Clearance required
10-26-2011, 02:34
Clearance required
BMC 37' is more like 37' 8" or 10" in length, with no tow bar attached. Well
over 38' with a towbar on and folded up. Dan 94 BMC 37' --- In WanderlodgeForum@yahoogroups.com, "Joe" > > Let me thank all of you for the info and insight. > > It appears that a FC would be fine and most likely a BMC as I'm also limited in building depth of 37 feet being the absolute maximum I could put inside and still walk (squeeze) around the back of the unit. > > Thanks again, > Joe > > > --- In WanderlodgeForum@yahoogroups.com, billpatty@ wrote: > > > > Depending the type of door and door track mechanism, the door may be able to be raised higher into the ceiling. Other have lowered the floor especially at the entry point. > > > > Bill Pape 1988FC Michigan > > > > --- In WanderlodgeForum@yahoogroups.com, billpatty@ wrote: > > > > > > > > > > > > > > > Bluebirds seem to be 12 feet, plus or minus. The same model can vary by inches, depending on tire size , ride height, & stuff on the roof. If you are considering a 12 foot door, some Birds will clear others may not. If a few inches are an issue, dumping the suspension will help lower the height by a few more inches. Several Birds were measured last year at a Rally, there is a chart in post #20. > > > > > > http://www.wanderlodgeownersgroup.com/fo...347&page=2 > > > > > > > > > Bill Pape 1988FC Michigan > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Joe" > > > > > > > > I'm still at it, trying to find a suitable coach that will fit in my warehouse. > > > > > > > > Can anyone tell me the clearance height of a BlueBird BMC 37? > > > > > > > > I realize this is not a BMC forum, but just maybe someone here knows and would tell me. > > > > > > > > Thanks, > > > > Joe > > > > Indian Harbour Beach, FL > > > > > > > > > > |
10-26-2011, 04:18
Clearance required
My '88 FC 35' has the front air unit removed from the top. It has an
11 foot clearance, which includes a storage box on the roof. It may be more if that AC unit is still there. Dave Swan '88 FC Silver edition |
