Loose wheel SP36?
04-06-2006, 03:20
Loose wheel SP36?
I took the bird out for a test drive after replacing the thermostat
and ran over a rather large pothole at which time I heard (and felt)
a rattling from the right front wheel which felt similar to an episode
I experienced with an old truck I had which turned out to be worn
kingpins. Questions are: does this coach have kingpins and if so
how big a job is it to replace them?
Chuck Harrison
90 SP36
Akron, Ohio
04-06-2006, 12:42
Loose wheel SP36?
thermostat
felt)
episode
> Chuck Harrison
> 90 SP36
> Akron, Ohio
Chuck,
Yes, your SP has king pins. I have not done a replacement of them
on my SP, but if it is anything like the other work I have done,
(brakes tires, valve adjust, fan clutch, radiator) it is not any
different than on a car, tractor, etc. Just much bigger,
heavier, etc. You will of course need the proper size
reamer, etc. I am sure the parts are available from Blue Bird,
however, they are probably available from bus - heavy truck parts
suppliers also.
Jim Brookshire
89 SP-36
Saluda, NC
04-06-2006, 12:42
Loose wheel SP36?
thermostat
felt)
episode
> Chuck Harrison
> 90 SP36
> Akron, Ohio
Chuck,
suppliers also.
Jim Brookshire
89 SP-36
Saluda, NC
