FUEL TANK VENT
12-23-2009, 11:53
FUEL TANK VENT
Merry Christmas to all.
Home here for Christmas after running the Wisconsin and Virginia blizzards. Interesting to say the least with 3 inches of ice on the roads. This problem started with my Webasto not firing. I changed the main engine filters, the Webasto filter and the nozzle. I also cleaned the burn chamber. I started the bus and it ran for about 5 minutes and shut down. It ran out of fuel. I opened the Racor and looked inside the secondary fuel filter and empty. Weird. I then thought alge. I disconnected the inlet fuel line to the Racor and blew air to the fuel tank. The tank made a stress noise so I quit. Opened the fill cap and massive amounts of air escaped. I left the fill cap off, primed the engine, and ran it for an hour no issues. Found a broken fuel line on the Webasto. Tomorrows project. Conclusion on the engine problem. I suspect a wasp has built a nest in the fuel tank vent. Anyone know where to look for the vent on a 90 300 gallon tank. Not on my drawings. Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA |
12-23-2009, 11:57
FUEL TANK VENT
Leroy:
Do you think it is possible that water had gotten into the vent and frozen? After being in warmer weather I would give it another try. Marv 2004 M380 Ocean Shores, WA --- In WanderlodgeForum@yahoogroups.com, "jwasnewski" > > Merry Christmas to all. > Home here for Christmas after running the Wisconsin and Virginia blizzards. Interesting to say the least with 3 inches of ice on the roads. > This problem started with my Webasto not firing. I changed the main engine filters, the Webasto filter and the nozzle. I also cleaned the burn chamber. I started the bus and it ran for about 5 minutes and shut down. It ran out of fuel. I opened the Racor and looked inside the secondary fuel filter and empty. Weird. I then thought alge. I disconnected the inlet fuel line to the Racor and blew air to the fuel tank. The tank made a stress noise so I quit. Opened the fill cap and massive amounts of air escaped. I left the fill cap off, primed the engine, and ran it for an hour no issues. Found a broken fuel line on the Webasto. Tomorrows project. > Conclusion on the engine problem. I suspect a wasp has built a nest in the fuel tank vent. Anyone know where to look for the vent on a 90 300 gallon tank. Not on my drawings. > > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > |
12-23-2009, 11:59
FUEL TANK VENT
