1983 35FC 3208 Engine Fan Rebuild/Replacement [Facet Fan]
09-16-2009, 00:54
Nate,
Way cool that you took the time to compose an epilogue to your thread, thoughtful. if they offer any $ for the out of production core, then they are rebuildable via parts. I have a air-fan-clutch that is a BorgWarner that was not supported by any rebuild kit. I took the fan parts to a brake liner rebuilder (L&M Friction materials RiversideCA)and matched all the orings and bearings up at Applied bearing in Corona Ca. One other method is to find a commercial truck/bigrig parts store and ask if they can match up the kit close. a typical rebuild kit cost about $125.00 Greg of Tim&Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, "compmanben" > > Hi Bob, Hi Folks, > > Great to hear from you again. > > That was just the info I was looking for. The fan part number is great too! I wanted to close up the post and summarize what I learned. > > Here is some additional information I found. I called around to three places and wanted to post the best price for the forum. > > SUPERIOR TURBO INJECTION in Detroit, MI > (800) 525-0164 > x22 larry > $497.98 + $150 [UPGRADE CHARGE FOR COMPETITIVE CLUTCHES] > $65 for solenoid kit > $30 for temperature control unit [205 degrees] > > There is a $400 core charge, but somehow they will accept my old Facet fan for only a $150 core charge. That's much better. Superior was the only place that offered this option. > > Fan Blade from American Cooling Systems 449200-22 $75 > [technical description in Bob's previous post] > This is a steel hub and nylon blades. > [Interchangeable Part Keys: American Cooling Systems Fan Blade 449200-22, BorgWarner Fan Blade 38449-09, BorgWarner Fan Blade 4735-38449-09, Cummins Fan Blade 3930243, Volvo Fan Blade 20801-3468] > > Other sources are: > > power train: indy office > 800.999.3912 > talked with bill - very knowledgeable > quoted 486.16 to rebuild an old one > solenoid kit HT993293 $127.49 > fan cltc $400 core plus $604.63 > sending unit $51.75 > > tri city truck parts > 800.438.0561 > 513.542.4812 > al - helpful and can order > $1,300 for kit - no further breakdown provided > > Thanks to everyone for their support! > > Cheers, > > Nate Owens > > --- In WanderlodgeForum@yahoogroups.com, "freewill2008" > > > > Nate - There is a Horton clutch that should be an exact replacement unless your 83 is very different from most FCs. A new fan is required anyway because the hub is different. > > > > Here is the info I sent another 83 owner a while back: > > > > The fan clutch is not too bad of a job, but it will take some time. The mechanical parts bolt right in. I ended up with a little less travel on the belt tension adjustment. No big deal. > > > > The new electric-to-air controls took a bit of thought and attention. Had to get the correct air relay from a local truck parts supplier. What you need to know: The clutch uses air pressure to engage. The relay must also exhaust pressure to release the clutch. With power on the relay coil, the clutch gets air pressure. With power off the relay coil, the clutch pressure can exhaust. Think it was called a "three way" valve, but like most switches and valves called "three way", it actually has two ways. They also sold me a neat little filter fitting that screwed right to the exhaust port of the relay valve. A nice piece. (I bought an extra and used it to vent the lid of the power steering reservoir.) > > > > An air line must be run - I used aux air, same air that supplies the suspension and air horns. To position the air relay I recommend the space under the floorboard in the area of the throttle linkage. I mounted mine behind the radiator in the engine compartment and then had to fabricate protection for the relay and air/electric lines in case of a thrown belt. The air line, fittings and relay cost about $100. > > > > I also took the opportunity to re-wire that area of the engine, including the harness up to the fuel valve area on top of the engine. This is also a great time to add a manual fan switch on the dashboard if you don't have one. Its just a SPST switch in parallel with the water temperature sensor switch on the engine. > > > > Horton does not build the Wanderlodge air clutch any longer but they will supply a remanufactured unit. The Horton reman part is 7910030. It is a reman of part number 990128. You need to find a local Horton dealer to order you the part. Horton may be able to help you find a dealer. They were very helpful on the phone. 800.621.1320. Because the reman price of $700 assumes you have a core, you must also pony up the core price of $400. > > > > Horton builds fans but they could not supply the correct fan for the Horton clutch in a Wanderlodge. I ended up getting a fan from American Cooling Systems, 800.974.3267. It had to be ordered from a Cummins dealer. It cost under $100. The fan is a 10 blade model, 3.5" bolt circle, 3/8" bolt hole diameter, 6 bolt holes, 2" pilot hole, 2.25" PW, 1.12" FB, Clockwise Rotation, and 22" overall diameter. Part number 449200-22. A couple notes: "FB" and "PW" are front-to-back dimensions. Also, fan makers do not look at rotation from the same end of the assembly as engine makers do. Clockwise IS correct. > > > > The new clutch/fan assembly runs MUCH quieter that the original, and it is better balanced. It is both a repair and an improvement. > > > > Bob Griesel '84 FC31 WLII WA > > > > > > --- In WanderlodgeForum@yahoogroups.com, "compmanben" > > > > > > Hi Folks, > > > > > > How are you? > > > > > > Thanks for the responses. I was told by a local shop that a rebuild is not possible. He may not be a machinist or may want the fat margin on spare parts. I may need to get a second opinion after hearing of several people that rebuilt theirs. I don't personally have the equipment for the rebuild. > > > > > > The spare parts are a concern. I took the model numbers referenced by the forum and they are no longer in production. Horton will 'custom' make the fan clutch if needed. However, this sounds like an expensive option. > > > > > > The fan that is meant for this fan clutch is not the right size for my shroud. There is a company that will custom [read: cu$tom] make a fan to fit. However, this also sounds like an expensive option. > > > > > > A few years back the cost [as referenced by the forum] as around $1,100. I would estimate two custom fabbed parts and their installation to be upwards of $1,800. > > > > > > In light of these three facts, does anyone have any further advice? > > > > > > God Speed, > > > > > > Nate Owens > > > 1983 35FC > > > "It's a Wanderful Life" > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "compmanben" > > > > > > > > Hi Folks, > > > > > > > > I have an 3208 engine fan clutch jingling and jangling. I currently have a Facet fan, which no longer sells or supports the fan. I started a search for a rebuild kit or a replacement to no avail. I searched the archives and came across some information, but nothing concrete. > > > > > > > > Has anyone replaced or rebuilt the engine fan clutch? Or does anyone have any advice to offer? Part numbers? Suppliers? How-to guide? Costs? Electromagnetic Clutch vs. Air Clutch? > > > > > > > > I really appreciate any information you can provide. > > > > > > > > Thanks! > > > > > > > > Nate Owens > > > > 1983 35FC > > > > "It's A Wanderlful Life" > > > > > > > > > > |
