Water Leaks!
03-05-2006, 14:58
Post: #21
Water Leaks!
Thanks Greg. I saw those and the write up said they had been tested carefully
under all conditions. But when I first looked at them they didn't look as substantial as the compression fittings and this is a job I only want to do once! Bruce Morris (919)872-7635 Raleigh, NC Webmaster - Wanderlodge Owners Online 1983 WL FC35RB FMCA: 7142s Ham Radio: KI4ME Vietnam Vet - 1966-67 'Doc' (Navy Corpsman) 3rd MarDiv ----- Original Message ----- From: pbe43 To: WanderlodgeForum@yahoogroups.com Sent: Sunday, March 05, 2006 9:08 PM Subject: [WanderlodgeForum] Re: Water Leaks! Pex makes a connector that works like copper tubing connector. No ferrel needed. The pex connectors come in all configurations. elbows, unions. I have used them for years. Cut tubing slide nut over tubing push fitting into tubing screw nut till it is tight. Just to make sure this would work, i heated water in tubing to 175 degrees and 100 psi no leaks and no failures. Did this right the water heater outlet line. 6 years later no problems, and they work in cramped spaces, no need for the long handle crimpers. Also much less costly. Greg SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
03-05-2006, 15:40
Post: #22
Water Leaks!
Pex tubing works nicely IF you get the correct product , have the
correct tools to cut (has to be clean and perfectly square to prevent leaks) and install it. There are two different general kinds of Pex tubing that which is coated and does not pass oxygen and that without coating which does. In addition not all Pex tubing can be used for potable water purposes unless it is marked with a laboratory seal and/or words to the effect that it is safe to use for potable water purposes. For your purposes I would think the straight lengths would be best and easiest to use. tom warner 1982 FC35 Vernon Center,NY for such prominAt 09:08 PM 3/5/2006, you wrote: >Pex makes a connector that works like copper tubing connector. No >ferrel needed. The pex connectors come in all configurations. elbows, >unions. I have used them for years. Cut tubing slide nut over tubing >push fitting into tubing screw nut till it is tight. Just to make >sure this would work, i heated water in tubing to 175 degrees and 100 >psi no leaks and no failures. Did this right the water heater outlet >line. 6 years later no problems, and they work in cramped spaces, no >need for the long handle crimpers. Also much less costly. >Greg > > > > > > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms&k=Recr...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\ ObWmSYTw>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms&k=Wand...w2=Wa\ nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\ ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\ anderlodge ><http://groups.yahoo.com/gads?t=ms&k=Auto...3;veh\ icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\ =Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\ 4cC1O9CxA>Automotive >maintenance ><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\ l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\ er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\ YHfELr6o72IW1A>Recreational >vehicle dealer ><http://groups.yahoo.com/gads?t=ms&k=Used...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\ -kXbDI4ZSadEw>Used >recreational vehicles ><http://groups.yahoo.com/gads?t=ms&k=Auto...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\ q_4GlXA>Automotive >radiators > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
03-05-2006, 16:49
Post: #23
Water Leaks!
Mine has two of them. One under the kitchen sink, and one under the bed, on
top of the rear furnace.- Of course neither did a bit of good when the previous owners didn't keep the coach plugged in--- not to mention properly drained, and maintained. However, I did set the thermostats on them to around 38 Just for kicks.(not like its going to get there here in Florida very often, but just in case) Stephen 81 FC-33SB Plant City, Fl _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of mbulriss Sent: Sunday, March 05, 2006 1:03 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Water Leaks! Bruce - The freeze heaters on my 83 had an adjustable thermostat on each of them. Mine were set to kick on at about 35 degrees or so. Maybe someone turned yours up higher if they are running at temps well above freezing. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Bruce Morris" <bamnc@...> wrote: > > Yes Tom. I know about the freeze heaters and they are still there. However I doubt that they are working as they were designed. They seemed to run a whole lot more than they should when the ambient temperature was well above freezing. Like many things in a 20+ year old Bird they just need attention and since I was incapacitated for most of the last 4 or 5 years I am playing catch up. > > I am familiar with the tape that has the thermostat in the end and I haven't pulled one of the blue wires yet to check it, but am under the impression that there was no mechanism at the end of the wire. I'll learn more when I can see one that is intact. > > > ----- Original Message ----- > From: Tom Warner > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, March 05, 2006 10:26 AM > Subject: Re: [WanderlodgeForum] Water Leaks! > > > Bruce if you have the coach as it was originally built you should > have a freeze protector (electric heater with blower) installed near > the water tank and another in the area of the kitchen sink. These are > thermostatically controlled and will keep the pipes from freezing. > The blue heat tape is further protection and is a resistance tape > that is controlled by a thermostat molded in at the end of the tape. > > tom warner > 1982 FC35 > Vernon Center,NY > > At 09:34 AM 3/5/2006, you wrote: > >Well Tom, as I said earlier I don't winterize my Bird but I do keep > >it connected to electricity and keep heat in it when it gets too > >cold. Maybe it's just a "Bruce" thing. > > > >I know that my Bird came from New Hampshire where it probably got > >cold enough to be a problem. All of the problems I have encountered > >did not occur on my watch, but I have to deal with them. I suspect > >the same thing is true of Bruce in Florida too since I believe he > >just bought the coach from someplace up north. > > > >So I guess you are right neither one of us followed the procedures > >as outlined in the Blue Box. > > > >Bruce Morris (919)872-7635 Raleigh, NC > >Webmaster - Wanderlodge Owners Online > >1983 WL FC35RB > > > >FMCA: 7142s Ham Radio: KI4ME > >Vietnam Vet - 1966-67 'Doc' (Navy Corpsman) 3rd MarDiv > > ----- Original Message ----- > > From: Tom Warner > > To: WanderlodgeForum@yahoogroups.com > > Sent: Saturday, March 04, 2006 11:57 PM > > Subject: Re: [WanderlodgeForum] Water Leaks! > > > > > > The fact that you both have frozen pipes begs the question of whether > > either of you properly followed the procedures for winterizing your > > fresh, grey and black water systems that is outlined in your > > owners manuals? > > > > tom warner > > 1982 FC35 > > Vernon center,NY > > > > At 09:52 PM 3/4/2006, you wrote: > > >Stephen, that is exactly what I am doing with my Bird now. It looks > > >like I am going to have to remove most of the pipes and replace > > >them. The ones that had not burst were expanded so that none of the > > >standard fittings will work. So, to do it right I have decided to > > >replace the copper with PEX which is supposed to be resistant to > > >bursting if frozen and it supposed to be much easier to work with in > > >tight areas. > > > > > >I have some pictures on the WOO site where I have taken mine apart, > > >but I still have to put the new in yet. I will be doing it in the > > >next few days . . . one way or the other. > > > > > >Bruce Morris (919)872-7635 Raleigh, NC > > >Webmaster - Wanderlodge Owners Online > > >1983 WL FC35RB > > > > > >FMCA: 7142s Ham Radio: KI4ME > > >Vietnam Vet - 1966-67 'Doc' (Navy Corpsman) 3rd MarDiv > > > ----- Original Message ----- > > > From: Stephen > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Saturday, March 04, 2006 9:35 PM > > > Subject: [WanderlodgeForum] Water Leaks! > > > > > > > > > Anyone else out there had to deal with what Im going through? I have > > > Niagra Falls running through my bus... Almost ALL of the copper water > > > pipes are busted...(I guess thats what I get for buying a unit from up > > > north) I got 3 repaired today --after removing the water tank- and now > > > there are more behind the stove-ice maker area!! I dont know how im > > > going to get those out from behind there, and the shower area(SB)..... > > > Any ideas????? HELP!!! > > > > > > > > > Stephen > > > 81 FC-33SB > > > Plant City, FL > > > > > > > > > > > > > > > > > > > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive > > > maintenance > > > Recreational vehicle dealer Used recreational > > > vehicles Automotive radiators > > > > > > > > > > >--------------------------------------------------------------------------- --- > > > YAHOO! GROUPS LINKS > > > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > > > b.. To unsubscribe from this group, send an email to: > > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > > > of Service. > > > > > > > > > > >--------------------------------------------------------------------------- --- > > > > > > > > > > > >[Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > >SPONSORED LINKS > > > > ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAU kCKkU7Dzhn_ObWmSYTw> &k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automoti ve+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles& w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_ObWmSYTw>http://groups. yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAU kCKkU7Dzhn_ObWmSYTw> &k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automoti ve+maintenance&w4=Recreational+vehicle+dealer& > > > > >vehicles > > > > ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2 =Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLP j9U0JvqYQ> &k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotive+mainten ance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles&w6=Automot ive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>http://groups.yahoo.com/ gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2 =Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLP j9U0JvqYQ> &k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotive+mainten ance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles&w6=Au > > > > > > ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+de aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF 4u_5wI8Pmy34cC1O9CxA> &k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automot ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles &w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34cC1O9CxA>http://groups .yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+de aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF 4u_5wI8Pmy34cC1O9CxA> &k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automot ive+maintenance&w4=Recreational+vehicle+dealer > > > > >maintenance > > > > ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s ig=z6_XahaeYHfELr6o72IW1A> &k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wanderlodge&w3=Au tomotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+veh icles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeYHfELr6o72IW1A>http://g roups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s ig=z6_XahaeYHfELr6o72IW1A> &k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wanderlodge&w3=Au tomotive+maintenance&w4=Recreat > > > > >vehicle dealer > > > > ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.si g=UGEY5km4L-kXbDI4ZSadEw> &k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w3=Aut omotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehi cles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-kXbDI4ZSadEw>http://gr oups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.si g=UGEY5km4L-kXbDI4ZSadEw> &k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w3=Aut omotive+maintenance&w4=Recreationa > > > > >recreational vehicles > > > > ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNV MmISsCWgTnMq_4GlXA> &k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotiv e+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles&w 6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq_4GlXA>http://groups.y ahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNV MmISsCWgTnMq_4GlXA> &k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotiv e+maintenance&w4=Recreational+vehicle+dealer&w5= > > > > >radiators > > > > > > > > >---------- > > >YAHOO! GROUPS LINKS > > > > > > * Visit your group > > > > > "<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/gr oup/WanderlodgeForum>WanderlodgeForum" > > on the web. > > > * > > > * To unsubscribe from this group, send an email to: > > > * > > > > > derlodgeForum-unsubscribe@yahoogroups.com > > > > > > > > * > > > * Your use of Yahoo! Groups is subject to the > > > > > <<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/>Yahoo! > > Terms of Service. > > > > > > > > >---------- > > > > > > > > > > > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive > > maintenance > > Recreational vehicle dealer Used recreational > > vehicles Automotive radiators > > > > > >--------------------------------------------------------------------------- --- > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > > of Service. > > > > > >--------------------------------------------------------------------------- --- > > > > > > > >[Non-text portions of this message have been removed] > > > > > > > > > > > >SPONSORED LINKS > ><http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAU kCKkU7Dzhn_ObWmSYTw> &k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automoti ve+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles& w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_ObWmSYTw>Recreational > >vehicles > ><http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2 =Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLP j9U0JvqYQ> &k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotive+mainten ance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles&w6=Automot ive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>Wanderlodge > ><http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+de aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF 4u_5wI8Pmy34cC1O9CxA> &k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automot ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles &w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34cC1O9CxA>Automotive > >maintenance > ><http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s ig=z6_XahaeYHfELr6o72IW1A> &k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wanderlodge&w3=Au tomotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+veh icles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeYHfELr6o72IW1A>Recreati onal > >vehicle dealer > ><http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.si g=UGEY5km4L-kXbDI4ZSadEw> &k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w3=Aut omotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehi cles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-kXbDI4ZSadEw>Used > >recreational vehicles > ><http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNV MmISsCWgTnMq_4GlXA> &k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotiv e+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles&w 6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq_4GlXA>Automotive > >radiators > > > > > >---------- > >YAHOO! GROUPS LINKS > > > > * Visit your group > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > > * > > * To unsubscribe from this group, send an email to: > > * > > derlodgeForum-unsubscribe@yahoogroups.com > > > > * > > * Your use of Yahoo! Groups is subject to the > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > >---------- > > > > > > > > ---------------------------------------------------------------------------- -- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ---------------------------------------------------------------------------- -- > > > > [Non-text portions of this message have been removed] > SPONSORED LINKS Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAU kCKkU7Dzhn_ObWmSYTw> vehicles Wanderlodge <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2 =Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLP j9U0JvqYQ> Automotive <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+de aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF 4u_5wI8Pmy34cC1O9CxA> maintenance Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s ig=z6_XahaeYHfELr6o72IW1A> vehicle dealer Used <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.si g=UGEY5km4L-kXbDI4ZSadEw> recreational vehicles Automotive <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNV MmISsCWgTnMq_4GlXA> radiators _____ YAHOO! GROUPS LINKS * Visit your group "WanderlodgeForum <http://groups.yahoo.com/group/WanderlodgeForum> " on the web. * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. _____ [Non-text portions of this message have been removed] |
03-05-2006, 16:56
Post: #24
Water Leaks!
Yes Greg-
That is what I am replacing them all with. Makes for a neat and clean connection. Everything at my local Home Depot. No tools needed here. Just a PVC pipe cutter, and an open end wrench!!! Stephen 81 FC-33SB Plant City, Fl _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of pbe43 Sent: Sunday, March 05, 2006 9:09 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Water Leaks! Pex makes a connector that works like copper tubing connector. No ferrel needed. The pex connectors come in all configurations. elbows, unions. I have used them for years. Cut tubing slide nut over tubing push fitting into tubing screw nut till it is tight. Just to make sure this would work, i heated water in tubing to 175 degrees and 100 psi no leaks and no failures. Did this right the water heater outlet line. 6 years later no problems, and they work in cramped spaces, no need for the long handle crimpers. Also much less costly. Greg SPONSORED LINKS Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAU kCKkU7Dzhn_ObWmSYTw> vehicles Wanderlodge <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2 =Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLP j9U0JvqYQ> Automotive <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+de aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF 4u_5wI8Pmy34cC1O9CxA> maintenance Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s ig=z6_XahaeYHfELr6o72IW1A> vehicle dealer Used <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.si g=UGEY5km4L-kXbDI4ZSadEw> recreational vehicles Automotive <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNV MmISsCWgTnMq_4GlXA> radiators _____ YAHOO! GROUPS LINKS * Visit your group "WanderlodgeForum <http://groups.yahoo.com/group/WanderlodgeForum> " on the web. * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. _____ [Non-text portions of this message have been removed] |
