run away engine
04-26-2006, 01:07
run away engine
lets not get all worked up about a run-away engine. think -fuel this
engine will not run without fuel. go to your fuel filter where the shut
off valve is. the valve iam talking about is the valve you turn off
when you are changing your fuel filter. close this valve and the engine
will die- end of trouble.
ed mcstay
"lonesome dove"
83fcrb
lake charles la.
04-26-2006, 01:55
run away engine
Not bad advice but it will take a while to use up the fuel in the system up
stream of the valve. Considering the OEM air filter would take a bit of time to
remove, Ed's suggestion is very good. If one is concerned about such a
happening, make sure there is a fuel line shut off valve close to the injector
pump.
Mike Hohnstein
Sent: Wednesday, April 26, 2006 8:07 AM
Subject: [WanderlodgeForum] run away engine
ed mcstay
"lonesome dove"
83fcrb
lake charles la.
YAHOO! GROUPS LINKS
