Speaking of heat
02-27-2008, 06:27
Speaking of heat
During the warm weather months I have to shut off the coolant line
going from the engine to the front heaters otherwise we would
roast in the cockpit. I have the switches in the right position
but there is a slide switch assenbly below the bu monitor that
has been replaced and is just dangling inside the small door. Can
this be the problem, and if so does someone have a wiring diagram
for the heater shut offs?
Chuck Harrison
Akron, Ohio
90 SP36
02-27-2008, 06:36
Speaking of heat
That is probably your problem. Unfortunately, I don't have a
schematic of it. Call BB tech support. They'll know.
> Chuck Harrison
> Akron, Ohio
> 90 SP36
02-27-2008, 07:38
Speaking of heat
Sounds like this could be the Winter/Summer switch, This surely
would effect the heating for the chassis heaters. But you mention the
front heater so this may not be your issue, which ever the switch,
there are sporlan valves in the coolant loop, possibly one of these
Sporlan solenoid valves are defective.
They control the coolant flow to the rear chassis heaters and another
for the front heat, on our 88 FC .
Bill 88 FC Michigan
> Chuck Harrison
> Akron, Ohio
> 90 SP36
