Coach Potable Water Pump
11-19-2006, 14:16
there are a bunch on ebay search shurflo or jabsco whichever you prefer
Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, David Brady > > Thanks Jay, > > On my coach the Shurflo 2088 pumps run simultaneously. Others > have wired in a switch to use one as a backup. Do you have a preferred > vendor to buy the pump from? Looking forward to freeing up some > space in the basement water pump closet. > > David B > '02 LXi, Smokey > Va, soon to be NC > > Jay Darst wrote: > > David, > > > > I removed my old noisey diaphram pump, the accumulator and the on > > board water filter. All of this was in the same crampt spot, so > > really made some room with just the pump going back in. > > > > If I do it over again, I'd get the Shurflo Smart Sensor 5.7. Brother > > has it, works great, bit higher shower pressure, little better volume > > (in case some in the kitchen while I'm in the shower). > > > > The pump will come with a variety of connectors for the water lines. > > I didn't have to buy anything else(85PT40) as they sent everything I > > needed. Not seen the much newer '02 pump set up. > > > > Do the redundant pumps run simultaneously? > > > > Get rid of the accunulator and both pumps, the variable speed pumps > > do a very good job. Was pleasantly surprised when it performed as > > described, you DO NOT need an accumulator. > > > > The only time I notice the micro second delay is while shaving, > > rinsing the razor without just leaving the water on. (not supposed > > shave while playing anyway ;~} ...) > > > > Make the change and don't look back! > > > > Jay Darst > > 85PT40 > > Springfield, IL > > > > > > --- In WanderlodgeForum@yahoogroups.com, David Brady > > wrote: > > > >> Hi Jay, > >> > >> My FloJet accumulator tank just threw in the towel. In addition, > >> in my short time with my coach I've gone through 2 Shurflo > >> > > diaphragm > > > >> water pumps; time to look for alternatives, which leads me to > >> your serendipitous post. Is there anything I need to know about > >> adapting the Jabsco 31755 to my bus, or is it simply remove the > >> rats nest of parallel Shurflo's and the accumulator tank along with > >> all the associated plumbing and drop in one single elegant device, > >> the Jabsco? > >> > >> Thanks > >> David Brady > >> '02 LXi, Smoke > >> Va, "but not for long" > >> > >> Jay Darst wrote: > >> > >>> Eric, > >>> > >>> I replaced my factory water pump with a Jabsco model#31755. It > >>> provides 4.5 gallons per minute(GPM) and has a 12amp/12volt draw. > >>> > >>> I like it because its quiet, variable speed, variable flow, > >>> > > constant > > > >>> pressure(about 40 psi) and I could remove the accumulator tank. > >>> > > The > > > >>> accumulator tank can have its issues, such as trying to get the > >>> proper air pressure on the bladder side. > >>> > >>> The new pump has worked flawlessly for 3 years now. There are > >>> > > pumps > > > >>> with higher GPM and pressure, I haven't needed anything larger > >>> > > than > > > >>> the 4.5GPM, 40PSI. > >>> > >>> I think my house runs about 60psi, so the pump is really close > >>> > > to > > > >>> provideing the same pressure as home. It definitely provides > >>> > > more > > > >>> flow(GPM) than shore water does. > >>> > >>> I like it alot. My borther has the next bigger pump. Its a > >>> > > Shurflo > > > >>> Smart Sensor 5.7, 65psi. He likes it I think. Maybe he'll > >>> > > comment > > > >>> here, he's real bashful or doesn't talk much or sumthin.. ;~} > >>> > >>> Anyway, yea, make the change > >>> > >>> Jay Darst > >>> 85PT40 > >>> Springfield, IL where the lows are 29 degrees and the highs are > >>> > > in > > > >>> the 40's, kinda sucks for this time of year... > >>> > >>> --- In WanderlodgeForum@yahoogroups.com, "Eric Johnson" > >>> > > > > > >>> wrote: > >>> > >>> > >>>> Has anyone tried the Flojet variable speed water pump? They > >>>> > >>>> > >>> advertise higher flow rates and > >>> > >>> > >>>> less noise. We have a Shurflo that pump that is noisey and has > >>>> > >>>> > >>> sprung a leak so I'm tempted > >>> > >>> > >>>> to try the Flojet. > >>>> > >>>> Eric in San Antonio > >>>> 84FC35SBWL2 > >>>> > >>>> > >>>> > >> > >> [Non-text portions of this message have been removed] > >> > >> > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > |
11-19-2006, 14:36
I placed an order for the ShurFlo Smart Sensor 5.7 from rvpartsoutlet.
They have the best price that I've seen so far. I'll let you know how it performs. Thanks for your help. David B '02 LXi, Smoke, Va, soon to be NC Jay Darst wrote: > David, > > The supplier Dan I both used was > https://www.rvpartsoutlet.com/newstore/nojava/index.cfm > > The pump I reccomend is > https://www.rvpartsoutlet.com/newstore/n...wprod.cfm? > ID=3513&src=shurflo&refid=9CDF3CAF%2DCDA5%2D4DC8%2D8D99A5E0D4D79D92 > > If you have trouble with the link, its their Stock Number:19-0163 > > Its currently on special for $149.95, a pretty good buy on this pump. > > Its $169.95 over at PPL, and $193.50 at Camping World. > > Have used RVPartsOutlet.com many times, great prices and same great > service. > > Jay Darst > 85PT40 > Springfield, IL > > > > > > |
11-20-2006, 06:17
I, too, just placed an order for the same pump ... and
RVPartsOutlet.com had the best price. Both of my Shurflow 2088 pumps have seeping leaks -- and I'm not impressed with the rat's nest of plumbing required to use them. Since I was going to have to rebuild both pumps, this looks like a better solution. (I wasn't too pleased with the delivery/pressure from the 2088s either.) I'll post my impressions once I get the new pump installed. Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA On Nov 19, 2006, at 6:36 PM, David Brady wrote: > I placed an order for the ShurFlo Smart Sensor 5.7 from rvpartsoutlet. > They have the best price that I've seen so far. I'll let you know > how it > performs. Thanks for your help. > > David B > '02 LXi, Smoke, > Va, soon to be NC > > Jay Darst wrote: >> David, >> >> The supplier Dan I both used was >> https://www.rvpartsoutlet.com/newstore/nojava/index.cfm >> >> The pump I reccomend is >> https://www.rvpartsoutlet.com/newstore/n...wprod.cfm? >> ID=3513&src=shurflo&refid=9CDF3CAF%2DCDA5%2D4DC8%2D8D99A5E0D4D79D92 >> >> If you have trouble with the link, its their Stock Number:19-0163 >> >> Its currently on special for $149.95, a pretty good buy on this pump. >> >> Its $169.95 over at PPL, and $193.50 at Camping World. >> >> Have used RVPartsOutlet.com many times, great prices and same great >> service. >> >> Jay Darst >> 85PT40 >> Springfield, IL >> >> >> >> >> >> > > > > > Yahoo! Groups Links > > > > [Non-text portions of this message have been removed] |
11-20-2006, 16:42
Pete, if you only use one pump you must plug the in and out of the
one not used or connect both in's and outs to the new one. I put a tube in-line of a leaking pump for a temp fix once. the tube caused a circular path for the water. The not used pump has a check valve that must close for the other pump to build pressure.. I think that check valve on a nonoperating pump is the cause when some coaches pump have continual run, low pressure problems. Gregory O'Connor 94ptRomolandca --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > I, too, just placed an order for the same pump ... and > RVPartsOutlet.com had the best price. Both of my Shurflow 2088 pumps > have seeping leaks -- and I'm not impressed with the rat's nest of > plumbing required to use them. Since I was going to have to rebuild > both pumps, this looks like a better solution. (I wasn't too pleased > with the delivery/pressure from the 2088s either.) > > I'll post my impressions once I get the new pump installed. > > Pete Masterson > aeonix1@... > '95 Blue Bird Wanderlodge WBDA 42' > El Sobrante, CA > > > > > On Nov 19, 2006, at 6:36 PM, David Brady wrote: > > > I placed an order for the ShurFlo Smart Sensor 5.7 from rvpartsoutlet. > > They have the best price that I've seen so far. I'll let you know > > how it > > performs. Thanks for your help. > > > > David B > > '02 LXi, Smoke, > > Va, soon to be NC > > > > Jay Darst wrote: > >> David, > >> > >> The supplier Dan I both used was > >> https://www.rvpartsoutlet.com/newstore/nojava/index.cfm > >> > >> The pump I reccomend is > >> https://www.rvpartsoutlet.com/newstore/n...wprod.cfm? > >> ID=3513&src=shurflo&refid=9CDF3CAF%2DCDA5%2D4DC8% 2D8D99A5E0D4D79D92 > >> > >> If you have trouble with the link, its their Stock Number:19-0163 > >> > >> Its currently on special for $149.95, a pretty good buy on this pump. > >> > >> Its $169.95 over at PPL, and $193.50 at Camping World. > >> > >> Have used RVPartsOutlet.com many times, great prices and same great > >> service. > >> > >> Jay Darst > >> 85PT40 > >> Springfield, IL > >> > >> > >> > >> > >> > >> > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > [Non-text portions of this message have been removed] > |
11-21-2006, 09:49
Thanks for the suggestions ... I suspected that the removed pump
would be blocked off or the ins/outs tied together. I'll take some photos when I do the job and share them later. Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA On Nov 20, 2006, at 8:42 PM, Gregory OConnor wrote: > Pete, if you only use one pump you must plug the in and out of the > one not used or connect both in's and outs to the new one. I put a > tube in-line of a leaking pump for a temp fix once. the tube caused a > circular path for the water. The not used pump has a check valve that > must close for the other pump to build pressure.. I think that check > valve on a nonoperating pump is the cause when some coaches pump > have continual run, low pressure problems. > Gregory O'Connor > 94ptRomolandca > > --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > wrote: >> >> I, too, just placed an order for the same pump ... and >> RVPartsOutlet.com had the best price. Both of my Shurflow 2088 > pumps >> have seeping leaks -- and I'm not impressed with the rat's nest of >> plumbing required to use them. Since I was going to have to > rebuild >> both pumps, this looks like a better solution. (I wasn't too > pleased >> with the delivery/pressure from the 2088s either.) >> >> I'll post my impressions once I get the new pump installed. >> >> Pete Masterson >> aeonix1@... >> '95 Blue Bird Wanderlodge WBDA 42' >> El Sobrante, CA >> >> >> >> >> On Nov 19, 2006, at 6:36 PM, David Brady wrote: >> >>> I placed an order for the ShurFlo Smart Sensor 5.7 from > rvpartsoutlet. >>> They have the best price that I've seen so far. I'll let you > know >>> how it >>> performs. Thanks for your help. >>> >>> David B >>> '02 LXi, Smoke, >>> Va, soon to be NC >>> >>> Jay Darst wrote: >>>> David, >>>> >>>> The supplier Dan I both used was >>>> https://www.rvpartsoutlet.com/newstore/nojava/index.cfm >>>> >>>> The pump I reccomend is >>>> https://www.rvpartsoutlet.com/newstore/n...wprod.cfm? >>>> ID=3513&src=shurflo&refid=9CDF3CAF%2DCDA5%2D4DC8% > 2D8D99A5E0D4D79D92 >>>> >>>> If you have trouble with the link, its their Stock Number:19-0163 >>>> >>>> Its currently on special for $149.95, a pretty good buy on this > pump. >>>> >>>> Its $169.95 over at PPL, and $193.50 at Camping World. >>>> >>>> Have used RVPartsOutlet.com many times, great prices and same > great >>>> service. >>>> >>>> Jay Darst >>>> 85PT40 >>>> Springfield, IL >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >>> Yahoo! Groups Links >>> >>> >>> >>> >> >> >> >> [Non-text portions of this message have been removed] >> > > > > > > > Yahoo! Groups Links > > > > [Non-text portions of this message have been removed] |
11-22-2006, 01:39
Thanks to Darsts and others for the information on variable speed fresh water
pumps. I installed a 4.5 gpm FloJet Sensor VSD in our coach a couple of days ago. I can still hear it run but, it's much quieter than the old Shurflo plus we get higher flow rates when we want them. Picked it up at New Braunfels Camping World for $170. One feature I really appreciated while installing it in the small cavity behind the galley cabinets was the rotatable inlet/outlet fittings versus fixed orientation of the old pump fittings. They have a clever quick change system for straight or 90º elbows and barbed versus threaded. Now we'll see how reliable it is. Regards, Eric in San Antonio 84FC35SBWL2 --- In WanderlodgeForum@yahoogroups.com, "Eric Johnson" > > Has anyone tried the Flojet variable speed water pump? They advertise higher flow rates and > less noise. We have a Shurflo that pump that is noisey and has sprung a leak so I'm tempted > to try the Flojet. > > Eric in San Antonio > 84FC35SBWL2 > |
