Replacing Power Steering Hoses to Steering Box
06-06-2006, 17:27
Fellow Wanderlodgers,
I'm working to replace all my power steering lines. I've got nearly everything off, except, I have not yet found a good way to remove the lines from the steering box itself. On my 83 FC-35, the steering box is so stuffed between the battery box and frame rail, I can't even see it, nevermind reach it. I went through previous posts and found one that recommended removing the drivers seat, rolling back the carpet, and exposing an access plate on the floor. I tried that - turns out my model does not have a plate above the steering box. Anybody have any experience in this?? There must be an easier way that I'm missing... Bluebird usually has a way that everything can be removed.. Any help is appreciated! Thanks! Andy |
06-06-2006, 22:39
Remove battery box.
MH ----- Original Message ----- From: Andy Coleman To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, June 07, 2006 12:27 AM Subject: [WanderlodgeForum] Replacing Power Steering Hoses to Steering Box Fellow Wanderlodgers, I'm working to replace all my power steering lines. I've got nearly everything off, except, I have not yet found a good way to remove the lines from the steering box itself. On my 83 FC-35, the steering box is so stuffed between the battery box and frame rail, I can't even see it, nevermind reach it. I went through previous posts and found one that recommended removing the drivers seat, rolling back the carpet, and exposing an access plate on the floor. I tried that - turns out my model does not have a plate above the steering box. Anybody have any experience in this?? There must be an easier way that I'm missing... Bluebird usually has a way that everything can be removed.. Any help is appreciated! Thanks! Andy [Non-text portions of this message have been removed] |
06-07-2006, 01:01
Andy,
On our 88 FC, I was able to remove the batteries, Lay on the ground and use a crows foot on a long extention, Needed a helper with the wrench to place it on the nut with each 1/4 turn. You may need to rearrange some wireing harnesses. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Andy Coleman" > > Fellow Wanderlodgers, > > I'm working to replace all my power steering lines. > > I've got nearly everything off, except, I have not yet found a good > way to remove the lines from the steering box itself. > > On my 83 FC-35, the steering box is so stuffed between the battery box > and frame rail, I can't even see it, nevermind reach it. > > I went through previous posts and found one that recommended removing > the drivers seat, rolling back the carpet, and exposing an access > plate on the floor. I tried that - turns out my model does not have a > plate above the steering box. > > Anybody have any experience in this?? There must be an easier way > that I'm missing... Bluebird usually has a way that everything can be > removed.. > > Any help is appreciated! Thanks! > > Andy > |
