wind noise
06-06-2007, 16:34
Post: #21
wind noise
Don, Curt,
Hey, I figured it out. Looked a little closer tonight with a flashlight and saw that the stuff in there is just old, cruddy foam type insulation that needs to be torn out. I also can now see the different "channels" you were talking about. This will be an easy fix. I should have looked closer before asking for extra help. :-) Thanks both for your assistance! -Ryan '86 PT-40 8V92 Tri-Cities, WA On 6/6/07, Curt Sprenger > Ryan, > > Call me and we'll talk through it 714 269-6187. > > Curt Sprenger > 1987 PT38 "MacAttach Racing" > Anaheim Hills, CA > > --- In wanderlodge@yahoogroups.com, "Ryan Wright" > > > > Curt, Don, > > > > I purchased some of this last night. Question, though: When I went to > > install it, I saw that there was already some weatherstripping just > > like it in the window channel. Now, I'm supposed to be installing this > > in the same channel that the window rides in, right? Such that the > > sliding portion of the window frame compresses against this > > weatherstripping? > > > > So, do I just rip the old stuff out and replace it with this? > > > > -Ryan > > '86 PT-40 8V92 > > Tri-Cities, WA > > > > On 6/4/07, Curt Sprenger > > > I can report that adding the weather stripping, as recommended by Don > > > Bradner, indeed stops the majority of wind noise. > > > > > > I purchased the Pile Seal from Ace Hardware, the same product #52210 > > > that Don used. > > > > > > -- > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > |
