Sporlan,water fill/location
04-19-2005, 10:44
Tom My sporlan valve is curbside bedroom behind that carpeted base by the
rear chassis heater. I had a leak in my water pipes where it came up through the floor & that is when I saw mine. It would be a bear to replace. Don 89 SP 36' Butler, PA Just got home from a 6000 mile trip [Non-text portions of this message have been removed] |
04-19-2005, 14:30
I have heard and read alot about the sporlan valves and water fill
valve.Are they one in the same? It takes a little bit for my water fill to stop filling when I flip the switch so i think it needs cleaning.Before I could here it stop filling, and could tell it had a good seal but now it slooooows and then finally stops. Can anyone tell me where this or these valves are located on a 90 SP36? Thanks Tom 90 SP36 Alpharetta GA |
04-19-2005, 14:37
This is one valve as you suspect.
- Jeff Miller http://www.wanderlodge.net --- In WanderlodgeForum@yahoogroups.com, "Tom Seitz" wrote: > > I have heard and read alot about the sporlan valves and water fill > valve.Are they one in the same? It takes a little bit for my water > fill to stop filling when I flip the switch so i think it needs > cleaning.Before I could here it stop filling, and could tell it had a > good seal but now it slooooows and then finally stops. > Can anyone tell me where this or these valves are located on a 90 > SP36? Thanks Tom 90 SP36 Alpharetta GA |
