plumbing question
07-02-2006, 03:26
plumbing question
I posted about my plumbing breaks a few weeks ago. I've got water enough to
work with at the moment but I am confused about how the system works and since it hasn't worked since I owned the coach I have no experience with it working properly. I had two breaks, one in a line going from under the vanity to the right side of the shower valve and one behind the tank--top line of the three. I replaced both with reinforced flexible hose. But something is not right. I have very little hot water flowing when the pump is on--a burst for a second or two, then a drizzle at the vanity. I have no hot water at all with city pressure and very little water either hot or coldl to the shower with city pressure but a good flow to the shower with the pump. Any ideas on what I'm missing conceptually about the system and what is wrong with it? Not in a big hurry to fix it at the moment since I'm on the road, but I'm trying to understand what is happening. Kerry |
09-12-2010, 13:17
plumbing question
How would you go about finding someone to replace the kitchen faucet
and instant hot? Mike could do it except his shoulders won't fit under the cabinet and his hands are too large to fit up behind it to do the work. We have the new units, but haven't figured out how to get up in there. Right now we are outside of Charlotte, North Carolina. Thanks for your advice. Mike and Jana Ewart 89 PT40WB -- Blessed are the people whose God is the Lord. (Psalm 144:15) |
09-12-2010, 13:25
plumbing question
Hi Mike & Jana
In my experience,I have found for that sort of work that an independent plumber would suit you fine.
Fred & Jeanne Hulse
Morristown,Arizona 97 WLWB41 |
09-12-2010, 22:45
plumbing question
09-13-2010, 02:07
plumbing question
Ernie,
No -- we can't make it to RATS -- I had already committed for that weekend not knowing that was when RATS was.  How far away will you be? Â
Jana --SD Mike--NC On Mon, Sep 13, 2010 at 6:45 AM, Ernie Ekberg <"ernietex@yahoo.com"> wrote:
09-13-2010, 07:49
plumbing question
09-13-2010, 12:35
plumbing question
so does that mean you are passing through close to where we are?
09-13-2010, 22:49
plumbing question
