High oil Temp
06-06-2006, 06:15
High oil Temp
I have a 1988 WLWB 8v92ta (1986) 475 hp..I have started having problems
when I run about 1900 2000 rpm the oil temp runs up to well if you know the guage approx 260 - 270,when this happens the cooling temp runs up to. There had been a washer in the intake for the water pump, I don't know why but was there. The temp runs up then gets to about 280 oil temp and seems that the thermostat open and then there is a big drom in both cooloing and oil temp then they start to increase again. Took it to Detroit Diesel they do not seem to have someone whom knows these engines very well. The fellow who work on it was born in 1980. Jim Riordan 1988 BB WBWL 772-260-1328 |
06-06-2006, 16:25
High oil Temp
Jim, West Palm Beach Florida, maybe somone knows of a good Detroit shop
there. My oil never gets over 250. keep cool Gregory O'Connor 94pt Romoland Ca--- In WanderlodgeForum@yahoogroups.com, "jqrjr" > > I have a 1988 WLWB 8v92ta (1986) 475 hp..I have started having problems > when I run about 1900 2000 rpm the oil temp runs up to well if you know > the guage approx 260 - 270,when this happens the cooling temp runs up > to. There had been a washer in the intake for the water pump, I don't > know why but was there. The temp runs up then gets to about 280 oil > temp and seems that the thermostat open and then there is a big drom in > both cooloing and oil temp then they start to increase again. Took it > to Detroit Diesel they do not seem to have someone whom knows these > engines very well. The fellow who work on it was born in 1980. > > Jim Riordan > 1988 BB WBWL > 772-260-1328 > |
