Tranmission Code
09-23-2007, 15:17
Tranmission Code
On my 86, 8V92, PT40 with the Allison HTB741, 4-speed transmission. I am getting
a code 1 light pause then 2 quick lights. I assume this is a Code 12. Can anyone
tell me what this code is.
Thanks,
Howard Truitt, Sowega
09-24-2007, 10:58
Tranmission Code
Howard,
I recently had a transmission problem. I, too, got a code 12 when
the problem started. My trans tech told me that code 12 is
an "initial" code that comes with any problem, sort of like a
warning. There should then be another specific code that follows it.
Scott Forman
86 PT38
Memphis
--- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt"
I am getting a code 1 light pause then 2 quick lights. I assume this
is a Code 12. Can anyone tell me what this code is.
> Thanks,
09-24-2007, 11:17
Tranmission Code
Scott,
I spent about 4 hrs searching for a code chart last night. Finally found one on
WOO site. It list diagnostic codes for
MT 600, HT 700, and CT700 series transmission. It says a code 12 is low lube
pressure/oil level.
Howard Truitt, Camilla, Ga. 86 PT40
"Knat Country"
Sent: Monday, September 24, 2007 6:58 PM
Subject: [WanderlodgeForum] Re: Tranmission Code
Howard,
Scott Forman
86 PT38
Memphis
> Thanks,
Checked by AVG Free Edition.
Version: 7.5.485 / Virus Database: 269.13.28/1023 - Release Date: 9/22/2007
1:27 PM
09-24-2007, 11:45
Tranmission Code
Howard,
My trans has two checks on the stick. Hot and cold and the fluid needs to be
balanced in between the lines so to speak.
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville, FL
Royale Conversion
Sent: Monday, September 24, 2007 6:17 PM
Subject: Re: [WanderlodgeForum] Re: Tranmission Code
Scott,
on WOO site. It list diagnostic codes for
pressure/oil level.
"Knat Country"
Howard,
Scott Forman
86 PT38
Memphis
> Thanks,
1:27 PM
09-24-2007, 11:48
Tranmission Code
Well that makes sense, as I received the code shortly after a
retarder line ruptured and all the trans oil sprayed out.
Scott
> Scott,
found one on WOO site. It list diagnostic codes for
low lube pressure/oil level.
> "Knat Country"
> From: Scott Forman
> Howard,
it.
> Scott Forman
> 86 PT38
> Memphis
transmission.
this
> > Thanks,
9/22/2007 1:27 PM
