Lighting problem
02-07-2009, 03:24
Lighting problem
02-07-2009, 05:50
Lighting problem
Thanks to Gary, I fixed my problem in a few minutes. It was fixed by
simply plugging and unplugging the cannon connector several times - the connections must have been a little lose or dirty. The cannon connector for the lights on the 85 PT40 is located behind the panels in the overhead cabinets close to where the curtain motor is located in the living room. I figured it had to be relatively simple since ALL the curtain lights in the living room went out at the same time. So, I learned something new today! Thanks again for the help! Jerry 85 PT40 --- In WanderlodgeForum@yahoogroups.com, GARY MINKER wrote: > > I have an 85 pt40 I would be happy to talk to you about things you should know. > Gary Minker > 561 969-9245 > > --- On Fri, 2/6/09, Bob Lawrence > > From: Bob Lawrence > Subject: [WanderlodgeForum] Re: Lighting problem > To: WanderlodgeForum@yahoogroups.com > Date: Friday, February 6, 2009, 6:29 PM > > > > > > > > > > > > > Try Ernie's solution first. > > I have been behind those swithes a lot adding wires and butt > > connectors are all over the place back there. > > Bob Lawrence > > 84 PT36 > > Workcamping at Laguna Atascosa NWR Texas > > > > > I registered on this forum a few weeks back after we sold our > > Beaver > > > and bought this 85 PT40. I religously read the emails twice daily > > > and it appears there is a wealth of knowledge here. I think I need > > > some help now myself. I've fixed two plumbing problems and > > assorted > > > other things and still have a few to go. Here's my main problem > > > today: > > > > > > - Our 85 PT40 has the light switches above the front door to turn > > on > > > the light over the door and turn on the lights by the front > > curtains > > > on both sides. The other night the lights all went out and I > > haven't > > > been able to get them to turn on. > > > > > > - The little individual lights work as do the rest of them > > > throughout the coach. > > > > > > - I did take off all the switch plate covers and checked for loose > > > wires, all to no avail. > > > > > > - The lights did work sporadically, but I haven't been able to get > > > them to turn on in 2 days. > > > > > > Any ideas and help would be greatly appreciated. > > > > > > Thanks again. > > > > > > Jerry and Jayne > > > Full timing in our 85 PT40 > > > > |
