Canister with Coolant Lines
02-17-2007, 09:51
There is a canister 7" dia. and 12" length. It's located under the
radiator fan mount. Coolant lines go to/from it. What is this canister? Thanks. -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. |
02-17-2007, 09:58
That's the filter canister for your engine coolant system. Uses a
filter element to trap all those pieces of crud from your engine block & radiator. Terry Neal Bozeman, MT 82PT40 6V92TA 74FC34 6V53T Curt Sprenger wrote: > There is a canister 7" dia. and 12" length. It's located under the > radiator fan mount. Coolant lines go to/from it. What is this canister? > Thanks. > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > [Non-text portions of this message have been removed] |
