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan" > > > > > --- ED: I have a 90SP36 and put in a 20 inch LCD TV and highly > > recommend it. made a metal frame etc. > > recommend a 24 in LCD with the speaker ON the bottom..It will > fit..u > > can get a 24 inch for what I paid for 20 Inch.... > > regards, > > Hank Hannigan > > 90SP36 > > > Hank-- thanks for the input.I finnaly got the original out > today.There is 19.5 inches between the doors. How would a 24" fit? > Don said he put in a 20" also. Might go shopping tommorrow. > thanks > Ed Gardels 89sp > Arlington,Tx > > > > > > > > In WanderlodgeForum@yahoogroups.com, "ED GARDELS" > > wrote: > > > > > > --- In WanderlodgeForum@yahoogroups.com, "ED GARDELS" > > > > > wrote: > > > > > > > > Is the TV connected(screwed)to the plywood base it sits on? I > am > > > > trying to replace it. Have already took off metal strap over > tv. > > > Also > > > > does the tv come out the rear with base attached, or through > the > > > front? > > > > > > > Forgot to mention its a 89sp. > > > > > > |
11-07-2005, 20:10
Front upper dash TV
Hank I had to settle for the 20'' between the door of my 89 SP 36. It was
just a little under if I remember right. The 20" Sharp just fit & got the doors open & the speakers were not on the side& it was not the wide screen. Don 89 SP 36' Butler, PA [Non-text portions of this message have been removed] |
11-08-2005, 18:24
Front upper dash TV
---DON:
I put in a 20 inch ZENITH with speakers on each SIDE.....the 90 SP must have different width between doors Regards, Hank 90SP36 In WanderlodgeForum@yahoogroups.com, dspithaler@a... wrote: > > Hank I had to settle for the 20'' between the door of my 89 SP 36. It was > just a little under if I remember right. The 20" Sharp just fit & got the > doors open & the speakers were not on the side& it was not the wide screen. > Don > 89 SP 36' > Butler, PA > > > [Non-text portions of this message have been removed] > |
