Interstate System Weight Limits
11-02-2005, 01:52
Tom,
From the Federal Highway Administration web site:
http://vsw.fhwa.dot.gov/qa/qa.jsp?catego...R%20658.17
Correct me if I'm wrong, but I think the drive/tag axles on an
LXi qualify as a Tandem axle.
*May States set weight limits on the Interstate
System at less than the Federal maximum weight limits?*
"No. When Interstate System weight limits were raised to the current
levels in
1974 (20,000 pounds single axle, 34,000 pounds tandem axle, 80,000 pounds
overall gross weight limits, plus bridge formula limits), States were
not required
to raise their limits accordingly, although most did. However, six
contiguous
States in the Mississippi valley, referred to as the "barrier States,"
did not
and effectively limited the weight for all vehicles moving across them to
their own limits. This was changed in 1982 when Congress established
Interstate System weight limits as minimums as well as maximums."
*What is the definition of a tandem axle?*
"It is two or more consecutive axles over 40 inches but not over 96 inches
apart. If there were 3 axles within that distance, they would be considered
a tandem axle for the purpose of Interstate weight limits."
Best regards,
David Brady
'02 LXi, Smokey, Va
Tom Warner wrote:
>David you are already 2000# over the Federally mandated maximum for
>your drive axel of 20,000 # per axel. Hope you are never stopped and
>checked. That was one of the problems with the BB...to heavy!
>Tom Warner
>1982 FC35
>Vernon Center,NY
No virus found in this outgoing message.
Checked by AVG Free Edition.
Version: 7.1.362 / Virus Database: 267.12.7/155 - Release Date: 11/1/2005
11-02-2005, 02:05
Oops, I think I see what you mean Tom. What the
fhwa site is saying is that even in a Tandem configuration,
no single axle can exceed 20000 lbs. Is this correct.
If so, then you are right, and my LXi is overweight
by federal standards. I hope I don't get stopped...
David Brady
'02 LXi, Smokey, Va
David Brady wrote:
>Tom,
>levels in
>not required
>contiguous
>did not
>Best regards,
>David Brady
>'02 LXi, Smokey, Va
>>Tom Warner
>>1982 FC35
>>Vernon Center,NY
11-02-2005, 02:37
David I always thought that no single axel can exceed 20,000# period
(as it states). And tandem axels cannot exceed 34000# . I interpret
that to mean that the steer axel and tandem axel drive wheels cannot
exceed 20,000# and the tags 14,000#.
Tom Warner
1982 FC35
Vernon Center,NY
At 08:52 AM 11/2/2005, you wrote:
>Tom,
><http://vsw.fhwa.dot.gov/qa/qa.jsp?catego...R%20658.17>http://vsw.fhwa.d\
ot.gov/qa/qa.jsp?category=23%20CFR%20658.17
>levels in
>not required
>contiguous
>did not
>Best regards,
>David Brady
>'02 LXi, Smokey, Va
> >Tom Warner
> >1982 FC35
> >Vernon Center,NY
>YAHOO! GROUPS LINKS
> * Visit your group
Wanderl\
11-02-2005, 02:58
Hi All,
Re axle weights; motorcoaches and RV's are exempt from the
Commercial Truck 20K axle limit in most every (all?) states per
legislation recently extended to 2009. This is due to the
differences between truck "tandem" axles and buses with tag axles.
RV's may be exempt on their own in some states or grouped with over
the road busses in others. Either way, commercial truck regs do not
apply per Fed DOT. The exemption, I'm told, once only applied to
Transit (Municipally owned) busses and RV's but now includes
commercial OTR buses.
The Highway Bill (SAFETEA-LU)
Axle Weight Exemptions
Issue: Over-the-road buses (OTRBs), like traditional transit buses,
have been carrying progressively more weight on each axle due to
government mandates, the latest being the wheelchair lifts required
by the Americans with Disabilities Act and market driven amenities.
As a consequence, fully loaded OTRBs approach, and sometimes may
exceed, the federal axle weight restrictions of 34,000 lbs. on the
tandem axle (with no single axle allowed to carry more than 20,000
lbs.). For example a tandem could be 17,000-17,000, but cannot be
21,000-16,000.
Motorcoaches and trucks should not have the same axle weight limits
due to the fundamental differences in vehicle design, configuration,
and vehicle use. A separate weight limit should be developed for
motorcoaches and other passenger carrying vehicles.
What's In It For You? : The current legislation allows the states to
exempt motorcoaches from axle weight restrictions on the
interstates. Fines are dependent on a number of factors, including
how much overweight they are, etc. and could be in the hundreds of
dollars.
When Does This Start: Congress granted a temporary axle weight
exemption for buses. This is a continuation of language that we
obtained previously, and will continue through 2009.
What's Next: The majority of states are already exempt. Please
notify ABA if you encounter sates that do not exempt motorcoaches.
NOTE: For information on "off-interstate" do a google search for
(22,500 axle weight) find any state you wish and check the
regulations.
As always, states (or towns) may limit weight on a particulay road
just as they limit certain roads for passenger cars only.
Rich D. '99LXi43' CT
--- In WanderlodgeForum@yahoogroups.com, David Brady
> Tom,
current
> levels in
pounds
were
> not required
> contiguous
States,"
> did not
them to
established
96 inches
considered
> Best regards,
> David Brady
> '02 LXi, Smokey, Va
for
> >Tom Warner
> >1982 FC35
> >Vernon Center,NY
11/1/2005
